Results 1 to 22 of 22
Thread: 1972 Float Adjustment ...
  1. #1
    Registered User 240Z240Z240Z's Avatar
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default 1972 Float Adjustment ...
    I have a 72 with 3 screw SU's and they have the long and short arms in the float bowl lids. Long in front carb, short in rear.
    I intend to set the floats on my bench top by setting the lid with its float and gasket on top of a small clear drinking glass with a 23mm scribe mark at the correct spot.
    Can anyone tell me whether the distance between the inside of the float bowl lid and the top of the gas is 23mm for both the front and the rear carbs on a 1972, or is the front 23mm and the rear something less ?
    I'm looking for a definitive answer for myself and all my 72 brethren
    1972, White w/red, 4 speed, 77K, All original.
  2. #2
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    54
    Posts
    1,895
    Default
    The 23mm mark is the same for both when you measure the bowls. If you use the upside down lid method, you use 16mm and 12mm. There was a huge thread on this in July.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  3. #3
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    Quote Originally Posted by Jeff G 78 View Post
    Thanks for the quick on point response!
    What's the title of the thread from July ?
  4. #4
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    54
    Posts
    1,895
    Jeff
    IZCC #1285
  5. #5
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    Yeah I had read that one, that's where I got the idea for the clear bottle, which I think is a genius idea BTW!
    Thanks for ferreting out those numbers, until I hear otherwise I'm using them for my 72 carbs
  6. #6
    Registered User Stanley's Avatar
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Because of the tilt of the engine, and the front float bowl being in front of the nozzle while the rear bowl is rear of the nozzle, the level in the front bowl needs to be lower than in the rear bowl by 2 mm. This puts the fuel at the same level in at the top of the nozzles. That's why the ears on the front are longer by 2 mm. The FSM for 72 SU's just says 23 mm down from the underside of the lid. So 23 mm rear carb, 25 mm front carb for equal level at the nozzles. I guess you could go 21 mm rear, 23 front - I had trouble with the rear carb overflowing out the vent when I tried that, but can't say for sure it's wrong.
  7. #7
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    The engine does know know where the floats are... it only sucks in air. The fuel level in the jet should be the same for both carbs so that the suction at the top of the jet draws the fuel up the same height.
    It is like drinking from a long straw vs. a short straw when you simply the process. The length of the straw is more important when the suction is weak due to gravity... as the suction force increases, gravity forces matters less.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  8. #8
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    So I created this apparatus to help set the floats accurately and now I have even more questions.
    To achieve a gas (water) height 23mm from the inside of the lid the float is nearly contacting the inside of the lid, that's doesn't seem correct. Its that way on both lids and floats.
    Some assumptions :
    1. The gasket and the inside depth of the lid adds up to about 4mm. So I marked the outside of the glass at 19mm.
    2. Water behaves similar the gas for this test.
    3. My valves are correct and in good shape.
    Since I have them apart I thought I would use my calipers and calculate where the top of the gas is relative to the carb bridge assuming a fuel height of 23mm.
    Here's what I got :
    The bridge to the dome surface is 44mm
    The top of the float bowl to the top of the dome surface is 33mm
    So from the top of the float bowl to the bridge its 11mm
    Add 4mm for the gasket and lid and you get 15mm from the inside of the lid to the bridge
    Subtract 15mm from 23mm and you get 8mm, not 10mm as I've seen elsewhere ?
    I'm thinking I should replace the values anyhow, where's the best place to get a proper set ?
    Click image for larger version.
ID:	65618Click image for larger version.
ID:	65619Click image for larger version.
  9. #9
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    A gallon of water weighs about 8.33 #'s a gallon of gasoline weighs 6.07 #'s so the float is going to ride higher in the water versus the gasoline because it has to displace more gasoline to equal its weight than water to equal its weight...
    Charles
  10. #10
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    Theorectically you could multiply the desired dimension by 1.3723 and that would give you the correct value for float setting in water. But I am not sure I did the conversion right... somebody want to check that?
    C
  11. #11
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I am in love with that lab calibration!
  12. #12
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    Well, I'm back at setting the floats and have fitted them with some new valves I ordered. I'm still using the glass jar setup, but I've eliminated the water pump arrangement and have a small funnel attached to the inlet port by means of some tubing. The glass is marked at 21mm as a reference and I can poor gas into the funnel and watch where the level stops. I was able to get the short legged cap set to stop at 21mm with the black plastic float about 1/8" from touching the inside of the cap when inverted, however, the long legged cap with the taller valve could not be adjusted enough to allow the level to come up to the 21mm mark. I stopped when I noticed that the tang was bent so far in that it was contacting the body of the valve when inverted and the plastic float was hitting the inside of the cap. I ended up using another short valve body and bending the tang up so that inverted the float was about 1/8" from touching the inside of the cap and that put the level at the 21mm mark. I think this is where I'm going to try them.
  13. #13
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Some needle valves are different lengths or screw into the cover and stop at different heights....as you found
  14. #14
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    Yeah perhaps, but the new valves behave just like the old ones I took out. I couldn't get the long legged cap dialed in with the old tall valve body either.
    I just find it interesting that to get the correct gas level in the glass bowl required that the black float be nearly touching the inside of the cap. If I were to use the static 12mm, 16mm inverted lid method I'm sure that there would be insufficient gas in the bowl during acceleration (stumbling). Those numbers might work if the needles were solid and not internally spring loaded. IMHO, the spring loaded 3 part needles are just not designed for an inverted static setting. Does anyone know if the original needles were spring loaded, or were they solid ?
  15. #15
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Weighting the float could possibly be a solution to increase fuel height (and keep the float parallel to the roof at nominal)..... or cutting the high towers down and drilling new holes for the float pin.
  16. #16
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    Quote Originally Posted by Blue View Post
    Not sure how one would bond a weight to the plastic float in that environment, but its worth thinking about.
    I like the redrilling idea, but I don't think the "towers" would need trimming down unless they interfere with the movement of the float.
  17. #17
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    You could open the float at the top, insert weights, then seal so nothing external to hang up.
  18. #18
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    It's the sealant that worries me in a long time gas environment.
  19. #19
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Fuel level in the front bowl needs to be 2 mm lower than rear bowl. that's why the ears and valves are 2 mm longer (for the later 3-screw SU's) for the front carb. Then the fuel in both nozzles will be at the same level (the main thing).
    Wonder if the 4-screws also ran longer nozzles in the front? The 72 FSM doesn't mention this change - wonder if Nissan engineers were embarrassed that they got it wrong with the 4-screws. Maybe the factory race team noticed the fuel level difference when they pulled the domes and checked fuel level in the nozzles. Easy enough to fix with a couple of washers, so maybe they passed it along to the designers who incorporated the change for the 3-screws. ???
  20. #20
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Quote Originally Posted by 240Z240Z240Z View Post
    The floats are solid foamed EPDM stuff . Nothing to seal. If you really really had to add mass, just screw in a tiny screw or embed a tiny needle or metal shaving.
    I'm also wondering about all this lovely static fuel height setting and imagining how this relates to the case when fuel is spritzing in the top and flowing out the bottom as the car runs. Here's hoping its kinda similar.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  21. #21
    Member ID
    CZCC-4410
    Join Date
    Jun 2003
    Location
    Woodinville WA
    Age
    65
    Posts
    79
    Default
    Quote Originally Posted by zKars View Post
    The floats are solid foamed EPDM tuff . Nothing to seal. If you really really had to add mass, just screw in a tiny screw or embed a tiny needle or metal shaving.
    I'm also wondering about all this lovely static fuel height setting and imagining how this relates to the case when fuel is spritzing in the top and flowing out the bottom as the car runs. Here's hoping is kinda similar.
    Ah I see, I didn't know they were solid, that makes a big difference!
    Yeah I hear ya, with all of the fuel entering and leaving and the car going up hill/down hill over bumps, idling, accelerating, banking, etc. it's a wonder a float system works at all !
  22. #22
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Early Spitfires had floats, German Messerschmitts had fuel injection. In -neg G moves, the floats raised and caused the Spitfire's engine to stop. To circumvent this, the Spits had to roll first before pursuing...... giving the Me-109 time to get away. Think of this when you pull high G turns, etc.
    I think putting the float on a gimbal would help (or the long buffer hose (anti slosh tank) between the bowl and jet solution I mentioned in another thread) however Weber and Hitachi (flat top) addressed it by putting the jet smack in the middle of the float bowl.
Thread Information
Users Browsing this Thread
Similar Threads
  1. ecu float
    By rcb280z in forum Electrical (S30)
    Last Post: 03-03-2013, 05:42 PM
  2. Float Height Adjustment ?
    By 240Z240Z240Z in forum Carburetors (S30)
    Last Post: 07-03-2010, 10:41 AM
  3. Gas Depth in Float bowl, when excluding float volume
    By hogie in forum Carburetors (S30)
    Last Post: 05-14-2010, 03:08 PM
  4. Float adjustment on
    By v4vAnimalMother in forum Carburetors (S30)
    Last Post: 04-05-2009, 03:35 PM
  5. Seat Adjustment 1972 240z
    By LJJONES in forum Help Me !!
    Last Post: 10-19-2003, 04:24 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
