Results 1 to 4 of 4
Thread: refurbish a stripped window regulator???
  1. #1
    Registered User '77az280z's Avatar
    Member ID
    CZCC-19083
    Join Date
    Apr 2009
    Location
    Mesa Arizona
    Age
    31
    Posts
    74
    Default refurbish a stripped window regulator???
    Is there any way you can refurb a stripped window regulator? I have the original window regulator but its stripped so i cant really roll my windows up and down. Any ideas?
  2. #2
    Registered User
    Member ID
    CZCC-20230
    Join Date
    Oct 2009
    Location
    The z is in Pittsburgh
    Posts
    294
    Default
    What part is stripped? The regulator is just a few pieces of stamped steel welded/pinned together. Would probably be less cost and work to locate another regulator that works than to refurb your existing ones. I haven't seen new-old-stock ones anywhere, but used ones are around.
  3. #3
    Registered User grantf's Avatar
    Member ID
    CZCC-17660
    Join Date
    Aug 2008
    Location
    seattle
    Posts
    1,298
    Default
    show pics please, perhaps a little welding and grinding can fix it. if so send it my way and I may be able to help.
  4. #4
    Member ID
    CZCC-19083
    Join Date
    Apr 2009
    Location
    Mesa Arizona
    Age
    31
    Posts
    74
    Default
    Ill post pics later tonight, but basically the regulator is fine, its the part the handle hooks onto, the little grooves that the handle grips onto so it can turn and crank the regulator is stripped unfortunately. Pics to come!!
Thread Information
Users Browsing this Thread
Similar Threads
  1. window regulator
    By rgilp in forum Help Me !!
    Last Post: 04-30-2009, 08:30 PM
  2. Drivers Window Regulator (Replacement)
    By mikewags in forum Interior (S30)
    Last Post: 07-06-2008, 03:58 PM
  3. Door Window Problems and Checks
    By EScanlon in forum Tech Pubs and HowTo
    Last Post: 09-02-2007, 02:55 PM
  4. Door Window Adjustments
    Last Post: 10-22-2004, 08:27 AM
  5. window regulator in a 70 Z
    By RobertH in forum Interior (S30)
    Last Post: 11-25-2003, 04:53 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
