Results 1 to 7 of 7
Thread: Brake rotor not fitting 240Z vs 280Z hub?
  1. #1
    Registered User Zealous's Avatar
    Member ID
    CZCC-16672
    Join Date
    Apr 2008
    Location
    Santa Clara, CA
    Posts
    305
    Default Brake rotor not fitting 240Z vs 280Z hub?
    Hey All,
    While I have the suspension out and replacing more bits and bobs on the car, I decided to refresh the rotors and brakes while changing the shocks and springs. I went to install some new 240z rotors I picked up but they are much taller in the hat then the old rotors I have. After looking around here and hybridz I am wondering if I have had my hubs replaced by 280z hubs some where in the cars life, or that I have the wrong new rotors. How I can tell the difference? The photo below show the difference in rotor hat sizes, even taking into account the wear of the rotor~2mm or so the hat is ~8-10mm taller than the old one. I am wondering if I had 280z rotors on the car? Does anyone have a 280z rotor with measurements so that I can compare? Or if there is a way to look at the hubs and know for certain if it is a 240z or 280z hub? I searched for this information all over but I could not find anything. If I missed it please send me to that thread.
    Click image for larger version.
ID:	47293Click image for larger version.
    Cheers
    JC
    Current Project: 1971 Datsun 240z Series I - HLS30-14842
    Current drivers:
    1972 Datsun 240z - HLS30-69726
    2009 Kawasaki Ninja 250R
    2010 Mazdaspeed3
  2. #2
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    They look like aftermarket rotors. What is the distance, compared between the two, from the bearing seat to the rotor face? And the dust seal seat. That will determine if the rotor is centered in the caliper, assuming the bearing diameters and other critical dimensions are the same.
  3. #3
    Member ID
    CZCC-16672
    Join Date
    Apr 2008
    Location
    Santa Clara, CA
    Posts
    305
    Default
    The difference is enough that the back of the rotor rubs up against the dust backing plate once mounted. The rear of the hub used to stick behind the rotor but with the new rotor it does not stick behind anymore. The hubs and bearings are exactly the same I have not changed them just the rotors and the rotor appears to be too tall. Moving the rotor back about 10mm up agains the dust cover.
    Cheers
    JC
    Current drivers:
    2010 Mazdaspeed3
  4. #4
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Apparently, the rotors are different, starting with the 260Z, which you apparently already know. But if you have 280Z rotors on your 240Z, you must also have the 280Z front struts and hub assembly, I believe. Maybe you should check those dimensions.
    That's all I know. Good luck.
  5. #5
    Member ID
    CZCC-16672
    Join Date
    Apr 2008
    Location
    Santa Clara, CA
    Posts
    305
    Default
    Thanks Zed Head, that is what I am asking what are the dimensions and difference of the hubs?
    Maybe it is time I pulled the other Z apart too to check.
    Cheers
    JC
    Current drivers:
    2010 Mazdaspeed3
  6. #6
    Member ID
    CZCC-16672
    Join Date
    Apr 2008
    Location
    Santa Clara, CA
    Posts
    305
    Default
    Does anyone know the offset difference for the brake rotors between the 240z and 280z hubs? Just talked to part manufactures and they have sold many of the rotors and never had a problem with fitment reported.
    Cheers
    JC
    Current drivers:
    2010 Mazdaspeed3
  7. #7
    Member ID
    CZCC-16672
    Join Date
    Apr 2008
    Location
    Santa Clara, CA
    Posts
    305
    Default
    Ok so I think I have worked out that I do have 280z hubs on the front now looking at these two hybridz threads. My rotors are of the 280z height.
    http://forums.hybridz.org/index.php/...30-brake-info/
    240z rotor info.
    # of Bolt Holes : 4
    Bolt Circle Diameter : 103 mm
    Brake rotor Diameter : 10.67"
    Brake rotor Discard Thickness : .41"
    Brake rotor Thickness New : .49"
    Brake rotor Type : Disc Brake rotor Only
    Center Hole Diameter : 3.19"
    Height : 2.02"
    Maximum Lateral Runout : .004"
    Mounting Type : Type L - rotor Only. The rotor Is Mounted Inboard Of The Hub. The Hub & rotor Sections Are Bolted Together. Replace The Complete Assembly If Hub Flange Is Bent Or Damaged. See Diagram For More Information.
    Vented / Solid : Solid
    260-280z rotor info.
    # of Bolt Holes : 4
    Height : 1.7"
    guess the height is the differnce between the two. that is why the Hub spacers are also different in thickness when converting to vented z31 rotors depending on hubs being used.
    More information in:
    http://forums.hybridz.org/index.php/...-front-offset/
    Hope this helps someone else. Now off to source 280z rotors.
    Cheers
    JC
    Current drivers:
    2010 Mazdaspeed3
Thread Information
Users Browsing this Thread
Similar Threads
  1. Is the bolt circle on brake rotor different than the wheel?
    By kray-z-1 in forum Wheels, Tires and Brakes (S30)
    Last Post: 07-01-2010, 04:11 PM
  2. question about OE brake rotor suppliers
    By BTF/PTM in forum Wheels, Tires and Brakes (S30)
    Last Post: 05-03-2010, 05:35 PM
  3. Replies: 4
    Last Post: 12-13-2009, 05:32 PM
  4. F.I.A. Brake System-Stock Rotor
    By fixitman in forum Wheels, Tires and Brakes (S30)
    Last Post: 09-19-2008, 05:47 PM
  5. When did brake rotor hat height change?
    By Royce in forum Wheels, Tires and Brakes (S30)
    Last Post: 02-06-2008, 10:05 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
