Results 1 to 10 of 10
Thread: Identify these SUs for me please
  1. #1
    Registered User
    Member ID
    CZCC-20806
    Join Date
    Jan 2010
    Location
    Denver
    Posts
    65
    Default Identify these SUs for me please
    I was always under the assumption these were from a 72, but I am unsure if the previous owner changed them out or not. I cant really make out the stamping on the side it looks like it says HJG46 W-F3 but I am kind of guessing, especially on the W-F3 part. It has a clicky type adjuster on the bottom and not the turn style knob. 3 screw on top and the round throat.
    Click image for larger version.
ID:	49951Click image for larger version.
ID:	49952Click image for larger version.
    1971 240z, L28 with SUs.
  2. #2
    Registered User 5thhorsemann's Avatar
    Member ID
    CZCC-22854
    Join Date
    Nov 2010
    Location
    maryland
    Age
    55
    Posts
    1,398
    Default
    72 3 screw SU. Wade, have you checked the damper oil, you mentioned that the car was running funky and blowing smoke after adjusting your needles. could be that youre burning damper oil.
  3. #3
    Registered User
    Member ID
    CZCC-20806
    Join Date
    Jan 2010
    Location
    Denver
    Posts
    65
    Default
    Ok cool, this style of adjuster only has 5 slots and is not the knob style I usually see write ups about on adjusting, I take it it is the same concept just less fine tuning available. As in most info says turn knob in all the way clockwise and then turn it out so many turns.
    I should of just put this on the other thread I got going but just needed to confirm the carbs.
  4. #4
    Member ID
    CZCC-22854
    Join Date
    Nov 2010
    Location
    maryland
    Age
    55
    Posts
    1,398
    Default
    I just looked at the knobs on my set of 72 SU's and it is different than yours, which leads me to believe that yours are an earlier generation. They are 3 screws, identical to mine in every other way, Iím sure someone will jump in and give the exact info on them.
Name:	pics mike 039.jpg
  5. #5
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    66
    Posts
    1,746
    Default
    Mixture knobs on my "late" 72 are cylindrical with straight knurls.
    Yours look like they would be easier to turn when you have your forearm bent in two places to get at the back one...
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  6. #6
    Registered User
    Member ID
    CZCC-20806
    Join Date
    Jan 2010
    Location
    Denver
    Posts
    65
    Default
    Oiluj, when you say cylindrical with straight knurls are you talking about the plastic black knob looking type? Im just trying to get an idea of when this style I got was used and figure if whether or not these ones I have were ever changed. 6/72 was the production date from the Z these carbs came from. This guy on ebay has the same style on his rebuild http://www.ebay.com/itm/Datsun-240Z-...item43abdfa744 (I sure wish I had the funds to just buy it!) and from what I have heard the 72's nozzles and adjusters are no longer available so I was thinking these adjusters actually came from the earlier series Z's.
  7. #7
    Member ID
    CZCC-22854
    Join Date
    Nov 2010
    Location
    maryland
    Age
    55
    Posts
    1,398
    Default
    The cylindrical knob looks kind of like a radio volume knob, made of metal, with bearings pressed into the side at 12 and 6 oclock.
  8. #8
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    Quote Originally Posted by Wade View Post
    That notched adjuster was the latest in the series and I'm sure was implemented to keep owners from doing wild and crazy adjustemments to the mixture.
    IF you need more adjustment than the notches will allow just bend that sprng clip out of the way and adjust to whee you need it and bend it back into the first available notch. Nozzles are standard to all 3 & 4 screw Hitachis and we have them.
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  9. #9
    Registered User
    Member ID
    CZCC-20806
    Join Date
    Jan 2010
    Location
    Denver
    Posts
    65
    Default
    Ok, sounds good, thanks for your guys responses.
  10. #10
    Registered User esmit208's Avatar
    Member ID
    CZCC-19498
    Join Date
    Jun 2009
    Location
    308 Palmetto Avenue Melbourne Florida 32901
    Age
    62
    Posts
    464
    Default
    I just sent a set of those to ZsOndaBrain (aka Dave Irwin) besides if Bruce doesn't know no one does. There is a thread in this forum addressing that type of SU.
    "HAPPINESS"....isn't just around the corner......"HAPPINESS"....is the CORNER"
Thread Information
Users Browsing this Thread
Similar Threads
  1. Can someone help identify?...
    By Willoughby Z in forum Fuel Injection (S30)
    Last Post: 02-09-2011, 03:45 PM
  2. Help me to identify this
    By bloxman in forum Electrical (S30)
    Last Post: 01-25-2008, 03:46 PM
  3. help me identify this
    By xtce in forum Interior (S30)
    Last Post: 02-21-2007, 05:31 PM
  4. Can you identify this?
    By 76Datsun280z in forum Help Me !!
    Last Post: 01-13-2007, 01:15 PM
  5. Can anybody identify these wheels?
    By JPTL in forum Wheels, Tires and Brakes (S30)
    Last Post: 12-19-2003, 02:20 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
