Results 1 to 21 of 21
Thread: mild camshaft ?
  1. #1
    Registered User nathan 240k's Avatar
    Member ID
    CZCC-25745
    Join Date
    Dec 2011
    Location
    tasmaina
    Age
    41
    Posts
    69
    Default mild camshaft ?
    hi guys im chasing a mild cam for my l28 dose anyone no weather u can still get billet cam shafts or do u have to get the standard one ground .im looking on the net and not getting much info.id rather not have to change lash pads etc.any info would be great
  2. #2
    Registered User 71Nissan240Z's Avatar
    Member ID
    CZCC-19487
    Join Date
    Jun 2009
    Location
    Portland, Oregon
    Age
    37
    Posts
    146
    Default
    Changing lash pads is only required when the wipe pattern is not centered om the pad. Stock spec pads are .160 of an inch i believe.
    I would just get the stock cam reground. The ppl doing the regrind will give u a valve lash spec and u take that number with u so when u do ur wipe test u see if u need thicker pads. Some ppl put little snipets of feeler guage to get the correct wipe pattern. Personallu i would just use new pads accordingly.
  3. #3
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Here's a company that does L motor cams.
    Web Cam Inc. - Performance and Racing Camshafts
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  4. #4
    Registered User Travel'n Man's Avatar
    Member ID
    CZCC-14147
    Join Date
    Mar 2007
    Location
    Western North Carolina
    Age
    60
    Posts
    1,486
    Default
    Get in touch with Dave Rebello at Rebello Racing - he can custom grind - I would go no less than a stage III personally
    Life's a journey; enjoy the ride!
    Mitchell
    L28 - N42 Block w/Flat tops - N42 Rebello Head & Cam - Triple 40 PHH Mikuni's - Headers - Recaro Seats -
    R180 3.9 Diff - Close Ratio 5 Speed - Toyota Vented Brake Upgrade w/ Porterfield High Performance Pads & Shoes
    1972 Datsun 240z
    HLS30-75040
  5. #5
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Do it right- do it big!!
    Like said, get a regrind done from someone that works with these L motors
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  6. #6
    Member ID
    CZCC-25745
    Join Date
    Dec 2011
    Location
    tasmaina
    Age
    41
    Posts
    69
    Default
    ok guys ive rebuilt the bottom end 4 thou over its a f54 block with a n42 head i had read in some forums not to go to big with these engines and other people say the bigger the better ?
  7. #7
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    If you go thru the MANY threads where owners comment on camshaft selection- MANY regret not going bigger as it doesn't effect drivability that much to have a big cam. I'm running stage 2 and it is as civilized as stock. If you read articles by Racer Brown , he comments how these engines like big cams.
    I can't wait to go bigger, but I'm not disappointed with milder cam .
    Being you already have the L28, you have some displacement and torque, now give it some HP.
    Remember , the power is in the head, make use of it.
    Steve
    3.90 Subaru STI LSD
  8. #8
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    I don't know what the L28's use in "tasmaina" (OP's location) but big cams on a stock EFI system is bad, big cams on carbs is good. That's what I've learned anyway.
    1976 280Z, with some minor modifications
  9. #9
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Yes, I meant to ask about induction system. This conversation should be based on how your fueling this.
    Steve
    3.90 Subaru STI LSD
  10. #10
    Member ID
    CZCC-25745
    Join Date
    Dec 2011
    Location
    tasmaina
    Age
    41
    Posts
    69
    Default
    sorry yea its gots a 350 holly at the moment but will be going triples
  11. #11
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Go BIG!
    Steve
    3.90 Subaru STI LSD
  12. #12
    Registered User Lazeum's Avatar
    Member ID
    CZCC-15411
    Join Date
    Nov 2007
    Location
    Paris, France (prev. Troy, Mi)
    Posts
    302
    Default
    I had a F54 with stock N42 head with what was called a stage II Cam (Schneider stage II 274/274 you can get at MSA).
    With regular distributor (Mallory Unilite) I wasn't able to get easily the advance the engine would require to get full power. I was only able to run 29° max advance. With spring kit, I could have been able to adjust somehow timing (maybe!)
    Going bigger on cam allows also engine to run with lower dymanic compression ratio where ping accurs. it should help to get engine running good.
    Regarding driveability, you're driving a 2300/2600lbs car with 2.8L engine, you should be smooth to drive.
    Today, I've got a much more agressive cam made by Rebello (called street cam with tight lash - I've got a reference number I need to dig from my documents if you'd like to know) on custom p79 head, 3xDCOE & Mejajolt ignition. Engine idle is set at 800rpm. In traffic jam is goes as low as 600rpm without any problem sometimes.
    At 2000rpm in 5th gear on roads going up with a 7% slope was no problem at all (but I run Megajolt so timing at this condition was 49° - it is hard to get on regular dizzy)
    So go BIG also
    Matt - 72' 240z
  13. #13
    Her Majesty the 26th 26th-Z's Avatar
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    http://home.earthlink.net/~cwenzel/index.html
    Go Gators
    Go Butler Bulldogs
  14. #14
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    I got my cam custom-ground by Isky, matching it to my engine and needs.
    2/74 260Z
  15. #15
    Registered User tez240k's Avatar
    Member ID
    CZCC-25613
    Join Date
    Nov 2011
    Location
    Adelaide
    Age
    34
    Posts
    211
    Default
    Yeah I'll definatly be going big. Built an 1800 for my Gemini years ago with a huge cam and was awesome. Will love to have the k just lumping its face off
    76' 240K - full resto project
  16. #16
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Being a bit closer to tassie, you might want to try Wade cams Wade Cams Australia precision camshafts for automotive, marine, aviation, industry or Crane cams Crane Cams Australia
    This article might help you some Racer Brown Datsun 510 camshafts & valve timing datsport
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  17. #17
    Member ID
    CZCC-25745
    Join Date
    Dec 2011
    Location
    tasmaina
    Age
    41
    Posts
    69
    Default
    ha ha yea i spoke to a tech guy at wades cams today ive ordered a cam lash pads and springs wades have a good rep her in aus with datsun camshafts so im going with them.thanks chashttp://www.datsport.com/racer-brown.html
  18. #18
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Soooo, what ya order mate?
    Steve
    3.90 Subaru STI LSD
  19. #19
    Member ID
    CZCC-25745
    Join Date
    Dec 2011
    Location
    tasmaina
    Age
    41
    Posts
    69
    Default
    i went a wade street/race grind the tech guy said that i had to change lash pads and springs with this cam
  20. #20
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Anything more specific - like lift and duration?
    Steve
    3.90 Subaru STI LSD
  21. #21
    Member ID
    CZCC-25745
    Join Date
    Dec 2011
    Location
    tasmaina
    Age
    41
    Posts
    69
    Default
    na sorry its a 74 grind .il post specs when it gets here
Thread Information
Users Browsing this Thread
Similar Threads
  1. Questions about mild cam for 280z
    By anthony280z2+2 in forum Engine and Drivetrain (S30)
    Last Post: 01-03-2013, 08:15 PM
  2. Triple carbs and mild cam, head Q
    By ra240z in forum Engine and Drivetrain (S30)
    Last Post: 04-13-2010, 07:51 AM
  3. Camshaft
    By Panamared in forum Engine and Drivetrain (S30)
    Last Post: 01-26-2007, 02:15 PM
  4. mild cam, triple webers
    By moyest in forum Engine and Drivetrain (S30)
    Last Post: 12-16-2003, 11:55 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
