Results 1 to 12 of 12
Thread: Properly Removing Interior Clips
  1. #1
    Registered User Hardway's Avatar
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default Properly Removing Interior Clips
    This may sound like a dumb question. Is there any way to remove the clips found in our cars that have the plastic stick/pin in the middle and not lose the pin? Removing it seems rather obvious, use a small punch to push the pin through and pull the clip out. However one is left to find the pin as it falls out and usually disappears forever. I am tempted to replace all of mine with the small nail head style clips, that way you pull the pin up and remove the clip. Any guidance here is greatly appreciated.
    08/1970 240z Series-1 #8011 - Silver, black int., 2.4L I-6, 5spd, 90% restored.
    06/1973 VW Karmann Ghia - Black convertible, 4spd, 1600cc air-cooled engine.
    11/2013 Scion FR-S - Silver, 6spd, a car with the soul of a Z for the modern times.
    Restoration thread of my old '72 240z -> http://www.classiczcars.com/forums/o...1972-240z.html
  2. #2
    Registered User
    Member ID
    CZCC-15144
    Join Date
    Sep 2007
    Location
    Murrells Inlet, South Carolina
    Age
    64
    Posts
    122
    Default
    Sorry to say the only way is to push the pin in and remove the plug. You can get lucky and find a few of the pins but not all. I just changed my panels and tried to find the pins but for some reason the car just didn't want to let some go of them and hid them forever. You can buy the pins from many places and the new ones seem to hold better than the ones I tried to reuse.
    They run about 1.00 each. I bought mine from MSA.
    Mike
  3. #3
    Registered User ZCurves's Avatar
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    56
    Posts
    1,052
    Default
    I do not believe they were intended to be reused. I have hunted many a pin as you have described and only missed a few. Back in the day, I got good enough to judge how far to push the pin in so it wouldn't drop out. I think it would be slick to have a little tool that on one end was long enough to push the pin in just so - then on the other end had a claw (like a hammer) to remove the rivet without damaging it. Seriously though, the rivets are relatively cheap and you should not have to disturb them very often - just get youself a couple of bags of spares off eBay. I like your idea of the nail style clips, I use a GM style from DORMAN for the rear finishers that hold the tail lamps in.
    Andrew (ZCurves)
    1978 Coupe - HLS30-440105
    Spring, Texas USA
    pro deo et patria
    My Albumz
  4. #4
    No more body roll! SteveJ's Avatar
    Member ID
    CZCC-5413
    Join Date
    Dec 2003
    Location
    Gainesville, GA
    Age
    54
    Posts
    3,651
    Default
    There is a thread floating around here about the panel rivets/pins/whatever they are called for a Ford. I bought a box of 50 on eBay for less than what it cost for 10 Datsun rivets. The only problem was that I needed to ream out the holes slightly for the rivets. It was worth the extra effort, though.
    Here's the eBay link.
    73 240Z
    74 260Z
    Blue's collection of tech tips - A great place to look for answers
    XenonS30 -The cheap source for FSMs
    Georgia Z Club
    Fiddling with Z Cars - Z car tips & tricks and pictures of my car-loving life.
    Steve's CARtography - Just car pictures.
  5. #5
    Registered User psdenno's Avatar
    Member ID
    CZCC-14231
    Join Date
    Apr 2007
    Location
    SoCal Desert
    Age
    73
    Posts
    1,091
    Default
    Those pins are like socks in a clothes dryer - some just disappear forever. I replaced my missing ones with Cotter pins of appropriate size in places where they didn't show. The "eye" head of the small Cotter pin was easy to grab and pull out of the rivet on subsequent removals.
    Dennis
    1971 240Z - Original Owner
    2010 Infiniti G37 Convertible
  6. #6
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    Thanks for the info guys and the link SteveJ. I will continue to investigate my options but all of this is good to know.
    In regards to the clothes dryer eating socks, my uncle always says, how do you know you did not gain one? :0)
  7. #7
    Registered User
    Member ID
    CZCC-25044
    Join Date
    Aug 2011
    Location
    MD
    Posts
    36
    Default
    SteveJ, thanks for the link. I just jumped on a set!
    1977 280Z - Sold 10/1986
    1978 280Z - Current and forever
  8. #8
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    56
    Posts
    1,052
    Default
    Quote Originally Posted by psdenno View Post
    Dennis
    What a fantastic idea! You could even paint the cotter black. Nice.
    Andrew (ZCurves)
    Spring, Texas USA
    pro deo et patria
    My Albumz
  9. #9
    Member ID
    CZCC-14231
    Join Date
    Apr 2007
    Location
    SoCal Desert
    Age
    73
    Posts
    1,091
    Default
    Quote Originally Posted by ZCurves View Post
    Thanks. At the time I came up with that 35 years ago, I didn't have a very large budget for maintaining the Z. A low bank balance is often the mother of invention. Didn't think of painting them black - good idea!
    Dennis
  10. #10
    Supporting Member EScanlon's Avatar
    Member ID
    CZCC-1490
    Join Date
    Dec 2001
    Location
    Vancouver, WA
    Age
    64
    Posts
    4,874
    71 240 920 Gold
    72 240 Orange
    73 240 Red
    67 1600 Sports Roadster Spicy Orange Mica
    68 2000 Sports Roadster Red
  11. #11
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    56
    Posts
    1,052
    Default
    Quote Originally Posted by EScanlon View Post
    EScanlon - You get the Awesome award for best the "Two for One" post! I am impressed that you pulled a 10 year old post out of your hat like that!
    Andrew (ZCurves)
    Spring, Texas USA
    pro deo et patria
    My Albumz
  12. #12
    Registered User doradox's Avatar
    Member ID
    CZCC-14809
    Join Date
    Aug 2007
    Location
    Colfax, IN
    Posts
    708
    Default
    You can purchase black plastic rod from McMaster Carr and make your own pins for next to nothing.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Wont run properly
    By comotion in forum Help Me !!
    Last Post: 10-03-2011, 06:23 PM
  2. Removing interior panel
    By Pomorza in forum Interior (S30)
    Last Post: 05-13-2010, 06:45 PM
  3. Removing Dash and Interior for Paint
    By EScanlon in forum Tech Pubs and HowTo
    Last Post: 10-14-2009, 06:37 PM
  4. Removing Overspray From Interior Plastic/Panels
    By lm71z in forum Interior (S30)
    Last Post: 03-10-2009, 01:34 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
