You'll want to define "correct" for your purposes.
Do you mean
1 - An antenna that works?
or;
2 - The OEM, Stock, Kanji Stamp, proper Date Code, verified Series I antenna tip with the proper exterior mount?
or;
3 - The replacement antenna that Nissan offered in latter years, which other than the antenna tip, works the same, and is hidden under the plastic panel?
or;
4 - An aftermarket antenna which can be made to operate the same as the original and it works?
That will help in answering your question.
FWIW
E
Bookmarks
