Results 1 to 2 of 2
Thread: Speedhut oil/temp senders & stock EFI control unit
  1. #1
    Registered User
    Member ID
    CZCC-25044
    Join Date
    Aug 2011
    Location
    MD
    Posts
    36
    Default Speedhut oil/temp senders & stock EFI control unit
    This is probably a DUMB question but....
    I'm replacing all my gauges with Speedhut gauges to include their oil pressure and coolant temp units. I see from the FSM that both of the stock sending units go to the EFI control unit. Also, the new units require the use of their sending units. So...
    1. Will the elimination of the stock sending units for oil and temp cause a problem with the fuel EFI control?
    2. If I use Speedhut's sending units, which must be of different current and/r resistance than stock, be OK?
    3. Do I need to keep the stock senders in place and ADD the new ones just for the gauges? If yes, does anyone have any recommendations on the best way to do so?
    Sorry for the multiple questions. I found many related threads but none touched on this issue. Thanks!!
  2. #2
    Registered User
    Member ID
    CZCC-25044
    Join Date
    Aug 2011
    Location
    MD
    Posts
    36
    Default
    I can't believe no one has any input on this. Guys (and gals) that have installed aftermarket gauges and senders, did you eliminate the stock senders or somehow just add the aftermarket ones?
    1977 280Z - Sold 10/1986
    1978 280Z - Current and forever
Thread Information
Users Browsing this Thread
Similar Threads
  1. Water Temp Sending Unit Installation
    By bartman in forum Misc (S30)
    Last Post: 06-29-2006, 02:06 PM
  2. H20 Temp sending unit help!
    By bart in forum Engine and Drivetrain (S30)
    Last Post: 06-17-2003, 06:58 AM
  3. Coolant Temp Sending unit 83 280 zx
    By Mike Hill in forum Help Me !!
    Last Post: 04-22-2003, 01:36 AM
  4. Coolant Temp Sending unit
    By Mike Hill in forum Electrical (S30)
    Last Post: 04-19-2003, 09:32 PM
  5. control unit
    By chevzee2 in forum Fuel Injection (S30)
    Last Post: 08-09-2002, 06:20 AM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
