Results 1 to 12 of 12
Thread: I need some help ASAP
  1. #1
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default I need some help ASAP
    The FSManual has the diagram that shows all the frame dimensions on it. It is all in metric and at the bottom there is a baseline near the rocker panel that everything is measured from. The question is where is the line on the car at the bottom of the rocker or at the bottom of the body flange below the rocker? I am going to the frame shop in the morning and need to check all the frame dimensions.
    Thanks, Charles
  2. #2
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default 240z Frame Alignment Chassis Jig
    The attachment may help. It seems the author had the same difficulty as you and assumed the bottom of the floor was the reference. I looked at '72 to '78 FSM's and could not find the reference stated. Datsun only shows drawings and it looks higher than the frame rails for certain however I would have assumed it to be the bottom of the rocker pinch-weld. If the rocker pinch-weld is lower than the frame rails then it can not be the reference.
    I hope this helps.
    Attached Thumbnails Attached Thumbnails 240Z-chassis-jig.pdf
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  3. #3
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Hmmmm
    I looked closer and it seems the reference datum line (red) is below the floor (blue) so maybe I was correct and the bottom of the rocker pinch-weld is the vertical reference?
    Have a look:
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Floor Detail.gif
  4. #4
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    That was great Blue. thanks for that. That makes perfect sense about the pinch welds. I assume that document is now part of the database now, so I can always find it since I'm in it . I love the burn marks from splatter on his notes.
    Charles
    PS The car went to our frame man today and he said it was an 1" out so I was glad I took it...
  5. #5
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    How do you know which line is the floor line? I guess I can measure from the tranny support and compare that to the 86 mm to determine what the reference is...?
    C
  6. #6
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    The floor line has the frame rail (floor support) welded to it. This is clear to see in the drawing at least!
  7. #7
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Here is another that uses the floor: 240Z frame drawing sketchup - Blogs - Classic Zcar Club
    I am now leaning to the datum line being the floor because the frame rail rises above the floor in the large groove behind the rear seat mount and because the seat mounts rest on the red line.
  8. #8
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    So the line you high lighted in blue must be the hump in the floor board which comes back near the rear seat supports. That would also explain the little angle at the rear of the frame rail coming up to the dashed line you high lighted because it comes up into the hump at the rear. Agree?
    C
  9. #9
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Yes, after a lot of review I agree
  10. #10
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    Thanks for the help last night Blue. I picked the car up today. He had it all squared up and level. The bolts for the front bumper are not exactly right but if he pulled that section it would throw off the fender. I'll make the bumper work. He said the car had been pulled before and that it had been hit in the front from the drivers side. The dimensions of the factory diagram are "more like guidelines anyway..." the tension rod sockets were different from the diagram by 10mm but both were even and he said they hadn't moved. Also the shock towers were 10mm higher than the diagram. There evidently were some fairly large tolerances on frame assembly as long at it was all even.
    Charles
  11. #11
    Registered User
    Member ID
    CZCC-23125
    Join Date
    Dec 2010
    Location
    Spartanburg, SC
    Age
    51
    Posts
    468
    Default
    In one of the other threads Blue posted one of the guys found a similar discrepancy in the rear frame rails...
    C
  12. #12
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Glad to help!
Thread Information
Users Browsing this Thread
Similar Threads
  1. Need a Cam Grinder asap!
    By Co0kieduster in forum Engine and Drivetrain (S30)
    Last Post: 12-08-2011, 06:40 PM
  2. Help needed ASAP
    By Jeff G 78 in forum Carburetors (S30)
    Last Post: 10-15-2011, 10:48 AM
  3. need tranny asap
    By robftw in forum Help Me !!
    Last Post: 09-25-2011, 10:37 PM
  4. Need diagnosis asap!!!
    By mike's78z in forum Fuel Injection (S30)
    Last Post: 10-05-2009, 04:01 PM
  5. '75 280 in Need of Help ASAP!
    By calliebrat in forum Help Me !!
    Last Post: 11-11-2004, 12:49 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
