Results 1 to 12 of 12
Thread: Who Makes the Best Strut Bar
  1. #1
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default Who Makes the Best Strut Bar
    I'm looking to add a Strut Bar to my car and looking for help the best one made for a 78.
  2. #2
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    Best is really relative. Things to look for..
    How easy is removal (for valve adjustments and the like)
    how much clearance does it provide for your wires and accessories
    Other than that, you are putting a straight tube in tension. They will all be strong enough to do the job in tension. So strength is about equal to all of them. So get what is easy to work around and what looks good.
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  3. #3
    '72 240Z(G) 3.2L
    Member ID
    CZCC-7328
    Join Date
    Nov 2004
    Location
    MA
    Age
    70
    Posts
    1,074
    Default
    A triangular set-up is better than a straight bar but adds some complexity to installation and removal. Have someone build you one. For the front go from the struts mounts back to the firewall and for the rear add an angles piece to one side of the strut tower up to the bar itself. A roll bar would do all this instead.
    if a little knowledge can make you dangerous, I'm a little dangerous
  4. #4
    Registered User d240zx2's Avatar
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    76
    Posts
    1,334
    Default
    I had a hood clearance issue with the strut bar from MSA.
    First & Third owner of HLS30-00721
    B. 01/70 D. 03/12
    New owner of HLS30-15653
    B. 12/70 D.
    Frank in Houston, Texas
  5. #5
    Registered User
    Member ID
    CZCC-26007
    Join Date
    Dec 2011
    Location
    Houston
    Posts
    45
    Default
    Frank this is the one you had clearance issue with.
    http://www.thezstore.com/page/TZS/PROD/PSDC03/23-4201
  6. #6
    Member ID
    CZCC-15137
    Join Date
    Sep 2007
    Location
    Houston, Texas
    Age
    76
    Posts
    1,334
    Default
    Yep, sure is.
    B. 01/70 D. 03/12
    B. 12/70 D.
  7. #7
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    67
    Posts
    1,746
    Default
    I have the same bar and it fits fine.
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  8. #8
    Registered User surfer.tech's Avatar
    Member ID
    CZCC-20365
    Join Date
    Nov 2009
    Location
    calgary
    Posts
    102
    Default
    Kameari carbon bar. Or even the RS Start bar. Be prepared to spend!
    Cusco makes one. Great price and looks good.
    HLS30137283
  9. #9
    Crumudgeon
    Member ID
    CZCC-798
    Join Date
    Apr 2000
    Location
    La Habra, CA USA
    Age
    61
    Posts
    1,374
    Default
    This one was built after some finite element analysis of the S30 chassis. Allowed an increase in front spring rate of up to 100 lb. in.
    Click image for larger version.
  10. #10
    Registered User steve91tt's Avatar
    Member ID
    CZCC-20531
    Join Date
    Dec 2009
    Location
    Houston
    Posts
    802
    Default
    John, Is the back of the firewall tied into the knee bar of the cage on the other side of the strut bars in your photo above?
    Steve
    1973 240Z (daily driver)
    1971 240Z (track car)
  11. #11
    Crumudgeon
    Member ID
    CZCC-798
    Join Date
    Apr 2000
    Location
    La Habra, CA USA
    Age
    61
    Posts
    1,374
    Default
    No. Not needed for my application. The cowl box is a triangle with the base of the triangle at the firewall. The center mount plate spans the base of that triangle. It very strong right there.
  12. #12
    Supporting Member pbarcher's Avatar
    Member ID
    CZCC-18713
    Join Date
    Feb 2009
    Location
    Fairfax, VA
    Age
    74
    Posts
    116
    Default
    I recently installed a Cusco bar that I bought from Amazon for just under $200. I was also concerned about fitment, but no problems at all. Looks great and actually makes a difference even in moderate driving.
    Peter Barcher
    Original Owner of HLS30-161241 - Mfg. 5/73
    Silver 1973 240Z
Thread Information
Users Browsing this Thread
Similar Threads
  1. Who Still Makes 215/60/R14 tires?
    By WingZr0 in forum Wheels, Tires and Brakes (S30)
    Last Post: 12-19-2007, 09:15 PM
  2. Front strut mounting bearing & rear strut mounting spacer
    By Miles in forum Suspension and Steering (S30)
    Last Post: 09-20-2005, 04:57 PM
  3. Who makes this mirror?
    By TomoHawk in forum Body and Paint (S30)
    Last Post: 06-03-2005, 04:08 PM
  4. Owning a Z makes me...
    By gema in forum Open Discussions
    Last Post: 04-18-2004, 06:51 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
