The Works rally seats were made from FRP, but with mounting studs moulded into the base. There were two brackets which attached to these studs, and the brackets were then bolted to the OEM sliding seat rails.
See attached photos. The tall bracket mounted to the FRONT part of the seat, and the short bracket mounted to the REAR of the seat. They are photographed in their correct orientation.
Bookmarks
