Results 1 to 9 of 9
Thread: Mounting of the float bowl to SU body
  1. #1
    Registered User
    Member ID
    CZCC-9012
    Join Date
    Aug 2005
    Location
    Oakland, California
    Age
    70
    Posts
    177
    Default Mounting of the float bowl to SU body
    On my SUs, the float bowl pivots pretty easily relative to the carb body. One, more than the other. It seems strange to me that the affixment would be at just one point, so that it can in fact pivot. Is there a rationale for that?
    More to the point, am I right that the bowl gets attached via a stud culminating in the nut marked in photo shown here? If so, how tight is it kosher to torque down that nut? (If I can even get at it without undoing the choke linkage.)
    thanks,
    Steve
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Mine have rubber on both sides:
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  3. #3
    Registered User
    Member ID
    CZCC-29289
    Join Date
    May 2013
    Location
    CA
    Age
    50
    Posts
    35
    Default
    steve - have a similar problem & mine are z therapy items < yr old. Need to see if they have rubber on both sides like Blue. What did you end up doing with yours ?
    wonder whether BruceP of ZT fame can chime in ?
  4. #4
    Registered User
    Member ID
    CZCC-9012
    Join Date
    Aug 2005
    Location
    Oakland, California
    Age
    70
    Posts
    177
    Default
    Mine have the rubber as well (thanks, Blue). The photo is something I grabbed off the Internet. On the looser bowl, at rear, I was able to tighten the nut somewhat, so I guess at this point, both bowls are fairly stable. I still think it's a strange set-up and would also like to hear what Bruce has to say.
  5. #5
    Registered User Stanley's Avatar
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Don't have an answer, but the ZTherapy video covers this topic in detail.
  6. #6
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
  7. #7
    Registered User
    Member ID
    CZCC-2139
    Join Date
    May 2002
    Location
    Salem Or
    Posts
    1,556
    Default
    I don't understand what the problem is. The mount is supposed to move as in a cushion mount. Tighten the nut over the lock washer over the flat washer til the nut bottoms on the shoulder of the bolt. If it's still loose it's because the rubber washer is worn out.
    Now on the float bowl side, if that orientation rubber is gooey it's taken a ride thru some carb cleaner. If not gooey, then get the nut tight and let 'er ride. SU had all that stuff done with metal bushings to insure the whole thing would vibrate to pieces.....
    Bruce Palmer
    Salem Or
    Sales@ztherapy.com
    www.ztherapy.com
    503-587-9800
  8. #8
    Registered User
    Member ID
    CZCC-9012
    Join Date
    Aug 2005
    Location
    Oakland, California
    Age
    70
    Posts
    177
    Default
    Thanks for the help, Blue and Bruce.
    Blue, I had missed that amazing set of photos. Extremely helpful. A lot of this stuff is not at all evident in either the parts fiche or the FSM, at least to me.
    The float-valve needle: I'm attaching a photo of one I just took out. No rubber tip. Do they invariably have one? Meaning this one is worn out? Or can there be a metal tip, no rubber?
    Looking at my photo showing the adjacent piece also, this whole assembly is a little different from the one in Blue's pic. Square vs. round for the piece that accepts the spring.
    I'm sure this is old ground; apologies.
ID:	67665   Click image for larger version.
  9. #9
    AZ Z Fan duffman's Avatar
    Member ID
    CZCC-9965
    Join Date
    Nov 2005
    Location
    Scottsdale, AZ
    Age
    65
    Posts
    580
    Default
    Some are rubber tipped, some are metal tipped.
    January 1970 240Z
    HLS3001399
Thread Information
Users Browsing this Thread
Similar Threads
  1. 3 screw su float bowl lid ear lengths
    By putmattaway in forum Help Me !!
    Last Post: 04-08-2013, 07:19 AM
  2. Gas Depth in Float bowl, when excluding float volume
    By hogie in forum Carburetors (S30)
    Last Post: 05-14-2010, 03:08 PM
  3. Float Bowl Vent
    By Xargon321 in forum Carburetors (S30)
    Last Post: 08-04-2003, 04:52 PM
  4. Float bowl and needle
    By Doehring in forum Carburetors (S30)
    Last Post: 07-21-2003, 06:27 AM
  5. Float bowl on '70-'71 SU
    By gpitman in forum Engine and Drivetrain (S30)
    Last Post: 12-08-2000, 07:43 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
