Results 1 to 10 of 10
Thread: Tachometer Swap : 280z into a 240z series 1 housing
  1. #1
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default Tachometer Swap : 280z into a 240z Series 1 Housing
    Comparison Photos:
    280z on left 240z on right
    Click image for larger version.
Name:	001 280z tach face.jpg
ID:	56087Click image for larger version.
Name:	002 240ztach face.jpg
    Front (note 280z screw hole)
Name:	003 280z l 240z r.jpg
    Bottom
Name:	004 280zl 240zr.jpg
    Top
Name:	005 280zl 240zr.jpg
    Back
Name:	007 280z back.jpg
ID:	56093 Click image for larger version.
Name:	006 240z back.jpg
    Back Harness (Note white current loop on 240z and red voltage pickup wire on 280z)
Name:	008 280z power connections.jpg
    280z back (Green is 12V and black is ground)
Name:	009 280z connections.jpg
ID:	56095Click image for larger version.
Name:	010 240z connections.jpg
    280z and 240z connector comparison. (Note the different locations for Gnd and +12V. It is neat to see the location for the tach signal input is in the same part of the can...clever engineering and evolution).
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  2. #2
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default 280z Tach Disassembly
    Disassembling the 280z donor tach
Name:	011 280z bezel removed.jpg
    Remove bezel, lens and trim pieces
Name:	013 280zinner face.jpg
    Front face
Name:	012 280zneedle.jpg
    Angle showing needle
Name:	015 280z needle.jpg
    Carefully pry off needle.
Name:	016 280z faceplate screws removed.jpg
    Remove two black screws holding face plate.
Name:	017 280z guts.jpg
    280z "can" with tachometer workings fastened to bottom.
Name:	014 280z circuit screws loose.jpg
    Remove two screws in back and press on the brass studs to "push" workings out. There is a double sided foam tape also holding the workings so you may need to apply heat to soften it. Prying up by starting at the sensor post seemed to work best for me.
Name:	018 280z workings.jpg
    Removed.
Name:	019 280z housing.jpg
    Empty 280z can.
  3. #3
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default Date Codes on Tachometers
    Date code stamps on the tachs:
Name:	021 240z date Nov 23 1970.jpg
ID:	56106 Click image for larger version.
Name:	022 280z date May 24 1977.jpg
    240z: 70-11-23 280z: 24-5-77
  4. #4
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default Disassembling the 240z Tach
    Disassembling 240z Tach:
Name:	020 240z induction removal.jpg
    Remove pick-up current induction loop.
Name:	023 240z connectors removed.jpg
    Connectors removed.
Name:	024 240z bezel.jpg
    Remove bezel and lens and spacer.
Name:	025 240zinner face.jpg
    240z face.
Name:	026 240z needle.jpg
    Side view of needle.
Name:	029 240z guts.jpg
    Workings in the can. (note the white turn indicator hoods)
Name:	030 240z inside.jpg
    Workings removed.
  5. #5
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default Transplanting 280z guts into 240z tach
    The Swap:
Name:	031 280z guts in 240z can.jpg
    280z "guts" in 240z tachometer.
Name:	032 back of 240z with 280z guts.jpg
    Align the posts on the back side. (match the holes to the white foam indentations)
Name:	033 screws.jpg
    The securing screws are different. Use the 280z ones.
Name:	034 secured.jpg
    Secured.
Name:	035 connections.jpg
    Different connectors. Use the 280z. (Burnish the brass fittings)
Name:	036 280z connector on 240z.jpg
    Installation detail. Star washers lock connector.
Name:	037 face plate installed.jpg
    Install face plate.
Name:	038 240z wires connected.jpg
    Install 240z harness to connector. (Black is ground)
  6. #6
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Button-Up
Name:	039 Bezel dirt.jpg
    240z "sand" inside the bezel. I think it may be from the paint inside.
Name:	040 lens dirt.jpg
    "Gravity grime" and dirt on the lens...especially at the bottom. (wash with soapy water and polish with plastic polish)
Name:	041 needle installed.jpg
    Installed front needle.
    I used goop to secure it. I read a post saying NOT TO USE CRAZY GLUE.
Name:	043 needle.jpg
    Installed needle.
Name:	044 installed bezel.jpg
    Install the side screws.
Name:	045 finished front.jpg
    Done!
Name:	046 finished back.jpg
    Back of completed tach showing white loop, power connector, and red sense wire that will be soldered to a longer one that will be routed to the coil -neg terminal.
Name:	047 280z dirt.jpg
    Closing photo: Very dirty lens from 280z tach.
  7. #7
    Registered User Ptero's Avatar
    Member ID
    CZCC-20606
    Join Date
    Dec 2009
    Location
    Canada
    Posts
    94
    Default
    '73 HLS30 143820
  8. #8
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default Removing Tach Needle
    Follow up.
    Tach works great.
    Here is a clever use of spoons I found on the net:
    How to remove the needle from a tachometer.
  9. #9
    Registered User
    Member ID
    CZCC-30885
    Join Date
    Oct 2014
    Location
    Columbia, SC
    Posts
    2
    Default
    Awesome discussion. I have a '73 that I put together from parts. It runs great but I too am trying to get the tach working. I upgraded to the Pertronix ignition. From the discussion above I understand where to connect a gnd and the +12volt wire, but I am confused as to how to hook up the "current loop" I bought a spare tach, was told it was working and was planning to "test wire" it under the hood before pulling the old one out of the dash. One side of the current loop has a piece of red tape and the other side has a piece of black tape. Where do I connect these two wire?
  10. #10
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Hi Burto,
    The above really is for wiring a 280z. There are only 3 connections (Ground, +12V and the tach. signal from -neg coil)
    This may help with your '73 tach:
    https://www.google.ca/search?q=site%...m=122&ie=UTF-8
Thread Information
Users Browsing this Thread
Similar Threads
  1. 280Z seatbelts into a series one 240Z?
    By zcar70 in forum Interior (S30)
    Last Post: 03-13-2010, 08:29 AM
  2. 240Z/260Z/280Z auto to 4/5 speed swap
    By Arne in forum Tech Pubs and HowTo
    Last Post: 08-29-2008, 04:05 PM
  3. 280Z housing on a 240Z :(
    By yoogener in forum Suspension and Steering (S30)
    Last Post: 02-12-2005, 08:04 PM
  4. series II to series I console swap
    By Rags in forum Body and Paint (S30)
    Last Post: 05-15-2002, 06:00 PM
  5. 240z to 280z? tranny swap
    By greenz in forum Suspension and Steering (S30)
    Last Post: 01-20-2002, 01:02 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
