Results 1 to 10 of 10
Thread: PO did a number on the carpet. How do I fix?
  1. #1
    Registered User hall.nathan89's Avatar
    Member ID
    CZCC-26424
    Join Date
    Feb 2012
    Location
    Gilbert, AZ
    Posts
    47
    Default PO did a number on the carpet. How do I fix?
    The previous owner of my '83 replaced the carpet, and it looks a little funny. The carpet itself looks nice enough, but it slides around and it now receding from the area where it should be tucked under the center console.
    I'm fixing my mirror switches today, so I'll have the center console torn apart anyways and my question is, what do I put under the carpet to get it to stay put?
    The only problem I can't fix is the one I'm having at the time
    1981 280ZX 2+2 (Determined to be a lost cause; now my parts car)
    1983 280ZX (RIP; lost to a careless driver)
    1983 280ZX (purchased courtesy of the insurance company of a careless driver)
    1976 280Z (currently being gutted and turned into a racecar)
  2. #2
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    76
    Posts
    1,334
    Default
    You can use spray adhesive for a semi-permanent fix. Or use some drawer liner rubber betwixt the carpet/backing and floor. That might work as well.
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  3. #3
    Member ID
    CZCC-26424
    Join Date
    Feb 2012
    Location
    Gilbert, AZ
    Posts
    47
    Default
    Spray adhesive! What a great idea! I've even got a can of 3M 90 sitting right here... Thanks!
  4. #4
    HS130-150591 4/79 zbane's Avatar
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    48
    Posts
    1,671
    Default
    I don't know if this was original to my 79 or an add-on improvisation by the PO, but I found a few strips of heavy duty velcro going up and over the trans tunnel, connecting the driver and passenger side.
    David
    _____________________________________
    HS130-150591, April, 1979-280zx
    2001 Infiniti I 30
  5. #5
    Member ID
    CZCC-26424
    Join Date
    Feb 2012
    Location
    Gilbert, AZ
    Posts
    47
    Default
    I thought about doing velcro, but I know that area gets hot and I was concerned the the adhesive might melt. Have you had any problems with that?
  6. #6
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    48
    Posts
    1,671
    Default
    No issues whatsoever, though the velcro is mainly attached at the upper edge of the carpet, and goes across the tunnel to attach to the other side. Works well, and should it ever need to be replace, shouldn't be a difficult task to tend to. I do like the idea of the spray adhesive, but would be afraid of cooking it-thus making it a more permanent thing.
    David
    2001 Infiniti I 30
  7. #7
    Member ID
    CZCC-26424
    Join Date
    Feb 2012
    Location
    Gilbert, AZ
    Posts
    47
    Default
    It probably will cook it, but I have access to lots of chemicals (through my work) that would melt the adhesive even in its cooked state. I like the idea of it being connected to the other side. Is it supposed to be that way originally? That would help solve the problem on both sides and prevent it from happening again.
  8. #8
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    48
    Posts
    1,671
    Default
    I don't know if the velcro was original or not, nor do I have any photos with me of where it attaches... I'll take some after work tonight and post them tomorrow for reference.
    David
    2001 Infiniti I 30
  9. #9
    Registered User black gold man's Avatar
    Member ID
    CZCC-22534
    Join Date
    Sep 2010
    Location
    Detroit, Michigan, United States
    Age
    59
    Posts
    821
    Default
    Spray adhesive! Yes but were? I just removed the carpet in my 78 only 50,000 miles.
    the carpet is in great cond. my carpet was glued to the pad in the heel area of the floor pans.
    Use heavy glue in that area and the carpet wont move.
  10. #10
    Member ID
    CZCC-11908
    Join Date
    Jun 2006
    Location
    Cashiers, NC
    Age
    48
    Posts
    1,671
    Default
    Just so happened that I had the drivers side carpet loose, so here are a few pics to show the velcro.
    It appears to me that this was indeed original, as it's stitched quite well. There are two velcro tabs-the forward part straps across the area underneath the center console (holding radio), the rearward tab goes under the center armrest. Also, there were several strips of heavy duty tape holding the carpet to the floors-some of those strips, upon removal of the carpet, stayed with the carpet/padding (shown in photo), others were more attached to the car and chose to stay there (with some of the padding attached). No pics of that, as I cleaned that up some time back (when I recolored the carpets).
    Driver side velcro has the hook component, passenger side has the loop/fuzzy part.
    Passenger side has longer straps of velcro to go across the tran tunnel, as what you can see in these pics clearly won't bridge the gap.
    From what I gather from your posts, your carpet is far from original, and therefor not molded/fitted. If I were in your situation, I'd get the heavy duty velcro with adhesive backing, and apply several strips (leaving the outer tape cover intact until you've got the carpet just where you want it.
    I'd put a strip up on the firewall-an upper anchor; one strip on the outer edge, where the floor goes vertical to meet the door; one strip along the upper edge of the transmission tunnel; and one close to the seat mount.
    Once you've gotten the carpet just right, remove the tape-exposing the sticky, then lay the carpet down down on it-apply pressure, and repeat elsewhere...
    As to connecting the two sides together, I'm sure you could figure out a reasonable way to do that too.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	52678   Click image for larger version.
ID:	52679   Click image for larger version.
ID:	52680   Click image for larger version.
    David
    2001 Infiniti I 30
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 3
    Last Post: 04-26-2011, 08:32 AM
  2. What to use for under carpet?
    By KAL7467 in forum Body and Paint (S30)
    Last Post: 11-22-2010, 08:11 AM
  3. 240 carpet
    By germanZfan in forum Interior (S30)
    Last Post: 05-22-2005, 08:45 AM
  4. All Z Carpet Kit
    By mrdatto in forum Australia and New Zealand
    Last Post: 11-28-2004, 11:34 PM
  5. Carpet: Is it possible?
    By Mateo05 in forum Interior (S30)
    Last Post: 05-05-2004, 06:00 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
