Results 1 to 3 of 3
Thread: High-idle vacuum motor thingy
  1. #1
    Registered User
    Member ID
    CZCC-29501
    Join Date
    Jul 2013
    Location
    Dorrington, CA
    Age
    62
    Posts
    3
    Question High-idle vacuum motor thingy
    Not sure what it's called. but it's a vacuum motor on top of the engine that yanks up on the throttle linkage. I assume it's the high idle throttle for starting. It was disconnectified when I got the car. I hooked it back up and it seems to do nothing. Engine runs great when warm, but barely starts when cold. Is this an essential component to Z-related happiness? I know Zs need to be choked until they warm up a bit, but would a properly functioning unit improve my starting situation? There's a red adjustment screw on it that I assume would adjust it in some way. It's a '70 HLS30, stock as a rock.
  2. #2
    Registered User beermanpete's Avatar
    Member ID
    CZCC-21519
    Join Date
    Apr 2010
    Location
    Northridge, California, U.S.A.
    Age
    57
    Posts
    631
    Default
    The part you are refering to is called the throttle opener. It is suppose to hold the throttle open slightly during decel. You won't see it do much, if anything, while blipping the throttle from under the hood. The factory service manual has informaton about it in the emission section and the fuel system section. This part is not likely to affect cold starting.
    Make sure the choke is adjusted correctly and that the jet nozzels move freely when operating the choke. See the fuel section for details.
  3. #3
    Registered User
    Member ID
    CZCC-29501
    Join Date
    Jul 2013
    Location
    Dorrington, CA
    Age
    62
    Posts
    3
    Default Thank you! You're a gentleman and a scholar.
    Quote Originally Posted by beermanpete View Post
    Ah! That makes much sense. I've been trying to find it in the shop manual. I thought it could not be doing much during startup, since it's vacuum-driven. Thank you sir, you've been most helpful. I just got the tranny rebuilt, and want to take it on a nice long drive.
    - Theron
Thread Information
Users Browsing this Thread
Similar Threads
  1. Brief high idle
    By siteunseen in forum Fuel Injection (S30)
    Last Post: 08-21-2011, 05:16 PM
  2. new part = very high idle
    By TexasStyle280z in forum Help Me !!
    Last Post: 04-27-2009, 11:58 AM
  3. High RPM when idle
    By Blue 280zx in forum Open S30 Z Discussions
    Last Post: 12-10-2007, 06:36 PM
  4. High Idle
    By mholmes in forum Help Me !!
    Last Post: 01-16-2006, 08:21 PM
  5. high idle
    By christ0ph in forum Open Discussions
    Last Post: 03-27-2003, 05:38 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
