Results 1 to 64 of 64
Thread: Rota RB Rims Fitment Question
  1. #1
    Registered User galban's Avatar
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default Rota RB Rims Fitment Question
    Hi, I am new to the site. I have a 1971 240z and would like to put new wheels on it. I'm looking to get Rota RB's but I am not sure what will be the right size because I do not want to roll the fenders or need any type of spacers. I need something that will plug and play stock, preferably 16" rims and will the front center cap fit the rim when mounted. Aslo if you guys can tell me what size tires to run with the setup. Thanks !!
  2. #2
    Semi-retired admin Arne's Avatar
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Two questions - is your car lowered? Do you have an air dam on the front, or the stock valance?
    Arne - Former owner, HLS30-37705, 7/71, 905 Red
    Car blogs - 240Z - Porsche 911
  3. #3
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    The car is not lower stock with a front air dam . thank you for your help
  4. #4
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    I have 14 inch wheels now
  5. #5
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    OK. It depends a bit on your particular air dam, and whether it drops straight down in front of the tire, or wraps under like the stock valance does. In either case I'd recommend Rota Rb 7x16 with +4 offset. If your air dam drops and has a lot of clearance for the tires in front while turning, you can use 225/50-16 on all four. If your air dam wraps and has tight clearance while turning, stick with 205/55-16, at least on the front.
    The picture below is my former car in its new home in Norway. It has the Rotas mentioned here with 205/55-16 Pirellis.
  6. #6
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Click image for larger version.
Name:	240 Z 4.jpg
    thank you for the information. I attached photo of the air dam. Does the center cap fits on the front hub?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  7. #7
    Supporting Member Zedyone_kenobi's Avatar
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    I have never seen that air dam before. Does it bolt onto the stock lower valance panels, or does it replace the stocklower valance panels.
    On first glance it looks like you have plenty of room up there.
    1971 240Z HLS30-38691
    93.9% done and getting better every day
    Now with 100% more DATSUN SPIRIT L28 Power
    1968 Datsun 2000 SRL311-03416
  8. #8
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    It bolt under the front marker lights. so what you think 205-55 ,215-50 or 225-50. Does the front cap fit the car hub. On your picture it looks like you have the front caps on.
  9. #9
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    It's not my car anymore, and it had different wheels on it when I sold it. But Terje does run center caps, according to all the pictures he has posted.
    I can't see the clearance from the picture angles you posted, but it looks encouraging. I also agree, that's an attractive but unusual air dam. I'd try 225/50 on that one, I think. 215/50 will look a little short and open up the fender gap.
  10. #10
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    For reference, my car runs 205/55/15 on the panasports. I run 195/60/15 on my LeMans VTO's. Both fit without any issues on stock bodywork with tokiko springs on board.
  11. #11
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    I run 225/50R16 on 16x7 zero offset Panasports and mine rubbed on all four corners. You are likely OK in the front if you go with +4 as Arne suggested, but in my case, even +4 would not have helped the rear rub. I tried to roll and when that didn't do it, I trimmed the flange by about 10mm.
    One option is to run the new Dunlop Direzza ZII in a 225/45R16. The diameter will be better for gearing, rubbing and overall looks IMHO. I think my 225/50R16 tires look a tad tall on the car.
    The first pic shows my clearance test with the spring removed. After trimming, the tire just clears the lip. The second pic shows the trimmed lip.
ID:	62530Click image for larger version.
ID:	62531Click image for larger version.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  12. #12
    Registered User Zbliss's Avatar
    Member ID
    CZCC-28308
    Join Date
    Oct 2012
    Location
    Nashville TN
    Posts
    8
    Default
    Here is my 1972 16x7 front and 16x8 rears with offset of 10 & 4. Tires are 205/45 front and 225/50 on the back. I also have lowering springs - Eibach Pro kit. No rubbing yet, but I just got it done and haven't driven it very far yet.Click image for larger version.
  13. #13
    Registered User
    Member ID
    CZCC-23182
    Join Date
    Dec 2010
    Location
    Mid-Atlantic
    Age
    49
    Posts
    148
    Default
    I run 225/50R16 on 16x7 zero offset. They rub on all four corners. You would probably be safe with 205's.
    You may find your options limited in 16's. You might consider doing 15's because that's what the Miata crowd uses. So there are more tire/wheel combinations available.
  14. #14
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Guys you are the best thank you so much. Zbliss I really like your set up. Your rims are Rota RB hyper black in the front 16X7 +10 205/45 back 16X8 +4 225/50 .. Nice you didnt roll the body and no rubbing . Does center cap fit the front hub with no problems? Why +10 in the front?
  15. #15
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Ksechler nice set up too.. maybe 205/45 front and back 215/50 ?
  16. #16
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Ksechler, are the wheels turned slightly right? Can't really tell. Looks like you could lose a little caster on the front there if they are straight. Might save a bit of rubbing on turns. Maybe the T/C bushings are shot?
    I also believe the 16" tire options outnumber the 15"s in most categories. Just do a quick list of 225/50-15 and 225/50-16 on TireRack if you need proof. With every possible kind of tire checked, in 15" there are 12 results, but with 16", there are 65 results... At 205/50 15 vs 16, 23 at 15", 43 at 16"
    And 225/50-16 Yoko S-drives on 16x8 +3 VTO's do NOT fit with a stock front valance rub-on-turns wise... But 215/40-16's do. Lots of choices in sizes around there to pick from to... Not a prayer in 15"
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  17. #17
    Registered User Pop's Z's Avatar
    Member ID
    CZCC-8342
    Join Date
    May 2005
    Location
    Fort Collins, Colorado
    Age
    75
    Posts
    430
    Default
    In answer to your question about the center caps...They fit with no issues clearing the dust caps on the front hubs. I'm running RBs (15") with no clearance issues on a lowered car (Eibachs) and 205/60-15 Potenzas.
    Cheers, Mike
    '73 240Z, 80,000 original miles, F54, N42 massaged and shaved (10.5-1 comp.), stage 2 cam, ZX ignition, Header, 2 1/2" exhaust w/ magnaflow muffler, 5 spd (Maxima), 4:11 R180 (200SX), 15" Rota RBs 205-60/15 Bridgestone Grid 109s, KYB struts, stock springs, rubber bushings, MSA sway bars and strut bars, HotRod Air hvac system, '90 300ZX seats, upgraded sound system, BRE-type spook and spoiler
  18. #18
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    My 16X7 Panasports (not exactly sure on offset) with 225/50-16 fit without any rubbing. However, tires listed as the same size can differ quite a bit between manufacturers, so it helps to know what tire is being used. Jeff's Hankooks look pretty wide for 225s. I believe the S-Drives are wide for their size too.
    Mine have 10-year-old rubber on them that will soon get replaced.
    2/74 260Z
  19. #19
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    Leon, if I had to guess, I'd say you have some positive offset. Look at where your tires sit in the fenders compared to mine.
    Jeff
    IZCC #1285
  20. #20
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    I just went to order the Rota RB 16X7 +4 front and 16X8 +4 but they said the front cap wont fit on the hub. PoP's you had no problem with your RB?
  21. #21
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    I'm curious why people order staggered fitments. They don't improve handling. Z cars usually understeer at the limit and wider rears only make it worse.
    Jeff
    IZCC #1285
  22. #22
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    really i didnt know that . i guess it looks nice but i like to drive fast. maybe i should do 16X7 all around. more thinking for me . thank you
  23. #23
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Quote Originally Posted by Jeff G 78 View Post
    I agree Jeff, I think it's a combo of a slight positive offset (maybe +6mm?) and slightly narrower tires (although both are spec'd 225mm). I'll have to take a wheel off and check the offset sometime.
    2/74 260Z
  24. #24
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    Leon, did your wheels come from MSA? If so, they are likely +6 since MSA had custom offsets made to minimize rubbing. Mine came from a regular Panasport retailer just after MSA quit selling them, so they are zero offset. I agree that my Hankooks are possibly on the wide side with square shoulders to boot, but the whole stance looks wider on mine. It was lucky that both pictures are almost the same vantage point.
    I'd really like to try the 225/45R16 tires next time to give me more front and rear clearance.
    Jeff
    IZCC #1285
  25. #25
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    That's interesting to know about the custom offsets. I got the wheels second-hand. The PO removed them from his car which he got from a lady that had gotten the wheels 10 years prior, or so. I think the wheels date back to about 2001, or maybe 2003. I'm not quite sure.
    To your issue, a shorter tire would put it further from the fender vertically, but I don't imagine there would be much of a horizontal change. I think if you rub now, you'll rub with the 45-series 225s. It'll just take a slightly bigger bump to do so.
    I was planning on getting RS-3s for my next set of tires, but now I'm feeling a bit cautious. Gotta go measure clearances...
    2/74 260Z
  26. #26
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Ok now Im changing mind 17X7 Toyo 225-45-17 center cap fits. lol
  27. #27
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Default
    Quote Originally Posted by galban View Post
    No offense, but eewww. If you want to go with something different, how about these?
    16 16x8 XXR 531 Black Wheels Rims 0 Deep Dish Lip 4x4 5 Datsun 240Z 260z 280z | eBay
    Jeff
    IZCC #1285
  28. #28
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    My problem is i wouldnt want to roll or use spacers. And I hate that the center caps cant be used.
  29. #29
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    I guess I'm looking for a miracle.
  30. #30
    Registered User Topz's Avatar
    Member ID
    CZCC-26037
    Join Date
    Jan 2012
    Location
    Jessheim, Norway
    Age
    55
    Posts
    40
    Default
    There is no proplem with the front cap, as Arne posted, i have 16x7 +4 on my car, no fit problems at all.
    I would go for the 205/55 on the front wheels to avoid any rub issues:-)
    Terje
    HLS30-37705, 07/1971, 905 red , DA 40865
  31. #31
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    When i went to order them yesterday . They said the front cap won't fit.
  32. #32
    Registered User
    Member ID
    CZCC-23182
    Join Date
    Dec 2010
    Location
    Mid-Atlantic
    Age
    49
    Posts
    148
    Default
    Quote Originally Posted by zKars View Post
    I don't know how you could see a castor issue in that picture. The wheels are not turned and all of the bushings are brand new.
    With the 15" vs. 16" issue it wasn't the tires it was the wheels that I had trouble finding. There aren't that many 16X7 or 16X8 options out there with 4 lugs. I'm not saying they can't be found, but I spent a long time looking before I found what I wanted.
  33. #33
    Member ID
    CZCC-16285
    Join Date
    Mar 2008
    Location
    Houston
    Age
    47
    Posts
    2,919
    Default
    I love the way 15's look on my car. 16" panasports would look the business as well.
    But I run 15x7 and I think that 205/55/15's look spot on. I plan to pick up another set of these tires for my VTO Lemans and sell my 195/60/15's Bridgestone 960A's. Which are truthfully a great set All season tires I just do not need all seasons here in Texas.
    Currently you can get dunlop Direzza's and Yokohama S'drives in 205/55/15
  34. #34
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    I'm running 17X8.5 +4 offset rota rb's and my caps work fine!
    I wouldn't like running without caps either, but I have seen that a lot with the bigger Rotas
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  35. #35
    Member ID
    CZCC-28308
    Join Date
    Oct 2012
    Location
    Nashville TN
    Posts
    8
    Default
    ...a shot of the front.
  36. #36
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    I ordered the Rota RBR 16x8 + 10 all around should get them in a few days. Now looking for tires . lets see what i get when i put the rims on the car.
  37. #37
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Jeff G. I like this tire Direzza ZII in a 225/45R16. i may go with it.
  38. #38
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Got the rims center cap didn't fit .:-(
  39. #39
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Also tried with a 6MM spacer. Didnt fit.
  40. #40
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    For the guys that the center cap fits . Do you have the original hub or after market?
  41. #41
    Member ID
    CZCC-26037
    Join Date
    Jan 2012
    Location
    Jessheim, Norway
    Age
    55
    Posts
    40
    Default
    I have the original hub, no problems with the Rota hubcaps at all.
    Terje
  42. #42
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    I have always wondered why I have seen so many RB's running without the caps. I have all of mine on, but don't remember if or what I did to make them work. It might have something to do with my Wildwood rotors? I think I did wind up smashing the bearing cap slightly to give the cap room. My wheels are +4 offset
    Steve
    3.90 Subaru STI LSD
  43. #43
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Im all original don't fit. Need about 1/2to 5/8 on the cap. i have 16x8 +10. I even put a 6mm spacer.Didn't help. question. with 6mm do i need to change the studs? I called Rota to see if they sell different size caps .
  44. #44
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    For the guys that the caps fit. How deep are your caps? My is about 20mm and to the tads 30mm
  45. #45
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    To all here is the TRUTH about Rota RB rims.
    Iím surprised the all that have stagger rims on their Z canít see the different on the rims for them self and share this information with others.
    Rota RB 16X7 +4 or +10 will fit the Z front hub with no problem.. But if you go to 16X8 +4 or +10 they are a totally DIFFERENT rim they are call Rota RBR which this rim will NOT fit the Z front hub.
    I wish I knew this information before I bought these rims. I hope this will help other Z cars owners
  46. #46
    Member ID
    CZCC-8596
    Join Date
    Jun 2005
    Location
    Eugene, Oregon, USA
    Age
    63
    Posts
    8,465
    Default
    Interesting. But to be honest, I can't recall ever hearing of anyone having staggered sizes in this rim before. Generally a Z is fairly well balanced (unlike my Porsche) and benefits from having all four the same size.
  47. #47
    Registered User alternativez's Avatar
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    67
    Posts
    116
    Default
    18Racing.com shows rb and rbr, the wider "royal lip," and they sell stagger (7.5 rb & 8.5 rbr x 17 and 6 rb & 8 rb x 16) sets, and site shows inventory. Galban, are all four of your rims same? What measure? Site may be helpful, as you can zoom on photos and see rim depth difference, rb vs rbr. Is there a difference in thickness of the wheel mounting face, perhaps? Will the rim fit the front with bearing dust cap removed or flattened? Interesting problem. Like to know how this works out for you. I had settled on a 17" stagger set of these, but haven't ordered yet. Thanks for posting.
  48. #48
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    67
    Posts
    116
    Default
    Would be nice to see xsection specs of each wheel size...
  49. #49
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    My rims are RBR 16X8 + 10 this rim WILL NOT fit the front hub they are made for the rear of the car you could use them without the center cap.. Dont make the same mistake I did.
    But The RB 16X7 will fit the hub....
  50. #50
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    67
    Posts
    116
    Default
    I'm going to guess that the 16x8 wheel and perhaps the 17x8.5 may have a thinner mounting face than the 7 and 7.5. I've tried to get information from rota and from 18 racing to confirm that, but no responses. Maybe someone here can tell me. I suppose that makes sense. Just wondering if the 7.5 and 8.5 look reasonable as a set. Galban, as long as you can keep the bearings from drying out, you should be ok with only the wheel center caps. Did you try "smashing" the bearing caps a little; would that help?
  51. #51
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    On 16X8 smashing will not help the cap needs about 20MM longer to fit. I dont know about the 17 inch.
  52. #52
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    67
    Posts
    116
    Default
    So, one thing I might have missed: without the inner spindle cap, ie. dust cover, which covers the spindle nut and bearing, will your rota center cap fit? If so, the wheel center cap should suffice to keep the spindle nut and the outer bearing clean. We always kept some grease in the dust cap, so it might still be a good idea, even though you probably don't want grease in it. Any chance you could post a photo of the front wheel mounted, showing the spindle bolt sticking out? Sorry to bother; it's an interesting problem. It sounds like the mounting plate of the wheel is thinner on the 8" wheel than on the 7", if that makes sense. In that case, a wheel spacer should make up the difference, but that essentially changes the offset of the front wheels. Yet, you said you had tried a spacer. It sounds like they've made one wheel for the front and a different wheel for the back, the mounting surfaces being of different thicknesses. If that's true, I wonder why rota doesn't describe this difference. Specs of each wheel would be nice. Good luck!
  53. #53
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    So this is what I got now. RBR 16X8 +10 with Hankook V12 225/50 rear. RB 16X7 +4 with 205/55 front ... No spacers and the center cap fits with no problems. To all
    RBR 16X8 center cap will not fit ... Hope the picture will help.
  54. #54
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    67
    Posts
    116
    Default
    Glad you got it worked out, and thanks for the update. Your z looks nice! Now maybe you can get back to enjoying the ride! I like your stagger sizes. Come back with your impressions of the tires, the ride, etc. thanks.
  55. #55
    Registered User
    Member ID
    CZCC-23182
    Join Date
    Dec 2010
    Location
    Mid-Atlantic
    Age
    49
    Posts
    148
    Default
    Galban:
    That's a nice looking setup. Is your motor out? The front looks a little high. What did you do with the flairs? The front certainly isn't stock with the integrated mud flap. I really like it.
  56. #56
    Registered User
    Member ID
    CZCC-27246
    Join Date
    May 2012
    Location
    ST. Louis Missouri
    Age
    48
    Posts
    4
    Default these are the wheels to get
    Rota RB wheels 17x8 Front and 17x8.5 rear
    Toyo proxes 4 front tires
    Nitto NT-01 Rear tires
    Tires look great one the car and don't stick out from the fenders
  57. #57
    Registered User
    Member ID
    CZCC-24552
    Join Date
    Jun 2011
    Location
    kona hawaii
    Age
    59
    Posts
    481
    Default here is a 17"
    Rota RBR 17◊8.5″ and has wheel cap
    1971 Datsun 240Z Restoration Project: Rota RBR Wheels, Interior Prep, Gas Cap + Vent Hoses | Whitehead Performance
  58. #58
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    The stock motor is in the car. Need to change my spring. Hope that helps with the height. when i got the car it had the flairs .
    Guys with 17x8.5 how do they fit .. cause my 8 just makes it i have about 4mm to hit the s prings on the rear. post pictures.
  59. #59
    Registered User hotroder's Avatar
    Member ID
    CZCC-3898
    Join Date
    Apr 2003
    Location
    Milwaukee
    Posts
    23
    Default
    Did you have to get special lug nuts?
    Thanks
    Mike
    #1300 5spd, 3 webers
  60. #60
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    Got the lugs at autozone.
  61. #61
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    67
    Posts
    116
    Default
    The +10 offset placed the wheel slightly closer to the spring.
  62. #62
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    +10 will clear stock spring Perch on a 240
    I'm running 17X8.5 245's tires
    They will touch the perch on the front.
    Steve
    3.90 Subaru STI LSD
  63. #63
    Member ID
    CZCC-29179
    Join Date
    Apr 2013
    Location
    Queens ,N.Y
    Posts
    27
    Default
    I have no rubbing with the +10 .. I have about 5mm before touching the spring.
  64. #64
    Registered User GeoJoe's Avatar
    Member ID
    CZCC-28971
    Join Date
    Jan 2013
    Location
    GA
    Posts
    107
    Default
    Reviving this thread as I have run into the center cap issue on the front of my Rota wheels not clearing the hub. Rear fits fine. Check out the pics and let me know if anyone has found a true solution. Tap it flat?
ID:	69329 Click image for larger version.
ID:	69330 Click image for larger version.
    1973 240z coming back to life
Thread Information
Users Browsing this Thread
Similar Threads
  1. Rota Grid V rims wont fit front hubs!
    By tymarbry in forum Wheels, Tires and Brakes (S30)
    Last Post: 05-02-2013, 02:11 PM
  2. Quick Question on Rims.
    By Zachary Lawson in forum Open S30 Z Discussions
    Last Post: 02-21-2013, 04:50 PM
  3. 5 slot rims question
    By patjamejam in forum Help Me !!
    Last Post: 01-02-2011, 08:50 PM
  4. Another Wheel & Tire Fitment question
    By webzlinger in forum Help Me !!
    Last Post: 03-07-2008, 09:23 AM
  5. Quick wheel fitment question - 15x8.5 3-3/8 backspace
    By ktm in forum Wheels, Tires and Brakes (S30)
    Last Post: 02-18-2008, 06:33 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
