Results 1 to 6 of 6
Thread: Tail light problem
  1. #1
    Registered User
    Member ID
    CZCC-22307
    Join Date
    Aug 2010
    Location
    Oregon
    Posts
    1
    Default Tail light problem
    I have a 1972 240 which has a tail light problem. On the left rear light the brake light and the turn signal light do not work. On the same light the back up light and regular light does work. I have changed the bulbs to no avail. Does anyone have a suggestion?
  2. #2
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Inspect the sockets and clean out corrosion.
    Use a voltmeter and check for voltage from the socket to the chasis. If you have voltage, check the continuity of your ground wire.
    Ensure you have a dual filament bulb.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  3. #3
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    76
    Posts
    1,334
    Default
    Physically check your fuses with an ohmmeter. They can look good, but be bad. Take them out of the holder to do this.
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  4. #4
    Registered User 240ZX's Avatar
    Member ID
    CZCC-1420
    Join Date
    Dec 2001
    Location
    Santa Paula, California
    Age
    69
    Posts
    1,884
    Exclamation
    I had a similar issue when I was redoing my 1970....seemed as though some of the tail lights worked and some didn't. After checking things out, I discovered that the switch on the steering colomn (it was the original unit) was just worn from many many years of use. After replacing it, all was fine again. Just some food for thought!
    Tom
  5. #5
    Registered User biddljj's Avatar
    Member ID
    CZCC-11405
    Join Date
    Apr 2006
    Location
    Colorado
    Posts
    236
    Default
    I just went thru this exercise on my 72 240Z
    1. Make sure the harness connections are good on the steering column
    - Especially the grounds
    - I found one issue by shaking the wiring harness
    2. Clean the harness connections on the passenger side under dash
    3. Make sure the bulbs are right
    4. Replace the flasher unit located above the steering column with a digital unit
    5. Refurbish the turn signal switch guts: Load following URL and read slowly
    http://www.classiczcars.com/forums/s...switch+rebuild
    Jay
    Not just a Z - ZDisease
  6. #6
    beandip beandip's Avatar
    Member ID
    CZCC-1887
    Join Date
    Mar 2002
    Location
    Beaverton, Oregon
    Age
    81
    Posts
    4,038
    Default
    First check the bulbs that are not working with a meeter to see they are indeed good. Then check the light socket with the meeter for voltage and continuity on the ground. If no joy check the connector for corrosion . Still no Joy then go to the combo switch. If the combo switch is not working , I recommend contacting David Irwin , He rebuilds them for a nominal fee. Replacing the combo switch can be a spendy matter . I have seen them sell for $200.00+ on ebay.
    I'd rather die while I am living than live while I am dieing. CZC 1887 IZCC 12602 Member of NorthWest Z Car Club
Thread Information
Users Browsing this Thread
Similar Threads
  1. 280 tail light panel ?
    By 280ZSS in forum Body and Paint (S30)
    Last Post: 02-18-2011, 08:30 AM
  2. Tailight issues
    By deadflo in forum Electrical (S30)
    Last Post: 11-21-2004, 10:04 AM
  3. Brake light Problem
    By Razor in forum Open 240K Discussion
    Last Post: 04-16-2004, 05:05 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
