Results 1 to 16 of 16
Thread: 240Z hatch repair panel
  1. #1
    Registered User
    Member ID
    CZCC-22018
    Join Date
    Jul 2010
    Location
    Palmetto State
    Age
    57
    Posts
    23
    Default 240Z hatch repair panel
    I have a '72 and am in the process of replacing some rusted metal. I have read of the possibilty of bonding the under-hatch (above tail lights) repair panel using one of the high-tec body adhesives. Has anyone done this? I thought about using this method along with spot welds on the braces coming off the rear panel above the tag. Seems like this would eliminate the possibility of rust after welding in hard to treat areas. Any thoughts? Does anyone have one of these panels made by Nissan they would like to sell? Thanks!
  2. #2
    Registered User grantf's Avatar
    Member ID
    CZCC-17660
    Join Date
    Aug 2008
    Location
    seattle
    Posts
    1,298
    Default
    I spot welded mine on and used seam filler on the underside farely strait forword.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	37245   Click image for larger version.
  3. #3
    Registered User psdenno's Avatar
    Member ID
    CZCC-14231
    Join Date
    Apr 2007
    Location
    SoCal Desert
    Age
    73
    Posts
    1,091
    Default
    Quote Originally Posted by grantf View Post
    Nice job on the fix! Did you use any special coating on the original metal under the panel you welded in place? Looks like that rust went fairly deep into the rear structure..
    Dennis
    1971 240Z - Original Owner
    2010 Infiniti G37 Convertible
  4. #4
    Registered User esmit208's Avatar
    Member ID
    CZCC-19498
    Join Date
    Jun 2009
    Location
    308 Palmetto Avenue Melbourne Florida 32901
    Age
    62
    Posts
    464
    Default
    Yes it is a nice job. I too would be interested in purchasing a replacement panel. Anyone that can put us on to a source would be much appreciated. I plan to cut mine away and start fresh. Project 3/72 moves along slowly.
  5. #5
    Mike B
    Member ID
    CZCC-9102
    Join Date
    Aug 2005
    Location
    WA
    Posts
    1,946
    Default
    Quote Originally Posted by esmit208 View Post
    http://www.thezstore.com/page/TZS/PROD/SBC1C02/30-7291
    -Mike
  6. #6
    Registered User doradox's Avatar
    Member ID
    CZCC-14809
    Join Date
    Aug 2007
    Location
    Colfax, IN
    Posts
    708
    Default
    I got mine here for about $85 shipped. Of course the exchange rate was very favorable at the time.
    https://rsp-secure.com/rarespares/de...%20240Z%20260Z
  7. #7
    Yup, It's Orange CoastGuardZ's Avatar
    Member ID
    CZCC-2476
    Join Date
    Jul 2002
    Location
    Clermont, FL
    Age
    41
    Posts
    975
    Default
    I need to do this same fix... so you actually put the new panel on top of the old rusted one? Why not cut out the old and install the new panel? I'm not a paint and body guy so take it easy on me, but that just seems hokey.
    -Nate
    1972 Datsun 240Z #HLS30-47945 (aka: Kikka)
    2007 Nissan Frontier Crew Cab Long Bed SE 4x4 6 spd
    2005 Nissan Sentra 1.8s SE (Wife-Mobile)
  8. #8
    Member ID
    CZCC-19498
    Join Date
    Jun 2009
    Location
    Age
    62
    Posts
    464
    Default
    Quote Originally Posted by Mike B View Post
    Thanks a bunch Mike
  9. #9
    Registered User Walter Moore's Avatar
    Member ID
    CZCC-3035
    Join Date
    Oct 2002
    Location
    Indianapolis
    Posts
    1,833
    Default
    Quote Originally Posted by CoastGuardZ View Post
    Depends upon your skill level. Personally I have barely mastered the pop rivet and bondo approach sufficiently to get by. If you can weld, and weld very thin sheet metal which is an even higher level skill, then your approach to repairs will be different I suspect.
    '71 240Z, Because any fool can drive fast in a straight line.
  10. #10
    Member ID
    CZCC-2476
    Join Date
    Jul 2002
    Location
    Clermont, FL
    Age
    41
    Posts
    975
    Default
    Quote Originally Posted by Walter Moore View Post
    You're a far sight better than me... I will be taking it to a body shop
    -Nate
  11. #11
    Registered User
    Member ID
    CZCC-22018
    Join Date
    Jul 2010
    Location
    Palmetto State
    Age
    57
    Posts
    23
    Default
    Looks good grantf...does it seem like the seam sealer will keep the water out from under the panel (above the tail light panel)? That's the area that always rusts and after welding, it doesn't look like there's a way to seal it off well enough to prevent future rust.
    CoastGuardZ, you do remove the old part first...I didn't mean to imply that you bond on top of the original part...it has to come out first. But, there's some good sized overlap areas when installing this part that would allow you to bond it in and not have to worry about untreated areas.
    Thansk for the leads guys...MSA seems a little high on that part although it's supposed to be a quality piece. That's a really good price on the Aussie part. doradox, how is the quality on that part?
  12. #12
    Member ID
    CZCC-14809
    Join Date
    Aug 2007
    Location
    Colfax, IN
    Posts
    708
    Default
    Quote Originally Posted by CarolinaTZ View Post
    The price on the Aussie part was good mainly because of the exchange rate at the time which was about 1.5 AUD to 1 USD. It's about 1.15 AUD to 1 USD right now. I and another member bought one each so the shipping was a little less per unit also. The quality is good but the hole that the latch protrudes through is a little smaller than the one on my 72 so it's not an exact replacement for that year. I can't vouch for any other year.
    Steve
    I slipped into my jeans
    Lookin' hard and feelin' mean
    I took a spit at the moon
  13. #13
    Registered User ajmcforester's Avatar
    Member ID
    CZCC-7115
    Join Date
    Sep 2004
    Location
    Cherry Hill, NJ
    Posts
    1,221
    Default
    I've used a body adhesive instead of using roset (sp?) welds on a truck bed panel and it has held for the last 7 years no problem. FYI spot welds are made with two panels roset (sp?) welds are the ones when you drill a hole and weld, and with a little paint look like spot welds. The truck had 86 spot welds that I would need to roset weld, so the adhesive looked like a good idea.
    I don't know if it would be a good idea to weld metal with the adhesive in the middle. You would damage the adhesive bond and contaminate the welds making poor bonding on two accounts. On my 240z the have seem sealer along the seems in this area and that kept it from rusting from below. I have the rust in the corner from the top it got a little thin and pin-holed so I'm replacing and will have it spot welded and put on new seam sealer. However if I was not going for an original, or I was replace this panel, but was not stripping the car to a shell I'd consider using these automotive bonding adhesives. It is easy just get a whole bunch of clamps, and you won't need seem sealer.
  14. #14
    Member ID
    CZCC-17660
    Join Date
    Aug 2008
    Location
    seattle
    Posts
    1,298
    Default
    Sorry I have been away on a motorcycle cross country trip up into Canada for the last five days....
    No you need to remove the old metal piece first, I plug welded mine back were the old spot welds were. As for metal treatment I removed as much rust as I could then used rust converter in the hard to reach places, all metal was stripped bare than coated with weld thru primer. after welding seam sealer (out of a caulking tube) was used between the new part and adjoining panels, this was how it was originally installed at the factory. hope this helps clarify.
  15. #15
    Registered User
    Member ID
    CZCC-22018
    Join Date
    Jul 2010
    Location
    Palmetto State
    Age
    57
    Posts
    23
    Default
    Alright!...another motorcycle guy. Never been into Canada...just a lot of trips to East Tennessee and NC mountains. Anyway, back to the subject. I'll be bonding the new panel in. I finished removing the old on last night from a fairly rustfree 240 and there's a ton of surface rust on the remaining panel. There's a couple of inches of metal overlap where these panels meet which will give a good bond. And it will be permanently sealed from water. There are 4 spotwelds for the extra braces above the tag, which I will weld. Thanks for the input, guys.
  16. #16
    Registered User
    Member ID
    CZCC-22018
    Join Date
    Jul 2010
    Location
    Palmetto State
    Age
    57
    Posts
    23
    Default
    Installed the replacement panel with 3m panel adhesive...worked great and solid as a rock. And water can't get to it at all...serves as it own seem sealer.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 1971 240z hatch repair PICs need help!
    By wickiewicked in forum Body and Paint (S30)
    Last Post: 07-30-2006, 12:30 AM
  2. 240Z horn button repair
    By kenz240z in forum Tech Pubs and HowTo
    Last Post: 08-19-2004, 05:46 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
