Results 1 to 8 of 8
Thread: L28 EFI setup on l24 motor?
  1. #1
    Registered User
    Member ID
    CZCC-29489
    Join Date
    Jul 2013
    Location
    Brisbane
    Age
    30
    Posts
    26
    Default L28 EFI setup on l24 motor?
    As the title says im after a EFi setup on my yonmeri i hate carbies with a passion an want it swapped out asap. so question is can i bolt on the efi setup an run an external fuel pump an drive off? will i need to go down a size in injectors? anyways cheers!
  2. #2
    Crumudgeon
    Member ID
    CZCC-798
    Join Date
    Apr 2000
    Location
    La Habra, CA USA
    Age
    60
    Posts
    1,374
    Default
    Its not a bolt on. There are slots cut in the cylinder head intake ports to allow the injector flow to atomize properly in the port. That's assuming your engine is carburated.
  3. #3
    Registered User madkaw's Avatar
    Member ID
    CZCC-7622
    Join Date
    Dec 2004
    Location
    bloomington IN
    Age
    58
    Posts
    2,288
    Default
    Then there's working out the high pressure fuel pump to feed the FI. It's going to be more work then what you think- definetly not a one day job.
    Steve
    71 240z,bw-5sp 2.4-40 over,balanced,e-88,big valves,ported&polished, stage2,header, triple Mikuni's 40's
    3.90 Subaru STI LSD
  4. #4
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    Where to put the ECU, wiring, fuel pump, and a possible head switch . Not all heads have the upper 10mm intake bolt holes for the FI manifolds. Strangely all heads with FI mount holes do have the carb intake holes too! Not fair!
    Yeah, possible, but not simple...
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  5. #5
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    Hmm...I have F.I. and want "carbies". I used to run the early SU's on my 77 280 until I came back to CA and I LOVED them. Much easier to from F.I. to carbs. I'm with the others, possible but not simple or a one day job.
  6. #6
    Registered User Noddle's Avatar
    Member ID
    CZCC-12467
    Join Date
    Aug 2006
    Location
    Tasmania
    Posts
    495
    Default
    Find yourself a MR30 skyline, it has a L24e engine in it,
    swap the head if need be (NM47, or the whole engine), and all the fuel injection bits,
    I original did this on my 240K, but now I moved onto megasquirt II
    Nigel
    Datsun 240K
    Turboed L24, Megasquirt II, EDIS
    Current project
  7. #7
    Registered User
    Member ID
    CZCC-29489
    Join Date
    Jul 2013
    Location
    Brisbane
    Age
    30
    Posts
    26
    Default
    Quote Originally Posted by Noddle View Post
    Nigel
    I picked up a N47 Head with the EFi setup as for a 1 day job the car will be stripped for restoration early next year an a complete rewiring will be done so no issue
  8. #8
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    If you are going to all this trouble, I would look for a Maxima N47 head. They are not the same as a 280Z head.
    The 280Z N47 will lower your compression ratio (on a L24) where the MN47 will give you about 10:1 and you dont have to notch the cylinders for the bigger valves.
    Thats my 2 cents...
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
Thread Information
Users Browsing this Thread
Similar Threads
  1. How to tell which setup to use?
    By awolfe in forum Help Me !!
    Last Post: 03-27-2011, 09:55 AM
  2. Need a wiper motor for 1972 240z will 97 honda motor work
    By marantz2250b in forum Help Me !!
    Last Post: 02-18-2009, 01:51 AM
  3. Welp.. motor swap DONE .. proper turbo motor .. VIDEO and pics
    By PrOxLaMuS© in forum Open S30 Z Discussions
    Last Post: 05-06-2006, 05:24 AM
  4. Can any one tell me anything about this setup?
    By mugen1 in forum Engine and Drivetrain (S30)
    Last Post: 04-09-2005, 01:40 AM
  5. New setup, What I have, what do I need?
    By Capt Mark in forum Suspension and Steering (S30)
    Last Post: 03-03-2005, 04:25 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
