Results 1 to 5 of 5
Thread: my 280zx
  1. #1
    Registered User
    Member ID
    CZCC-26062
    Join Date
    Jan 2012
    Location
    waynesville NC USA
    Age
    30
    Posts
    40
    Default my 280zx
    ok my zx has a lot or rust at the top of the windshield on the body all the way from the left side to the right side there r a few spots where it has rusted through how can i fix this and also how do i pull the chrome trim off the car to pull the windshield
  2. #2
    HS130-150591 4/79 zbane's Avatar
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    48
    Posts
    1,671
    Default
    Removing the trim from the upper and lower edges of the windshield is fairly easy; the vertical portions are less so.
    To pop the upper SS trim, grab the trim near the center of the car, and pry it up-gently, but with some force. It's held on mainly by a few plastic clips, though there is certainly going to be a nice accumulation of crud in there acting as glue...and you may find some silicon (or other adhesive) as well. You will hear and feel it come loose, then it's just a matter of going from one side to the other. Once it's separated from the upper line of the car, you can wiggle it out from the vertical wings.
    Same procedure for the bottom trim, just watch out for the wipers.
    To remove the vertical trim, you'll need to open the doors, carefully remove the weatherstripping, and remove the screws on the A pillar. Once the screws are out, you'll be able to remove the vertical pieces.
    I pulled this link (lot's of pictures) from a similar thread.
    http://www.zcar.com/70-83_tech_discu...tml#msg2713861
    David
    _____________________________________
    HS130-150591, April, 1979-280zx
    2001 Infiniti I 30
  3. #3
    Registered User
    Member ID
    CZCC-26062
    Join Date
    Jan 2012
    Location
    waynesville NC USA
    Age
    30
    Posts
    40
    Default
    thank u buddy that helped a lot i like the pics thats pretty much what mine looks like but all the way across the top but ill deff be putting that to good use thanks a lot now so u know where i can get a windshield for my car mine is cracked and when i go to take it out it will just crack the rest of the way
  4. #4
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    48
    Posts
    1,671
    Default
    a quick search online found a place called windshieldstogo with replacements at $125. Before going the online route, I'd call around to the shops from Waynesville to Asheville... as well as checking the junkyards in the Asheville area.
    David
    2001 Infiniti I 30
  5. #5
    Registered User
    Member ID
    CZCC-26062
    Join Date
    Jan 2012
    Location
    waynesville NC USA
    Age
    30
    Posts
    40
    Default
    yeah thats not to bad i think there is one in a junk yard round here or well if it ant been crushed yet the guy i got the car off of said there was one
Thread Information
Users Browsing this Thread
Similar Threads
  1. new 280zx
    By mike260z in forum Open S130 ZX Discussions
    Last Post: 12-27-2011, 11:39 PM
  2. Can '79 280ZX halfshaft fit on 240Z? the 280ZX has R180 3.36 5spd..
    By jbuenviaje in forum Open S30 Z Discussions
    Last Post: 02-02-2010, 01:31 PM
  3. 280zx needs more HP
    By soldier_boy1863 in forum Help Me !!
    Last Post: 12-06-2006, 03:34 PM
  4. 82 280zx bumpers on a 79 280zx?
    By s14280zx in forum Body and Paint (S30)
    Last Post: 06-10-2006, 03:45 PM
  5. 280zx
    By rogue_squirrel in forum Open Discussions
    Last Post: 03-03-2003, 03:06 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
