Results 1 to 15 of 15
Thread: Interior rust spots to check
  1. #1
    www.project240k.com khughes's Avatar
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default Interior rust spots to check
    Hi Guys,
    As some of you know, i have had my car sandblasted a while ago.. The sandblasting removed 99.9% of paint, however left all of the interior body sealant intact.
    I have to say the overall condition of the car is pretty good bar what i would call the usual rust problems, however I spent most of yesterday scraping the factory sealant out of the panel joins in the cabin, i am glad i did, The biggest issue was in the front corner of front footwells where the sill meets the firewall and A piller kick panel area.. Once i pulled the sealant out, it showed that there is a direct gap right into the wheel well.. i can't remember there being sealant on the outside so i assume water has been getting in the gap (maybe 1mil) and then soaking along the inside of the sealant/metal join
    Some other areas of note:
    • There was some rust forming around the air inlets into the cabin from the front windscreen valance, i have seen it much worse here on my other cars though
    • Rust hole around the size of a 20c piece on the drivers firewall, looks like the end of the frame rail in the engine bay.
    • I also found a bit of rust in the cabin along the bottom of the rear wheel well (especially at the corner of the rear quarter\rear window section)) - i can't find an external reason why it was rusting under the sealant here, but it was on the left side only.. so i presume it may have had a leak in the rear window, and dripping down the parcel tray, then down to the floor ending up here.
    • Previous cars have been also bad across the middle of the firewall where the heater box sits (i assume from a leak in the heater box), but this car is pretty good.
    I havn't started stripping the boot's sealant yet.. kind of dreading what i may find there!
    I have epoxied the bottom of the car twice now, then sprayed some 3M waterbased Stone Guard. I realized yesterday that i missed the step of seam sealing.. i am going to cover the inside with Rust bullet (along any frame rails\inside sections i can), seam seal the inside, then cover in epoxy and opt. a coat of stone guard.. externally i will probably seam seal every spot i can find, followed by 2 coats of epoxy along the seams and then the stone guard.. not ideal, but hopefully enough to stop water accessing it on both sides! I am avoiding any areas i know need bodywork until i can get that sorted out (i am trying to get the insides done, and enough of the understide done to get the drivetrain back on and it off the
    Frame Rail wise, i am planning to spray rust bullet in, then probably a coat of stone guard and then once the car is fully painted some Dynax S50 wax as the last line of defense.
    I am not 100% sure what areas i should be leaving unsealed, i hope some common sense prevails
    I will grab some photos of the rust spots i am talking about next weekend and post them up. but these areas are worth some thought.
    PS. i refuse to use POR15 on the car now, after a previous major failure on easily accessible panels (prepared correctly), no chance i would risk using it in areas i can't get to! i sure hope rust bullet is better!
    07/74 Datsun 240K GL Hardtop KHGC110 - #5497 (longest 240k project in history?)
    1970 Datsun 240Z HS30 #212
    www.project240k.com - project details on all my cars
  2. #2
    Registered User tez240k's Avatar
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    34
    Posts
    211
    Default
    i think its a necessity on these cars! im also rust treating, rust kill enamel, sealing AND stone guarding under the car too. just seems the only way to prevent this jap tin from rusting :/
    76' 240K - full resto project
  3. #3
    Registered User Flauski's Avatar
    Member ID
    CZCC-18329
    Join Date
    Dec 2008
    Location
    Wellington, New Zealand
    Age
    39
    Posts
    73
    Default
    You might want to strip the factory sealer on this join too;
    The three coupes I have seen in this spot have all had rust. This is a picture of my current one (best condition one) and it still warranted stripping this sealer and grinding/rust killing.
    This car had minimal rust, with none in firewall.
    Click image for larger version.
    1974 Datsun KHGC110 240K GT Hardtop
  4. #4
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    problem is metal treatment prior to epoxy, if this isn't done correctly is doesn't matter how much epoxy, stone guard or kill rust is on.
    I also wouldn't be leaving epoxy then stone guard either. Not sure what brand your using as some vary. My process is epoxy, prime, paint then stock guard.
    Wanted: Hardtop interior pieces
  5. #5
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default
    Quote Originally Posted by Flauski View Post
    Yep, pulled all the sealer there too, mine was actually very good in those areas, i would hate to see where the water got in to soak that seal up, what is the inside of that panel like? that yellow glue stuff is a total PITA to scrape (chip) off!
    Uras, that decision keeps me up at night!, The bottom of my car was really good and had been sandblasted and coated in some form of flash rust preventer. I lightly sanded that, then sprayed 2 coats of dupont 840R epoxy, then i have coated it in 2-3 coats of white 3M stone guard.. I chose this as it is paintable (and white), so plan to do 2-pac colour (dupont probably) and clear over that (will just take a little while).. that is just the underside.. topside, i am leaving to the pro's (with the rest of the body work)
ID:	62805Click image for larger version.
Name:	2013-03-29 16.53.04.jpg
ID:	62803Click image for larger version.
Name:	2013-03-29 16.53.25.jpg
    i am willing to give Rust bullet a chance on the inside where it is unlikely to really matter.
  6. #6
    ケンメリ 240k Style's Avatar
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    37
    Posts
    533
    Default
    Love the jig
    Adam
    1975 HGC110 "YONMERI" Datsun 240K GL Sedan
    1976 KHGC110 "KENMERI" Datsun 240K GL Coupe
    1978 MGC210 "Japan" Datsun 240K sedan (sold)
    http://japanesenostalgiccar.com/foru...hp?f=7&t=24596
    Contact Jason at info@jdmfactory.com.au for all your YJ / JDM needs !!
  7. #7
    240Krazy! Adzmax's Avatar
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    Good to see my old rotisserie is getting good use! Might have to buy it back when you're done lol
  8. #8
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default
    it certainly is going strong! i almost sold it to the sandblaster in part exchange, but glad that i didn't!
    I am in two minds to keep it after i am done incase (when) i decide to strip down the 240Z.. am i that foolish
  9. #9
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    Haha nice. Yeah not sure that I'll need one anyhow. I plan to build another jig just to move the shell and let the blaster/repairer deal with the chassis moving :P
    On a side note mine has some rust in the same places, inside of 1/4 seals as did my other shell.
  10. #10
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default
    spent the Mothers Day weekend doing the RustBullet and Epoxy top coat.. finally got the pics up onto my website Interior painting - Project 240K
    came out quite well i think
  11. #11
    ケンメリ uras1's Avatar
    Member ID
    CZCC-23813
    Join Date
    Mar 2011
    Location
    sunshine coast
    Posts
    809
    Default
    how much is this rust bullet stuff?
  12. #12
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default
    about $95 a quart (935ml?) + $25 delivery
    a little more than POR.. but much less when you factor in the cost of POR's metal prep and metal ready stuff too
  13. #13
    Member ID
    CZCC-18343
    Join Date
    Dec 2008
    Location
    Melbourne
    Posts
    450
    Default
    Quote Originally Posted by khughes View Post
    Awesome! I fantasize about my car getting to this point all the time lol.
  14. #14
    Member ID
    CZCC-6769
    Join Date
    Jun 2004
    Location
    Australia
    Age
    40
    Posts
    1,191
    Default
    really? i still feel like i haven't achieved much! maybe its because it isn't in rolling around yet..
  15. #15
    Member ID
    CZCC-28810
    Join Date
    Dec 2012
    Location
    Melbourne
    Age
    37
    Posts
    533
    Default
    It's all progress mate!!!
    and for the record colour and then deadner mats IMO
    Adam
Thread Information
Users Browsing this Thread
Similar Threads
  1. Check out this RUST!
    By kjohnson2444 in forum Open Discussions
    Last Post: 02-09-2013, 07:30 PM
  2. Where to check for rust??
    By Scaotty in forum Help Me !!
    Last Post: 06-22-2010, 03:42 PM
  3. Dealing with Minor spots of Surface Rust
    By mikewags in forum Body and Paint (S30)
    Last Post: 07-07-2008, 12:48 PM
  4. Small Rust Spots
    By spindel in forum Body and Paint (S30)
    Last Post: 03-04-2004, 09:43 AM
  5. Interior rust removal
    By QCAR17 in forum Interior (S30)
    Last Post: 10-20-2003, 12:46 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
