Results 1 to 5 of 5
Thread: Tacho differences
  1. #1
    Registered User Noddle's Avatar
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default Tacho differences
    Hi,
    FYI for anyone having tacho issues.
    I finished moving my turbo setup from my '77 four door to my '73 two door a week ago, but I been having issue getting my tacho working again, I spent some time checking some wiring diagrams, and noticed there were differences between the too,
    one has 3 wires, power, earth, - side of the coil, (late)
    the other, 4 wires, power, earth, and a loop wire (loop picks up inductive energy from the power to the coil I believe) (early)
    swapped the tacho over, working fine now.
    Nigel
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	39907   Click image for larger version.
    Datsun 240K
    Turboed L24, Megasquirt II, EDIS
    Current project
  2. #2
    skyc110 skyc110's Avatar
    Member ID
    CZCC-12962
    Join Date
    Oct 2006
    Location
    Saudi Arbia
    Posts
    127
    Default
    on my 1976 ( late edition of C110 ) I have that loop, dose that mean my meters are not the original ?
    took from an early C110 ?
    and BTW I am always facing prob with Tacho needle unstability !
    the C110 240k is a not normal car
  3. #3
    240Krazy! Adzmax's Avatar
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    I'm looking at this now. I've got a late model Japanese cluster at home and the one from my '75. The '75 has the loop style. From what you are saying, I'll need to use the later model tacho if I want to use an electronic dizzy yeah?
  4. #4
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    My understanding is, the loop coil one should work, and long as the coil has it power going through the 'loop'.
    I could have done this on my EDIS setup, but I create my wiring harness to suit the other type of tacho
    Nigel
    Datsun 240K
    Current project
  5. #5
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    Ahhh nice, thanks for the info buddy.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 7
    Last Post: 03-24-2014, 06:07 PM
  2. Easiest way to remove tacho from '72 240Z?
    By alhbln in forum Electrical (S30)
    Last Post: 12-30-2009, 12:47 AM
  3. Differences in Gas Tanks?
    By DMC-Z in forum Engine and Drivetrain (S30)
    Last Post: 07-22-2009, 05:53 PM
  4. Replaced tacho with 240k
    By 260Zed in forum Australia and New Zealand
    Last Post: 02-03-2004, 02:33 PM
  5. 240z tacho problem
    By zr240 in forum Electrical (S30)
    Last Post: 11-30-2003, 06:08 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
