Results 1 to 11 of 11
Thread: Noddles Front Brake Upgrade
  1. #1
    Registered User Noddle's Avatar
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default Noddles Front Brake Upgrade
    Hi,
    I've been wanting to do this for ages , I special ordered these blank rotors from DBA and they have been sitting in my spare room for a few years now.
    and now I have some time, the weathers getting nice ( no shed to work in though ), and I found a small engineering firm,
    the spacers between the hub and rotors, the enlargement of the center hole for the rotor, and the caliper spacers, all came to $50, not to bad I thought.
    Nigel
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	48275   Click image for larger version.
ID:	48276   Click image for larger version.
ID:	48277   Click image for larger version.
ID:	48282   Click image for larger version.
ID:	48281   Click image for larger version.
ID:	48279   Click image for larger version.
ID:	48280   Click image for larger version.
    Datsun 240K
    Turboed L24, Megasquirt II, EDIS
    Current project
  2. #2
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    I did a little more last night,
    made my first flare ( brake line flare ), what a mess that was, so off to youtube to see how it was done,
    now I'm a expert.
  3. #3
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Hi,
    Another beautiful day, so good weather to finish my brake upgrade.
    Originally I left the 3/4 Master cylinder on, Brake worked fine, soft pedal, but a lot of travel, probably 3/4 way to the floor,
    So I went to put a 7/8 master cylinder on, of course this would not fit the brake booster, the 4 bolts have a different spacing.
    So I compared this to my part part '73 four door, different brake booster ( my 4 door was a little larger than what's on the 2 door),
    So I swap this out from the 4 door, fitted the 7/8 master cylinder, brakes work really good, pedal still soft, but only travels about a inch or so,
    So, can someone tell me , which is the original brake booster for a '73 model, from these pictures ?
    Not sure if it matters, but the 4 door has the 250mm rotors, and the 2 door has the 270 mm rotors
    Nigel
ID:	48314   Click image for larger version.
ID:	48319   Click image for larger version.
ID:	48318   Click image for larger version.
ID:	48317   Click image for larger version.
ID:	48315   Click image for larger version.
ID:	48320   Click image for larger version.
ID:	48322   Click image for larger version.
ID:	48323   Click image for larger version.
    Datsun 240K
    Current project
  4. #4
    RB addict N1GTR's Avatar
    Member ID
    CZCC-18027
    Join Date
    Oct 2008
    Location
    Sydney, NSW
    Posts
    62
    Default
    Would it be different between 73 and 74? I have a 74 and can check when at the car next for you
  5. #5
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    I don't know, but my other 2 (1977) have a larger brake booster again.
  6. #6
    ケンメリ 240k Style's Avatar
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    37
    Posts
    533
    Default
    Found the thread Noddle thanks mate
    Adam
    1975 HGC110 "YONMERI" Datsun 240K GL Sedan
    1976 KHGC110 "KENMERI" Datsun 240K GL Coupe
    1978 MGC210 "Japan" Datsun 240K sedan (sold)
    http://japanesenostalgiccar.com/foru...hp?f=7&t=24596
    Contact Jason at info@jdmfactory.com.au for all your YJ / JDM needs !!
  7. #7
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Theory of combos for S30 but it matches Nigel's empirical observations above:
    http://www.classiczcars.com/forums/w...o-changes.html
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  8. #8
    Registered User Torker Man's Avatar
    Member ID
    CZCC-23976
    Join Date
    Mar 2011
    Location
    Melbourne
    Age
    47
    Posts
    109
    Default
    Hi Noodle, what calipers are they, and what RDA discs are they, if you dont mind me asking?
    Adam
  9. #9
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Quote Originally Posted by Torker Man View Post
    Adam
    Sorry for the later reply,
    Calipers are Toyota S13WB ( 4 runner from memory, each caliper had, 4 x 45mm pistons )
    Rotors, were special order DBA425USL & DBA425USR ( they did not have the stud holes drilled / blank )
    Nigel
    Datsun 240K
    Current project
  10. #10
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Quote Originally Posted by Noddle View Post
    Nigel
    They are actually from a '91 Toyota Surf, ( found my ebay bid )
    Datsun 240K
    Current project
  11. #11
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    37
    Posts
    533
    Adam
Thread Information
Users Browsing this Thread
Similar Threads
  1. anyone for a brake upgrade?
    By khughes in forum Wheels, Tires, Brakes (240K)
    Last Post: 04-21-2010, 04:53 PM
  2. Replies: 4
    Last Post: 12-13-2009, 05:32 PM
  3. Front Brake upgrade Spacers for $70
    By logan1 in forum Wheels, Tires and Brakes (S30)
    Last Post: 10-13-2009, 12:57 AM
  4. Replies: 5
    Last Post: 07-30-2009, 05:39 AM
  5. WTB Toyota brake calipers for a Datsun 240K / Magna brake upgrade.
    By Noddle in forum Wheels, Tires, Brakes (240K)
    Last Post: 05-04-2007, 06:49 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
