Results 1 to 32 of 32
Thread: overheating race car - stumped!
  1. #1
    Registered User cbuczesk's Avatar
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default overheating race car - stumped!
    I have a 1972 240Z that I race in ITS. I built a new engine and used it for a race weekend last month without any issues except for a miss that would kick in around 6400-6600 RPMs. After the race I rebuilt the carbs and took the car for a drive. The miss was still there but everything else was fine including water temp.
    I went out for qualifying Saturday morning and had the annoying miss but water temp was good. I swapped out the MSD 6 digital with the MSD 6AL that I used last year in an attempt to fix the miss. The race was Saturday afternoon and the miss was a little better but the water temp got up to almost 260 on the 6th lap so I came in. There was so much pressure in the system that the overflow hose blew out of the catch bottle! Once the car cooled I removed the thermostat.
    It was warmer Sunday and on the 3rd lap of qualifying the temp hit 240 and I came in. This time I put on a known good water pump and a new radiator cap. I ran the engine with the cap off and I could see coolant flowing in the radiator. The front carb was running lean so we adjusted it. In the race the car hit 240 on lap 3 and I backed it down. I was able to complete the race by racing 2 laps and then coasting down the front straight and short shifting a lap and repeating that process.
    I'd appreciate any ideas!
    Chuck
    East Coast Z Nationals held at the Carlisle Import & Kit Nationals - May 16-18, 2014 Carlisle, PA
    www.carlisleevents.com/events/import
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z ITS race car
    1972 240Z turbo
    1974 260Z turbo
    1975 280Z my first car
    1978 620 King Cab
  2. #2
    Registered User
    Member ID
    CZCC-19999
    Join Date
    Sep 2009
    Location
    Tucson Az
    Posts
    696
    Default
    Chuck
    A few questions. Is the miss still there? Did you break in your new engine properly? What shape is the radiator (and cap) in? I would start with the obvious, pull the plugs and see what's going on there. If you have a miss that's still there you clearly have an issue of some sort.
    Just a few suggestions
    Jan
    1976 280Z
    HLS30288273
  3. #3
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    You swapped out ignitions-did this change any of your timing parameters?
    Have you done a radiator pressure check to insure no HG defect?
    Do you run with a thermostat? If so, what kind?
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  4. #4
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Quote Originally Posted by Pomorza View Post
    Instead of obvious, scary might be more appropriate. Headgasket,maybe? New engine, cylinder misfire and overheating.
    1976 280Z, with some minor modifications
  5. #5
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    The miss is still there but it doesn't happen until 6700RPMs. I'm thinking that the problem is with the distributor and that the digital MSD is more sensitive than the analog that's in it now. I'll post a link to my in-car camera tonight so you can hear the miss. You might be able to read the temp gauge too.
    I broke in the engine properly. 20 over pistons, new bearings, etc. The engine has to remain mostly stock for ITS.
    Pulled the plugs before yesterday's race and 1-3 were lean. 4-6 were fine. I will pull them when I get home today.
    The radiator and cap were new last year. It's a 3-row from Champion. I used it last year and it kept the engine plenty cool.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  6. #6
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Ideas:
    -Losing coolant? But not to the overflow? Do a leak down test for sure. Is one cylinder disposing of the coolant due to a HG failure and causing the mis-fire? Plugs might be a clue if one looks different than the rest.
    -Bad hoses, ie collapsed lower hose on the suction side.
    -Front cover damage in the impeller area causing poor pump performance. Check for chips and cavitation caused pock marks in the impeller housing area.
    -If using a thermostat, take it out and see if problem changes/improves.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  7. #7
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    I didn't check the timing after swapping the MSD. I assumed that timing wouldn't change but I plan to check that tonight.
    I haven't done a pressure test but all the coolant hoses were pressurized when the engine was warm.
    I started Saturday with aa themostat but removed it for Sunday.
    I'll pull the plugs tonight and do a cold and warm compression test. I have a new leakdown tester that I can learn to use.
    Thanks for all the ideas guys!
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  8. #8
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    It looks like I found the problem. Here are my compression numbers from a cold engine: 157, 163, 175, 175, 165 183
    I never saw any smoke from the exhaust and it didn't smell like coolant. If it burned the coolant it didn't burn much of it because there was very little missing from the radiator.
    Now I have to figure out what caused the head gasket fail. I'm assuming that's what happened.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  9. #9
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    High RPM spark consistency is also affected by the meshing of the distributor drive spindle with the crank gear. There are combinations of steel and brass that are supposed to be better than stock.... I read this it in one of the datsun racing or datsun engine rebuild books.
    Maybe sunken brass seats or a valve adjust is the reason for the variance in compression.... did you baseline it after the rebuild?
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  10. #10
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Quote Originally Posted by cbuczesk View Post
    I only suggested the head gasket because some of the signs fit, but the signs also fit some of the other suggestions, like a collapsing hose, along with an ignition problem, for example. Those pressure numbers sure don't look good though.
    You have so many cars, and you're building your own engines, so I'm sure you know how to get good test numbers. Since it's so new and has few miles, I wonder if re-torquing the head bolts could save it? Not likely, but a re-torque would tell you if any of the bolts were loose, before you removed them to work on the gasket. If you find loose bolts, at least you'll have a possibility for the cause.
  11. #11
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    I had a bad HG and my numbers looked better then that, so not sure that tells all.
    The tester kit I suggested from Autozone(freebie borrowed tool) plugs into the radiator instead of the cap. You run the engine and see if the pressure rises above cap pressure. If it does, start pulling plug wires one at a time to try and diffuse the pressure. When the pressure stops rising, you found where your problem is. My symptoms were very subtle, never overheated, but I wasn't racing either. It just didn't run right, like a miss.
    That was a felpro gasket I believe, and it was giving out around #3. I'm running a Nismo gasket now.
    I also haven't read where you checked valve lash.
    Steve
    3.90 Subaru STI LSD
  12. #12
    Registered User
    Member ID
    CZCC-26864
    Join Date
    Apr 2012
    Location
    Durango, Colorado, United States
    Posts
    692
    Default
    At 6500 RPM's the thing that usually goes wrong is a valve starts floating. I'd pull your springs and check them all; you may have a weak one.
    As for overheating, sorry, we don't provide magic bullets here on ClassicZ but there are any number of overheating threads you can read and learn from, including this one:
    http://www.classiczcars.com/forums/h...mperature.html
    I believe that once one understands the THEORY of overheating finding the mechanical cause is fairly straighforward.
  13. #13
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    I didn't have time for a baseline after I built the engine. The head has new seats and guides and the valve springs were tested. I adjusted the valves last week before the race. I checked the head bolts and they were tight.
    I think what appeared to be a lean condition on the front 3 plugs was actually the blown head gasket. I'll pull it this week and check it for straightness. It's going to be a busy couple weeks. I also have to pull the transmission and fix a broken roll pin on 3rd gear. The joys of owning a race car! Thanks for all the help guys!
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  14. #14
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Quote Originally Posted by Wade Nelson View Post
    Do you have any corroborating data or calculations to even remotely prove this, or is the statement pure conjecture?
    2/74 260Z
  15. #15
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Wade,
    Are you serious?
    "Here at ClassicZ , we don't have magic bullets" -
    --ummm, I hope you aren't speaking on my behalf with such a pompous statement.
    So I guess your car never sees redline for fear of floating valves?
    Steve
    3.90 Subaru STI LSD
  16. #16
    Registered User
    Member ID
    CZCC-19999
    Join Date
    Sep 2009
    Location
    Tucson Az
    Posts
    696
    Default
    Chuck
    Could you be kind enough to keep us posted on what you find, maybe post some pictures. I would really like to see that cause of that overheating if it is actually the HG. As for redlines, all cars have them and they vary depending on too many factors to list. I personally don't like approaching them - I have a hard limiter at 6500 - but I've seen Z's hit 8k before without an issue. It all depends.
    Thanks
    Jan
    1976 280Z
    HLS30288273
  17. #17
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    Jan,
    I'll post pics when I get back out to the garage. Tue-Thu nights are filled with softball playoffs, volleyball, groceries, mowing, etc. I'm off Friday so I'll work on it then and post some pictures. I'm curious to see the head gasket too.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  18. #18
    '72 240Z(G) 3.2L
    Member ID
    CZCC-7328
    Join Date
    Nov 2004
    Location
    MA
    Age
    70
    Posts
    1,074
    Default
    So our 300 hp L28 with the 44mm carbs, pistons and other nice bits from the original BSR 240 running at 13:1 CR on 110 fuel ran hot from day one.
    The 240 did real well at the VRG event last year taking 1st, 2nd (overheating on the last lap), and DNF (first lap overheated).
    We changed out radiators, hoses, timing, a new head gasket, reconfigured the cooling system, replaced the BSR E31 head, etc.
    Little bubbles became much bigger bubbles once the throttle was blipped. Current thought is a small cylinder wall crack.
    Since the only thing that didn't get changed was the block and we started to get bubbles at idle and then big bubbles at WOT.
    We figured cracked block.
    Out came the engine and all the usable stuff (8-gal custom oil pan, diesel water pump and custom front cover, a real BSR valve cover, the huey tranny oil cooler
    if a little knowledge can make you dangerous, I'm a little dangerous
  19. #19
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    Wow. I sure hope I don't have a cracked block. I had the radiator cap off while the engine ran so I could see if the coolant was flowing through the radiator. It was. I didn't notice any bubbles though. I'm anxious to get the head off this Friday.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  20. #20
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    I pulled the head today. Everything looks good. I was hoping to see something that didn't look right. I have another E31 head that I just picked up from the machine shop. I think I'll put it on the block and get the old head pressure checked. What do you guys think?
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  21. #21
    Registered User
    Member ID
    CZCC-19999
    Join Date
    Sep 2009
    Location
    Tucson Az
    Posts
    696
    Default
    Hmm that interesting
    How do the valves look on the head? Any of them burned (really lean)? How did the pistons look?
    Jan
    1976 280Z
    HLS30288273
  22. #22
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    Valves and pistons look fine...everything looks fine. #1 and #2 are a little lighter in color than #3-6 but everything looks good.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  23. #23
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    HG fire rings all look solid, no blow by anywhere?
    On my HG , it showed up more as a discoloration of the fire ring.
    Steve
    3.90 Subaru STI LSD
  24. #24
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Chuck
    Lighter as in cleaner then the other pistons?
    Steve
    3.90 Subaru STI LSD
  25. #25
    Registered User 71Nissan240Z's Avatar
    Member ID
    CZCC-19487
    Join Date
    Jun 2009
    Location
    Portland, Oregon
    Age
    36
    Posts
    146
    Default
    Diesel water pump. Is it better than the normal petrol pump.
  26. #26
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    Lighter as in cleaner. Everything about the head gasket looks fine. I went over everything for a long time with a flashlight and magnifying lens. I checked the head with a straight edge and it looks good. Whew! I think I'll prep the other head and have this one checked by the machine shop.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  27. #27
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    What HG were you using? Do you run just water or Glycol ?
    I asked about the cleaner pistons because maybe some water was steam cleaning your pistons . It wouldn't take much of anything to pressurize the coolant system.
    Steve
    3.90 Subaru STI LSD
  28. #28
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    I used a full FelPro kit. I've never had a problem with FelPro. I ran water for the first weekend of use and a mix last time. I think there was a little steam cleaning the pistons and chambers. I think it was a very small leak and the temp dropped to normal under normal loads. When I did easy laps and the cool down lap the temp dropped to normal. But after 2-3 hard laps it was 240 degrees.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  29. #29
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Any chance the head had some warpage? Was it machined to flatness before building, or maybe at the high end of the warp limits and used as-is?
    I've never rebuilt an engine but I'm curious. I have a warped head in the garage and wonder how much is too much and what the effects are.
  30. #30
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Just curious of your engine specs as far as CR?
    Steve
    3.90 Subaru STI LSD
  31. #31
    Member ID
    CZCC-4368
    Join Date
    Jun 2003
    Location
    Chambersburg, PA
    Age
    53
    Posts
    488
    Default
    The head was on an engine that I removed from a car about 20 years ago. I had the head resurfaced just to clean it and make sure it's straight. We aren't allowed to shave it to raise compression for IT racing. I have new 20 over pistons installed so compression is about 9:1...stock. Everything is stock except for +20 pistons, Hooker header, exhaust, semi-custom air cleaner, oil cooler, Taylor plug wires and MSD 6.
    Chuck
    1969 240Z #390
    1971 Fairlady Z
    1971 240Z parts car
    1972 240Z turbo
    1974 260Z turbo
    1978 620 King Cab
  32. #32
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Personally I would spend the money on a Nismo gasket. They are pricey, but I think it's worth it. 125$ at Courtesy Nissan.
    Steve
    3.90 Subaru STI LSD
Thread Information
Users Browsing this Thread
Similar Threads
  1. Need help from anyone I am stumped!!!
    By nitrider73 in forum Help Me !!
    Last Post: 08-23-2011, 03:48 AM
  2. Still stumped, please help!
    By KDMatt in forum Help Me !!
    Last Post: 09-23-2010, 09:49 PM
  3. Stumped
    By 2toneFatone in forum SU Carb Discussions
    Last Post: 01-08-2008, 08:06 AM
  4. stumped
    By mtdripo in forum Engine and Drivetrain (S30)
    Last Post: 04-15-2004, 07:05 PM
  5. stumped
    By dero in forum Open Discussions
    Last Post: 03-13-2003, 06:42 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
