Results 1 to 8 of 8
Thread: Added header - Now idle is too high - HELP
  1. #1
    Registered User KingTutVII's Avatar
    Member ID
    CZCC-19369
    Join Date
    May 2009
    Location
    North Carolina
    Posts
    8
    Default Added header - Now idle is too high - HELP
    I just installed a MSA 3-2 header and exhaust system on my 1972 240z and now my idle is too high. It used to idle around 800 rpms, now it idle around 1200-1300 rpms. Overall it seem to run great. Just idles high. Is there a quick idle adjustment on these SUs ? Any help would be greatly appreciated.
    I know there is tons of info. already in this forum, but it is very hard to find any specifics... Thanks again in advance
    1972 240z
    MSA 3-2 Header
    Performance Cam
    Wish List A Mile Long
  2. #2
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Do you perchance have the linkage not connected to both carbs the same, possibly holding one open?
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  3. #3
    Registered User Gary in NJ's Avatar
    Member ID
    CZCC-21253
    Join Date
    Mar 2010
    Location
    Amongst the twisty roads
    Posts
    1,057
    Default
    I would expect that after installing headers a full carb adjustment would be in order.
    Gary
    Guardian of HLS30-91415
    Previous Owner of a 10/70 240Z ('83-'85)
  4. #4
    Member ID
    CZCC-19369
    Join Date
    May 2009
    Location
    North Carolina
    Posts
    8
    Default
    Quote Originally Posted by Bruce Palmer View Post
    It ran like a champ prior to header and exhaust installation. It still runs very well, just the idle is 400-500 rpms higher. I have checked the linkage and all seems to be fine.
    1972 240z
    MSA 3-2 Header
    Performance Cam
  5. #5
    Registered User ajmcforester's Avatar
    Member ID
    CZCC-7115
    Join Date
    Sep 2004
    Location
    Cherry Hill, NJ
    Posts
    1,221
    Default
    You can't expect to change one thing like the header and not impact something else. Not to mention you had to move the intake to put the headers on and you can't expect it all went exactly like it came off. You need to fully tune the carbs.
  6. #6
    Fired Up! JLPurcell's Avatar
    Member ID
    CZCC-7454
    Join Date
    Dec 2004
    Location
    Richmond, Indiana
    Age
    67
    Posts
    1,098
    Question Is it one word or two?
    "Z-Therapy"
    I understand they offer a visual set up guide for SU's.
    I agree that with the removal and installation of the headers you need to set up and balance your SU's.
    JLP
    Jerry Purcell
    1970 HLS30 00029 Owner since 1976 Now owned by Les Canaday (Classic Datsun Motorsports)
    1972 HLS30 93606 IZCC Registion #105 Original owner back home after full restoration by Classic Datsun Motorsports
  7. #7
    Registered User tlorber's Avatar
    Member ID
    CZCC-20299
    Join Date
    Oct 2009
    Location
    Los Angeles
    Age
    55
    Posts
    1,190
    Default
    Just try backing off the idle adjustment on the carbs (evenly). Hopefully you have a flow meter to sync them. If not you should get one.
  8. #8
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Sounds like a vacuum leak to me. Start by spraying starting fluid (or something similar) around the parts that were removed or tampered with when you installed the header. I'd suspect a hose that is cracked or not quite sealing, or the intake/exhaust gasket especially if you didn't install a new one.
Thread Information
Users Browsing this Thread
Similar Threads
  1. 71 240z high idle
    By Raquelita in forum Help Me !!
    Last Post: 03-19-2010, 11:20 PM
  2. high idle when synchronizing SU's
    By rossman in forum SU Carb Discussions
    Last Post: 04-06-2008, 03:22 PM
  3. High RPM when idle
    By Blue 280zx in forum Open S30 Z Discussions
    Last Post: 12-10-2007, 06:36 PM
  4. High Idle
    By mholmes in forum Help Me !!
    Last Post: 01-16-2006, 08:21 PM
  5. high idle
    By christ0ph in forum Open Discussions
    Last Post: 03-27-2003, 05:38 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
