You'll need to be more specific, for your own testing and for describing what's going on. You said the harness shows juice, but what does that mean? A couple of sentences before you said "no juice". If you're using a jumper to apply power to various spots, that's not good (as you've found with the blown link).
Are you sure the ECU was heating up? It's rather big and the components would have to generate a lot of heat to heat up the whole thing. Maybe you meant coil or some other component? No offense, but it looks like you're in unfamiliar territory and could do some damage while you're learning.
If the battery is hooked up correctly (don't trust the colors of the cables, verify that negative goes to ground and positive to the starter lug) and the fusible links are intact, you should at least get dome lights, radio, heater fan or something. The headlight dimmer switch is notorious for killing the headlights so "no headlights" after two years doesn't tell much.
Good luck and be careful with that jumper wire.
Bookmarks
