Results 1 to 6 of 6
Thread: Are 240z -280z heads and cam and valves interchangeable
  1. #1
    Registered User
    Member ID
    CZCC-29312
    Join Date
    May 2013
    Location
    Massachusetts
    Posts
    21
    Default Are 240z -280z heads and cam and valves interchangeable
    I have an older 240z engine built up mildly (Cam and valves) but after pulling the head off i can see a few cylinder walls are trash. It has an 83mm bore which from my understanding is stock 2.4l and the options I am seeing is bore it to clean it up and then gain some hp but I would have to but oversized pistons, or if it is possible put the heads on my l28 280z engine and do a rebuilt on it and bore it out a little and do some modifications. I only recently got into the Datsun world so I dont know a whole lot but if you guys have any better ideas I would love to hear them. I am 17 and my 280z is my senior year project.
  2. #2
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    I would do what is the most cost effective. Have you looked at the cylinders on the 280 motor yet? These bottom ends are pretty bullet proof and most of the time it's just the head that needs the real work.
    Yes that head will work on that l28 block.
    You need to do some research ! Considering this is a school project I would think that would be part of your homework
    Things to consider
    CR - small chamber head on bigger bore= high CR
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  3. #3
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Download the FSM's for both engines and do some reading in the engine chapters. Any of the 280Z and the 240Z manuals will get going it the right direction. See link for manuals
    XenonS30
    This site will give you an idea of what is possible too
    Datsun L-series ZCAR engine modifications
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  4. #4
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Double post. Lost my connection for a minute......
    Chas
  5. #5
    Registered User 71Nissan240Z's Avatar
    Member ID
    CZCC-19487
    Join Date
    Jun 2009
    Location
    Portland, Oregon
    Age
    36
    Posts
    146
    Default
    Download a book called "how to modify your Nissan/Datsun oho engine" it is a must for frankenstien engines concoctions.
  6. #6
    Member ID
    CZCC-19487
    Join Date
    Jun 2009
    Location
    Portland, Oregon
    Age
    36
    Posts
    146
    Default
    Ohc engine*
Thread Information
Users Browsing this Thread
Similar Threads
  1. Are all 240,260,280z quarter panels interchangeable
    By TomCrowley in forum Help Me !!
    Last Post: 05-27-2013, 01:35 PM
  2. 76 280Z fuel injected, intake valves stuck open
    By poolman in forum Help Me !!
    Last Post: 08-31-2010, 06:07 AM
  3. 240Z/240K rear brake drums interchangeable?
    By Alfadog in forum Wheels, Tires, Brakes (240K)
    Last Post: 03-06-2006, 04:08 AM
  4. 280z Valves
    By seerex in forum Engine and Drivetrain (S30)
    Last Post: 12-05-2003, 07:31 PM
  5. 240z-260z interchangeable accesories
    By datto_240z in forum Misc (S30)
    Last Post: 10-07-2003, 07:24 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
