Since making it look pretty is a high priority, why not install new fire wall grommets for plumbing, electrical, throttle, choke cables etc. All of these are much easier to install with the engine out and the little touches will make a big difference when everything is back together. I'm assuming you are also degreasing the engine and accessories while it is out as well. Also sooo much easier with the engine out. Obviously check and replace the engine mounts if needed. Access to front end suspension and steering components is also much easier with the engine out if they need to be refreshed. I'm sure I am missing some other obviously things but these were top of mind, as I just did mine.
Bookmarks
