Results 1 to 25 of 25
Thread: Wiring harness repair kit - eliminate your electrical gremlins! Rate Topic:
  1. #1
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default Wiring harness repair kit - eliminate your electrical gremlins! Rate Topic:
    I've managed to source connectors for the stock engine wiring harness for the early FI S30 and S130 cars. I'm just posting here to see if anyone else would be interested in a kit and I'll order in some extras. The kit will include nine EV1 connectors for the fuel injectors, cold start valve, idle air and thermal switch, a three pin connector for the TPS and the seven pin AFM connector. I'm redoing all the connectors on all my harnesses and I ordered in extra connectors for a few members on the forum who requested a kit. Price will be $50 shipped in US/Canada. There is well over $100 worth of connectors so this is a great deal. If you have a 280Z, 280ZX or engine swap EFI and you haven't replaced the 30+ year old connectors on your car yet you need this kit! A lot of the problems on the car have to do with corroded or loose connectors. Cleaning the male side of the plugs is possible on the AFM, injectors, TPS, etc however cleaning the female side on the connector is difficult and doesn't often last. The reason is that the male connector is easily accessable and are usually solid brass. These can be cleaned/polished to new condition. The connector side is plated and the disimilar metals cause corrosion and the plating is destroyed in the process. Cleaning the corrosion is difficult because they are physically difficult to access and with the plated material missing the base material will quickly corrode and the problems will come back.
    A lot of the problems associated with the idle and running of the car are associated with the AFM connector. Often the clip from the connector is missing causing poor a poor connection which can cause intermittant faults which are often difficult to track down. The replacement AFM connector includes the new body and clip as well as new pins to get rid of the many problems this connection causes.
    I would also highly recomend replacing the stock negative battery cable with a heavy cable to the starter and one to the chassis. I also recomend a ground cable from the chassis where the battery cable mounts to the ECU and from the ECU to the ground point for all the sensors on the manifold near the Idle air valve. Replace all the connectors with this kit and you have an excellent base for your electronic fuel injection system.
    Replacing your connectors isn't going to solve all your electrical problems but it will give you a good solid base and eliminate a lot of potential problems and prevent future problems.
    "Rachel" - 1972 Datsun 240Z
    "Kayla II" - 1983 Datsun 280ZX
    "Unnamed" - 1983 Datsun 280ZX Turbo
    "Unnamed" - 1993 Nissan 300ZX Convertible
    "Zathina" - 2009 Nissan 370Z 6MT PB Touring Sport
  2. #2
    Registered User jimbob_racing's Avatar
    Member ID
    CZCC-7584
    Join Date
    Dec 2004
    Age
    52
    Posts
    32
    Default
    I'm interested but what kind of tool do I need to crimp the new connectors on?
    Jim
    '75 280Z (good car)
    '77 280Z (parts car)
  3. #3
    Registered User grantf's Avatar
    Member ID
    CZCC-17660
    Join Date
    Aug 2008
    Location
    seattle
    Posts
    1,298
    Default
    me want!!! need. pm on its way. And you may not need to ship them, An excuse to take a motorcycle trip to Victoria!
  4. #4
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    All I need is the 7 pin and 3 pin connector. Will you sell only those two to me? I have already replaced the rest of them. Nice score though!
  5. #5
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    Quote Originally Posted by jimbob_racing View Post
    For these lugs, I prefer the crimpers like in the picture I attached. First, use long-nosed pliers to bend the tabs on the lugs in enough that they fit in the part of the crimpers where I drew the arrow. Then slowly squeeze the crimpers so the tabs curl into the wire.
    You can find crimpers like that at Fry's. They can also be found through vendors at Amazon.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  6. #6
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    Quote Originally Posted by SteveJ View Post
    Those will work. The die is the right shape but the crimpers I use have a set of six for the wire and a set of six for the insulated portion of the pin. I recomend crimping and hitting them with solder but just enough to bond to the pin and wire not a blob and not enough to run up the wire into the insulated portion.
    I can add a pig tail to the connectors for those who aren't comfortable soldering the wire to the pin
  7. #7
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    Ok I made a little video up to give you some pointers on repairing your wiring harness. I did the AFM which is the most complicated of the ones we'll be replacing. It's a little embarasing because I messed up the connector trying to keep the video time short but I left it in. It's a good reminder to make sure you've got everything in place before you solder or crimp your connector on. I do this sort of work all the time and I should know better - shows you what happens when you rush. Anyhow if you have any questions the video doesn't answer feel free to ask!
  8. #8
    Member ID
    CZCC-17660
    Join Date
    Aug 2008
    Location
    seattle
    Posts
    1,298
    Default
    really cool.
  9. #9
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    I'll make a video on how to wire in the pig tails and water proof those but it will be a little while before I can get to that. I'm getting everyone's orders ready to mail out as my number one priority.
  10. #10
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    *** Please note I've had to make some minor adjustments to the kit pricing unfortunatly. The kit will increase from $50 to $55 to cover Paypal fees and Air postage which cuts shipping time in half or less as well as insurance. In addition I've had a few requests for some other options with the kit. For those who would like a trackable insured shipment there is an additional $15 fee (and I believe shipping time is reduced to 4-6 days). If you don't feel comfortable soldering pin to wire I can add pigtails (a six inch piece of wire coming out of the connector) so you can solder wire to wire for an additional $10. The pig tails take about 45 minutes to do. These are professionaly fabricated (crimped and soldered) and populated into your connector ready to go. I highly recomend water proof heat shrink (heat shrink with a meltable inner jacket). I can supply it for $5 per kit (24 pieces) for as long as my current stock remains then I may need to adjust the price. You will only need the heat shrink if you are using pig tails and need to water proof your solder joints. You should be able to get water proof heat shrink as well at your local electronics supplier.
  11. #11
    Member ID
    CZCC-7584
    Join Date
    Dec 2004
    Age
    52
    Posts
    32
    Default
    Have you ever thought of having people send you their harness and you do all the work and ship it back to them? Might be worthwhile to some people.
    Jim
    '75 280Z (good car)
  12. #12
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    I can definately do harness repair. I would think shipping back and forth would be expensive though. Right now I'm making a custom wiring harness for S130 for plug and play MegaSquirt setup then I'll be developing an S30 kit as well.
  13. #13
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    Kurk, the kit looks awesome! I just recieved mine in the mail today. Took less than a week to get. Can't wait to install them. Will post results when done.
    Thanks.
    Bob
  14. #14
    Registered User mjr45's Avatar
    Member ID
    CZCC-21301
    Join Date
    Mar 2010
    Location
    Divide, CO
    Posts
    572
    Default
    Kurk, great product works like a champ, keep up the good work. Thanx
    Mike
  15. #15
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    I got an entire engine wiring harness from a place called Vines Auto in AL. They recycle BMWs there. For about $30, I got enough connectors to do two engines.
    www.vinesauto.com
    Drive Responsibly.
    enjoy classic Rock music.
  16. #16
    Member ID
    CZCC-7584
    Join Date
    Dec 2004
    Age
    52
    Posts
    32
    Default
    Quote Originally Posted by FricFrac View Post
    I'd be interested if you make a MegaSquirt pnp harness to put a turbo L28 into my '75 280Z.
    Jim
    '75 280Z (good car)
  17. #17
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    I'm pretty close to a finished product with the S130 harness. I'll get to the S30 harness when I get a chance and keep you guys posted.
    For those waiting on backordered kits I have the S30/S130 kits in and I'll be doing an Z31 kit as well for those of you who have the Z31 ECU swap (or a Z31 lol).
  18. #18
    '73 HLS30-154951 Quinn'Z's Avatar
    Member ID
    CZCC-26191
    Join Date
    Jan 2012
    Location
    waimea hawaii
    Age
    45
    Posts
    56
    Default
    I would totally be in in this if it worked on my 73.
  19. #19
    Registered User
    Member ID
    CZCC-19940
    Join Date
    Aug 2009
    Location
    Victoria, BC
    Age
    48
    Posts
    53
    Default
    Just got some new connector kits in. I would like to donate the proceeds from the next two kits sold on this forum (minus $10 shipping) to World Vision - a charity I strongly believe in and have supported since I was a little kid. I would encourage you to consider supporting them as well and/or researching charitable organizations of your choice to make sure the majority of your donations go to those in need (Charity Navigator!).
  20. #20
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Durango, Colorado, United States
    Posts
    692
    Default
    Thank you so much for sourcing these.
  21. #21
    Registered User
    Member ID
    CZCC-28345
    Join Date
    Oct 2012
    Location
    Missouri
    Posts
    1
    Default
    Would like to buy a set for my 78 280z. How do I contact you?
  22. #22
    Registered User
    Member ID
    CZCC-19200
    Join Date
    Apr 2009
    Location
    Mesa, AZ
    Posts
    23
    Default
    I'd like to buy a set for my 78 280z.
  23. #23
    Registered User
    Member ID
    CZCC-19200
    Join Date
    Apr 2009
    Location
    Mesa, AZ
    Posts
    23
    Default
    Scratch that. I already got some.
  24. #24
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    You've already got one?
    2/74 260Z
  25. #25
    Registered User
    Member ID
    CZCC-27748
    Join Date
    Jul 2012
    Location
    Illinois
    Posts
    8
    Default
    Is this kit still available?
Thread Information
Users Browsing this Thread
Similar Threads
  1. Electrical Gremlins: Ignition and Temp Gauge
    By jfa.series1 in forum Help Me !!
    Last Post: 09-05-2011, 09:06 PM
  2. Replies: 8
    Last Post: 07-23-2011, 04:54 AM
  3. Off topic - Harness mounting in an S2000
    By Marty Rogan in forum Open Racing Discussions
    Last Post: 02-09-2007, 09:37 AM
  4. Electrical Gremlins
    By daveinc in forum Electrical (S30)
    Last Post: 08-25-2005, 07:52 PM
  5. 1978 280Z electrical gremlins
    By mdbrandy in forum Electrical (S30)
    Last Post: 01-23-2004, 05:41 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
