Results 1 to 44 of 44
Thread: Sound deadening and heat shielding materials
  1. #1
    Administrator bpilati's Avatar
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Question Sound deadening and heat shielding materials
    I'd like to know what everyone that has removed the original materials off the floor and deck areas are using. I'm aware of several products:
    Dynamat
    LizardSkin (spray on)
    SecondSkin
    Hushmat
    Ensolite
    BXT II RAAMmat
    Eastwood Thermo-coustic (poorly rated)
    Noxudol 3101
    B-Quiet
    I'm sure there are many more. There are few things I'd like to know about your experience and knowledge of these products. Cost, performance, application issues, flammability are among the most important to me. Please slay me with your knowledge, recommendations and evaluations.
    Bryan Pilati
    1971 Datsun 240Z (8/71; 920 paint)
    IZCC #583; TZCC #16; CZC #110
    I'm never serious unless I should be.
  2. #2
    Z Club of San Diego Montezuma's Avatar
    Member ID
    CZCC-10665
    Join Date
    Feb 2006
    Location
    San Diego
    Age
    56
    Posts
    1,063
    Default
    We use Lizard Skin; great product. We got 5 quarts of both heat shield and sound; for $360 with the paint gun kit. Easy to apply and paintable. The only down side is that it will not stick to bare metal. I bought it from Tony Corriera of Barry White's Hot Rod Shop. Tony is a southern Cal distributor of Lizard Skin.
  3. #3
    Jim Arnett jfa.series1's Avatar
    Member ID
    CZCC-22303
    Join Date
    Aug 2010
    Location
    Richardson TX
    Posts
    764
    Default
    I used a product called Prodex from Insulation4less ( http://www.insulation4less.com/ ). It is a closed-cell polyethylene foam core with reflective aluminum foil coverings. it has a R16 rating and noise reduction of 19dB. Unlike bubble insulation, this stuff does not collapse under pressure or aging. Installation was pretty easy with 3M spray adhesive. I used about 60% of a 100' roll of 72" wide product.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	03. Rear insulation complete.jpg
ID:	59356   Click image for larger version.
Name:	05. Firewall insulation complete.jpg
    Jim Arnett
    HLS30-15320 12/1970, original owner
    L24-020208 (original)
    IZCC Original Owner Registry #53
  4. #4
    Registered User Kurbycar32's Avatar
    Member ID
    CZCC-23586
    Join Date
    Feb 2011
    Location
    Manteca, CA
    Posts
    337
    Default
    I used megamat made by fatmat. Its butyl which is an adhesive rubber commonly found on butyl tape used in the HVAC industry. Advantages are that it has zero odor, sticks really well, has thermal insulation properties (no official R rating) and is affordable. Disadvantages are that its a bit heavy
    I think there are plenty of good options on the market. The real key is to avoid anything made out of tar or roofing material like regular dynamat. Those products have issues with not sticking and terrible smell's when they get hot. Spray on material generally isnt thick enough to be effective in my opinion
    Early 1974 260z
    https://sites.google.com/a/thecomputerrehab.com/260z/
  5. #5
    Registered User
    Member ID
    CZCC-20446
    Join Date
    Nov 2009
    Location
    Rocklin, CA
    Posts
    70
    Default
    I spent many hours looking at various sound and heat insulation options. I suggest reading
    http://www.soundproofing.org/images/LightAircraft.pdf
    Insulation techniques used for aircraft are applicable to our vehicles, since we are also want maximum effectiveness with minimum weight, and to avoid flammable materials.
  6. #6
    Registered User Dr. 240Z's Avatar
    Member ID
    CZCC-28265
    Join Date
    Oct 2012
    Location
    New Brunswick Canada
    Age
    70
    Posts
    228
    Default
    Hi,
    Anyone having had any experience/exposure with a product, 'Murdermat', please offer your comments.
    From the company web site presentation, it appears to be a well thought out product both in its composition and application.
    Thanks,
    George
    Original Registration and Warranty Card
    Original owner of: HLS3018859 (Jan./71) ZCOOR Member # 178
    'Storms Never Last'
  7. #7
    Member ID
    CZCC-23586
    Join Date
    Feb 2011
    Location
    Manteca, CA
    Posts
    337
    Default
    Murdermat looks like super Megamat. Its essentially the same thing with thicker butyl core and high quality aluminum. Im sure its great but its pretty expensive. When I measured the car i figured about 60 sqft to cover the entire vehicle interior. If you use a real firewall insulator and use strips in the doors you can probably make 40ft cover the car. Using strips on large panels is important because the goal is to reduce panel vibration and not blanket the vehicle. Using two 6"x12" strips on the inner rear quarter panels as well as two 4"x12" strips inside the door gave me that new car door closing sound instead of "clang/rattle/rattle"
    Early 1974 260z
  8. #8
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    QuietCoat - Leading Sprayable Viscoelastic Polymer for Noise and Vibration Damping
    Someone posted this link in another thread. Has anyone else tried this? Results?
    Bryan Pilati
  9. #9
    Member ID
    CZCC-23586
    Join Date
    Feb 2011
    Location
    Manteca, CA
    Posts
    337
    Default
    I have used truck bed liner on metal panels before. The concept works and lowers vibration, just not as well as an actual mat. The heat resistance is also minimal
    Early 1974 260z
  10. #10
    Registered User
    Member ID
    CZCC-22274
    Join Date
    Aug 2010
    Location
    Inland Empire, CA
    Age
    30
    Posts
    230
    Default
    Something in me just leans toward the mat rather than the spray on, stuff. Mainly because it is thicker and can be used to stiffen up panels where they might rub and squeak.
    That PDF on aircraft soundproofing shows a product called Super SoundProofing Matt. Has anyone used that? Soundproofing Foams
  11. #11
    Registered User ZCurves's Avatar
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    56
    Posts
    1,052
    Default
    Quote Originally Posted by bpilati View Post
    That might have been me. I used it and am VERY happy. One - two gallon container is enough for an entire Z.
    Go here to read more:
    http://www.classiczcars.com/forums/i...tml#post421875
    Andrew (ZCurves)
    1978 Coupe - HLS30-440105
    Spring, Texas USA
    pro deo et patria
    My Albumz
  12. #12
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Quote Originally Posted by Dr. 240Z View Post
    Hi,
    Thanks,
    George
    George, I just got my MurderMax the other day, the reviews are good and I thought the price was fantastic.
    It will be a few months before I install it.
    1970 240Z HLS30 01955 March/70
  13. #13
    Registered User Rainman's Avatar
    Member ID
    CZCC-12393
    Join Date
    Aug 2006
    Location
    Medford, Oregon
    Posts
    169
    Default
    I used Hushmat in my 260Z.. Another aluminum backed butyl sheet type product. If you'd like photos I'm happy to share.
    Nissan Monterey Blue Early '74 260Z
    RLS30-037826
    Complete rotisserie refreshtoration in process
  14. #14
    Member ID
    CZCC-28265
    Join Date
    Oct 2012
    Location
    Age
    70
    Posts
    228
    Default
    Hi,
    I purchased Murdermat after a lot of study. The order arrived in great shape and shipping was pleasingly fast via UPS. However, the order arrived without an instructions (helpful hints) but I found cutting and fitting the material was straight forward using a sharp utility knife. How well it actually works only time will tell. The day I installed it the outside temperature was -15F and the Z was in full hibernation.
    The company requested a product review and, as such, I wrote it up; both the good and the not so good. It was the first product review placed on the company web site and if you read it you will note the company published the whole review which I think was pretty straight up of them.
    Cheers,
    George
    'Storms Never Last'
  15. #15
    Crumudgeon
    Member ID
    CZCC-798
    Join Date
    Apr 2000
    Location
    La Habra, CA USA
    Age
    60
    Posts
    1,374
    Default
    I use Wurth 890-100-060 sound deadening mats. Exact same stuff used by BMW in their new cars.
  16. #16
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    Quote Originally Posted by Rainman View Post
    Bring the pics!
    Bryan Pilati
  17. #17
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    I also used Quiet Car on my ride. It's hard to give an accurate rating without driving before and after in a short period of time.
    Folks have said my car has a refined ride- that's partially because of the noise reduction I bet.
    I bought someones leftovers so I got off cheap- 40$
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  18. #18
    Registered User mgmoreau's Avatar
    Member ID
    CZCC-14933
    Join Date
    Aug 2007
    Location
    Lincoln RI
    Posts
    220
    Default
    Hi,
    Cheers,
    George
    Hi George,
    Have you installed any of this Murdermat yet? Do you think it will also block the heat? Would love to see pictures of your install.
    Thanks
  19. #19
    Admin Mike's Avatar
    Member ID
    CZCC-4
    Join Date
    Feb 2000
    Location
    Seattle, WA
    Age
    50
    Posts
    6,070
    Default
    I used the B-Quiet material. Works ok, but, maybe something thicker would have been better: [m] 1971 240z - Year 2003 - Classic Zcar Club Photo Gallery
    Mike
  20. #20
    Member ID
    CZCC-28265
    Join Date
    Oct 2012
    Location
    Age
    70
    Posts
    228
    Default Murdermat Picture
    Hi mgmoreau,
    I could/should have taken a series of pictures while I was installing the material. That said, its now covered up with foam and carpet. As such, I rolled them back in an attempt to give you at least a small look at the material in place.
    Cheers,
    George
    'Storms Never Last'
  21. #21
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    Hmmm, I still can't make up my mind about which product both performs and is easily installed/applied.
    Bryan Pilati
  22. #22
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    Quote Originally Posted by ZCurves View Post
    BTW, how is this stuff holding up under the heat of summer? Does it remain stable?
    Bryan Pilati
  23. #23
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    Are most you priming and painting the surface, then coating......or what?
    Bryan Pilati
  24. #24
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Bryan P. I have purchased the murdermax panels and am just about to install it over my own version of Lizard skin that I made up from the same components,
    paint and micro balloons(micro spheres by 3M) I used Tremclad metal rust paint as the medium, it was applied at about 60*F and the metal of the body has been with in 30* - 70*F since then. That was a month ago and I can still push a fingernail into it if I push hard. As the temps increase I think it will harden up more but what I think is really 'giving' is the micro spheres, they are popping as I push. Tomorrow I'll be heating the inside firewall before applying the murdermax to the cab then spray adheseve on that to attach the firewall insulation. A bit of over kill I know but there is nothing like hearing a good song in a quiet car. I'll let you know how it goes.
    Chris
  25. #25
    Furthur GreenZZZ's Avatar
    Member ID
    CZCC-14083
    Join Date
    Mar 2007
    Location
    Austin, TX
    Age
    56
    Posts
    608
    Default
    I have some photos posted on my LizardSkin application in this thread http://www.classiczcars.com/forums/o...-products.html
    Lee - 2/72 240Z
    Thinking ahead is NO EXCUSE for thinking!
  26. #26
    Member ID
    CZCC-14933
    Join Date
    Aug 2007
    Location
    Lincoln RI
    Posts
    220
    Default
    Hi mgmoreau,
    Cheers,
    George
    Hi George,
    Thanks for the picture. I had forgotten I posted on this thread. How many square feet did you buy and was it enough to do most of the interior?
    Are you happy with the sound deadening now that it is installed?
    Take care,
    Marc
  27. #27
    Member ID
    CZCC-28265
    Join Date
    Oct 2012
    Location
    Age
    70
    Posts
    228
    Default
    Quote Originally Posted by mgmoreau View Post
    Hi George,
    Take care,
    Marc
    Hi Marc,
    I purchased the MDK Trunk Kit (20 sq ft.) and it turned out to be enough. In fact, just the right amount for the job.
    It was easy to work with be using a sharp utility knife.
    As to how well it works, please ask me again in a month - snowing here this AM!!
    FYI: The company has dropped the price; now $80.00
    Cheers,
    George
    'Storms Never Last'
  28. #28
    Member ID
    CZCC-14933
    Join Date
    Aug 2007
    Location
    Lincoln RI
    Posts
    220
    Default
    Hi Marc,
    Cheers,
    George
    George,
    Did you cover the inside of the rear quarters and doors and floor pans also with that trunk kit?
    Thanks,
    Marc
  29. #29
    Member ID
    CZCC-28265
    Join Date
    Oct 2012
    Location
    Age
    70
    Posts
    228
    Default
    George,
    Thanks,
    Marc
    Marc, all but the doors to date. That said, I have two sheets remaining, and I'm undecided as to where they go until I road test it. Certainly, the doors are a possibility - if needed.
    Cheers,
    George
    'Storms Never Last'
  30. #30
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Okay, so I thought I would have the Murder Mat in a week ago but just finished it today and couldn't be happier. It adhered to my version of Lizard Skin very well and once it is rolled down is very difficult to remove. Although the surface facing inside the car is slick after it is cleaned with an alcohol wipe, it takes spray on 3M adhesive very well. I'm a long way from getting the sound system going but the echoee sound inside the cab is gone. I'm sure most of the stick on sound deadeners would do the same thing.
    I bought 40sq. ft. and was able to cover everything I thought needed it.
    Chris
  31. #31
    Member ID
    CZCC-12393
    Join Date
    Aug 2006
    Location
    Medford, Oregon
    Posts
    169
    Default a few photos per bpilati's request
    Bring the pics!
    Here are a few photos of the hush mat in my 260Z.. Try not to laugh.. I know it looks like a first grader did most of the application, I was trying to get maximum coverage while minimizing waste.. The roof was completely covered as well as the insides of the doors. This is great stuff, I highly recommend it.
ID:	62219Click image for larger version.
ID:	62220Click image for larger version.
ID:	62221Click image for larger version.
    RLS30-037826
  32. #32
    Registered User GeoJoe's Avatar
    Member ID
    CZCC-28971
    Join Date
    Jan 2013
    Location
    GA
    Posts
    107
    Default
    This looks great ^^^^^. Nice puzzle work.
  33. #33
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    I decided to go with the Lizardskin. I spent last weekend taping the inside off.
    Bryan Pilati
  34. #34
    Member ID
    CZCC-28971
    Join Date
    Jan 2013
    Location
    GA
    Posts
    107
    Default
    I've ordered 80 sq ft (2 40' packs) of the BL version of Murdermat for about $225 with free shipping. The sales rep said that it would probably take 60 sq ft to do the whole car. I'm talking floorboards, tranny tunnel, firewall, doors, roof and trunk area.
    He also said that there isn't a reason to buy their thicker stuff, as I'll probably have some left over and can easily double up on concerned areas.
    My problem was getting all that nasty, hairy jute off the bare metal. Check out the green monster!Click image for larger version.
  35. #35
    Registered User kacrow76's Avatar
    Member ID
    CZCC-25334
    Join Date
    Oct 2011
    Location
    Kansas
    Age
    52
    Posts
    97
    Default
    I used the lizzard skin just make sure you put it on heavy. not sure i put enough on and was to late to spray more. so i got some pad with the foil on it from my upholstery guy looks to be good stuff and was cheep. ready for carpet now.
  36. #36
    Member ID
    CZCC-28971
    Join Date
    Jan 2013
    Location
    GA
    Posts
    107
    Default
    Here's my progress. I've used all 80 sq ft of murdermat already, and still nothing on doors. Already has a much more soild sound inside. Got it in and laid out some carpet and vinyl for estimated future look.
  37. #37
    Registered User
    Member ID
    CZCC-24523
    Join Date
    Jun 2011
    Location
    Canada
    Posts
    56
    Default
    I used a product from ProForm Products, (Welcome to Pro Form Products). Is is available in a box with (2) 29"x32" sheets which is large enough to do the rear deck area (I traced the original pattern before removing the old). This bitumen material is a touch thinner than the original stock material but is quite close. It also has a very sticky adhesive which keeps it down firmly whatwith all the ridges in the rear cargo area and is paintable as well. This material is black in color and would be ideal for the stock restoration. Just another option...
  38. #38
    Registered User
    Member ID
    CZCC-24523
    Join Date
    Jun 2011
    Location
    Canada
    Posts
    56
    Default Bitumen Sound Deadening Sheets
    Thanks Jim D. for the PM, here are some pics as promised. I think you should be able to distinguish the pattern for the early Series I car with these pics but I would be happy to trace out a pattern for you and send it to you. The sheets are black but were sprayed with a grey primer in preparation for paint. I hope this helps for now...
    It might be noted that someone has welded the steel tool box doors from a later car, that is why they are in the pics, so as not to confuse you, this is a 12/70 car. The original sound deadening went pretty close to the front luggage riser trim from other stock pics I have seen. I believe the bitumen went up to about 1/2" or so with cut-outs for the the luggage strap screws. I obviously went as far as the tool box doors only. These bitumen sheets are long enough for a Series II 240z but not long enough for a Series I as they would need to be about 38.75" long and the sheets are only 32" long. If you have the tool box doors in the back then these sheets are plenty long enough.
    Perhaps another member might be able to supply some original pics of the rear cargo area to determine the correct position for your 7/70car. Rob
ID:	62769Click image for larger version.
ID:	62770Click image for larger version.
ID:	62771Click image for larger version.
ID:	62772Click image for larger version.
ID:	62773Click image for larger version.
ID:	62774Click image for larger version.
ID:	62775Click image for larger version.
  39. #39
    Frogsquisher Zup's Avatar
    Member ID
    CZCC-8151
    Join Date
    Apr 2005
    Location
    Bentonville, AR.(not Arizona)
    Age
    71
    Posts
    265
    Default
    Thanks a bunch Rob!
    That helps me get a visual on it. I know there are several other members (Mike B and Chuck R) that are quite interested in maintaining the originality of materials used to restore their cars.
    Chuck R. made a pattern for me of his floorboards and behind the seats and sent it. It is a big help as well.
    Once I get all the patterns together I will reproduce them on a 1" square grid and scan them on a large scanner I have access to at the office and I will save it as a .pdf file as a reference for everyone.
    Jim D.
    "Zup"
  40. #40
    Registered User
    Member ID
    CZCC-24523
    Join Date
    Jun 2011
    Location
    Canada
    Posts
    56
    Default
    Some early reference pics of sound deadening in the rear cargo area of a Series I 240Z.
Name:	early 70 240z car.jpg
ID:	62784Click image for larger version.
    Reference pic of Series II with tool box doors in rear area.
Name:	series II 240z cargo area.jpg
  41. #41
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    Well, I started spraying in the Lizardskin this past Saturday. It goes on pretty well. I had treated rust with converter and rust-inhibiting primer before putting in the Lizardskin. I've used up a gallon of the sound control so far with about 75% complete. I have the door interiors left, and some touchup in areas where I think it needs to be a bit thicker. I've been taking photos, will post some time. I need to order more, and the ceramic insulation. The optional sprayer works well, and is well made. You have to take the time to clean it well though. The cup that came with my sprayer has a tiny crack in it, so I've requested a replacement. Not sure how it got there but I think during its manufacture, because it was there when I pulled it from the box.
    Bryan Pilati
  42. #42
    Taz0162 Taz0162's Avatar
    Member ID
    CZCC-23207
    Join Date
    Dec 2010
    Location
    Illinois
    Age
    42
    Posts
    125
    Default
    I went with Dynamat lining directly to the inner plastic side panels, and the entire wheel well. I have the horizontal rear panel speaker box that MSA sells, duel side speakers in stock brackets (Passanger side one created and rebent to install on that side) and a Subwoofer installed in a PyleDriver box (sub box made to look like a tire generally installed inside rear of SUV's) cut to sit shallower in wheel well. No rattle so far.
  43. #43
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    And you're happy with the Dynamat?
    Bryan Pilati
  44. #44
    Member ID
    CZCC-23207
    Join Date
    Dec 2010
    Location
    Illinois
    Age
    42
    Posts
    125
    Default
    Yes very happy with Dynamat. I was going with the approach of ensuring that there would not be any rattle noises from the amp powered four speakers plus subwoofer that I installed. I didn't use it on anything up front only the insides of the rear panels and throughout the wheelwell. I have not experienced any rattle at all with the system cranked up (for testing purposes only, ). I didn't want to eliminate road/engine noise because that's half the fun of the 240Z with my MSA performance exhaust setup. I would use Dynamat again on my other projects.
    ~Chris Tazelaar
    05/72 HLS30-081275 L24-102597
    Owner since 07/05
Thread Information
Users Browsing this Thread
Similar Threads
  1. Sound Deadening, Anyone Heard/Used This One?
    By texasz in forum Body and Paint (S30)
    Last Post: 05-31-2010, 05:45 PM
  2. sound deadener/heat shielding
    By trykflyr in forum Interior (S30)
    Last Post: 07-01-2008, 12:02 PM
  3. Sound Deadening ....Post OP
    By MAX in forum Interior (S30)
    Last Post: 04-07-2007, 11:18 AM
  4. Stripped sound deadening marterial
    By hmsports in forum Open Racing Discussions
    Last Post: 11-20-2003, 09:14 AM
  5. Underbody sound deadening
    By drunkenmaster in forum Body and Paint (S30)
    Last Post: 04-09-2003, 02:01 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
