Results 1 to 8 of 8
Thread: 240Z blinker speed
  1. #1
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default 240Z blinker speed
    Does everybody's stock turn signals blink faster than most cars? Mine is faster on the tach gauge than the blinkers themselves. My Dad says older cars are like that but he spells Datsun with an "O". They work fine just faster than I'm used to, like there's a blown bulb. Just curious.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  2. #2
    petrolhead spitz17's Avatar
    Member ID
    CZCC-20758
    Join Date
    Jan 2010
    Location
    Bay Area, CA
    Posts
    618
    Default
    Mine doesn't blink that fast, most of the time normal, but occasionally speeds up for a split second then returns to normal speed.
    '72 Fairlady 240Z-L - HS30-10052, Imported in 1973 from Yokota Airbase
    '70 240Z - HLS30-19927, History in SCCA CP & Trans-Am, ICSCC CIP, IMSA GTU
    '77 Porsche 930 Turbo Carrera - Black on black
    '13 Subaru BRZ Limited - Daily Driver
  3. #3
    Registered User black gold man's Avatar
    Member ID
    CZCC-22534
    Join Date
    Sep 2010
    Location
    Detroit, Michigan, United States
    Age
    59
    Posts
    821
    Default
    This happens when there is a problem like bad bulb, short in socket ext.
  4. #4
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    I have the one on my 280Z flashing about once a second, but the other side is noticeably faster, almost twice a second.
    Drive Responsibly.
    enjoy classic Rock music.
  5. #5
    Registered User tlorber's Avatar
    Member ID
    CZCC-20299
    Join Date
    Oct 2009
    Location
    Los Angeles
    Age
    55
    Posts
    1,190
    Default
    I concur with the bad bulb theory if you think it is blinking too fast.
    The other thing you can do is to swap out the old thermal flasher with an electronic one. These cost around $8.00 instead of $2.50, but they draw much less current and are more consistent.
  6. #6
    Registered User alternativez's Avatar
    Member ID
    CZCC-7110
    Join Date
    Sep 2004
    Age
    67
    Posts
    116
    Default
    Bad bulb, wrong bulb, corroded contacts, aging thermal, frayed or corroded wires or ground that are only nominally working, anywhere that is a mild short or overheating of a weakness will cause the incorrect pulse.
  7. #7
    Registered User
    Member ID
    CZCC-26669
    Join Date
    Mar 2012
    Location
    Washington
    Age
    31
    Posts
    53
    Default
    Also when the capacitor for the flashers starts to go it will blink faster and faster.
  8. #8
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Some 240's may also have the thermal bimetal clicker module between the flasher and the socket.
    The two devices click at a rate proportional to the current flowing through them...more current= faster rate. If your left side clicks at a different rate from your right then one side has higher wattage bulbs drawing more current, or one side has more resistance due to corrosion (in the sockets, connections or chassis ground) drawing less current or one side has a a short to ground drawing more current.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
Thread Information
Users Browsing this Thread
Similar Threads
  1. 1973 240z 3 speed auto swap to 4 speed maxima
    By ez73 in forum Parts Swapping (S30)
    Last Post: 08-12-2012, 08:02 AM
  2. Blinker issue!
    By madkaw in forum Electrical (S30)
    Last Post: 06-11-2012, 07:08 AM
  3. blinker help
    By sliprenoodle in forum Help Me !!
    Last Post: 08-29-2009, 04:48 PM
  4. blinker question
    By cst0215 in forum Electrical (S30)
    Last Post: 04-11-2004, 06:00 PM
  5. need blinker help
    Last Post: 04-01-2004, 04:18 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
