Results 1 to 16 of 16
Thread: 280Z Fuel line insulators
  1. #1
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default 280Z Fuel line insulators
    Hi club members,
    Most of my fuel line insulators have seen better days and due for replacement.
    Mike (nix240z) makes the sets for the 240Z, but they are different from the 280Z and only a few of the insulators are usable.
    I decided to make a set of fuel and brake line insulators for my 280Z. I had all the equipment (degassing tank, vacuum pump and pressure chamber) from making my amber turn signal lenses from the taillights so the extra investment would be my own time and the raw materials. To get a good mould I made the dummies out of aluminium and now getting ready to make the silicone moulds.
    Click image for larger version.
    The insulators will be made of urethane rubber shore 70A and post cured.
    The insulators will fit the 1977 280Z. I know there is some variations between the years, but I think its only in the brackets and an extra insulator after re-routing of the return line after Aug, 76.
    If any Club members are interested, I can make extra sets.
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  2. #2
    Registered User HaZmatt's Avatar
    Member ID
    CZCC-29861
    Join Date
    Nov 2013
    Location
    Colorado
    Age
    44
    Posts
    160
    Default
    I would definitely be interested in a set!
  3. #3
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Quick status report.
    I made an inventry of all the insulators on my 77 Z and checked it against the Nissan E-FAST parts manual.(same as Datsun 280Z Fuel Piping L28E )
    The quantity mentioned doesn't add up to what Im getting on my car.
    For example; I have 7 of the type D/E and the parts manual lists 9 (Pos 10 & 19) And I have 2 of the type F and the manual states 1.
    I don't think the years use different types, just the quantity is different. Ill make a list of all the different type and quantities needed for my 280Z.
    Chas
    Chas
  4. #4
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Its been a while, but finnally had some time to play with the insulators. This is the first run, but the first results still look promising.
    I made some photo's during demoulding and after a quick clean.
ID:	68891Click image for larger version.
ID:	68892Click image for larger version.
ID:	68893Click image for larger version.
    Now to cure them and see how they fit.
    Chas
    Chas
  5. #5
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    Hey Chas, they look good and I'm interested in a set of these.
    Bob
  6. #6
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Bob,
    Im still have to make the last moulds for the small (single) fuel line insulators 1/4" & 5/16" and I want to check how all these fit on my Z. Cured the first batch today so I might have time tomorrow to fit them and take some photo's.
    I having a bit of trouble trying to figure out how many are needed on the differeny model 280Z's They changed the lines around the tank area in August 1976. Mine is a 77 so I know what needed for the 77.
    The parts manual is not very clear, so it will require some input from pre aug 76 owners.
    I made some quick sketches to give people an overview of what goes where and how many are required.
    Chas
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	68932   Click image for larger version.
ID:	68933   Click image for larger version.
    Chas
  7. #7
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    Chas, mine is a 77 as well. Production date 05/77. Should be the same as yours. Keep me posted on how they work on your 77.
    Bob
  8. #8
    Registered User
    Member ID
    CZCC-23818
    Join Date
    Mar 2011
    Location
    Prairie Grove, Arkansas
    Age
    52
    Posts
    235
    Default
    Chas,
    I'm not sure how I missed this post earlier, but very nicely done. Mine is a 77 as well & when you get everything to your liking, I would be interested in a set.
    Lenny
    77 280z - test vehicle
    HellFire L28 digital ECU replacement janitor.
  9. #9
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Guys,
    Did some testing on the car today. Fitted some of the B1, B2, F3, F4, F5 and F6. They clamped up well and look clean and straight. They dont want to be any tighter because that will disvorm the brackets that hold them in place.
    Not easy getting decent photo's under the car.
    Only the F6 is not up to scratch. Its too tight and just doesn't look right. Im not happy with it so Ill make a new mould for a slightly smaller version. The F6 was the only one I didnt have any kind of good example to go with and it ended up being 1mm too thick. Doesn't sound like much, but it makes the rubber bulge out the sides.
    I took some before and after photo's. You can see whats left of the F4 and one of the F6's in the photo's.
    Photo index:
    DSC-1818 One of the original F6
    DSC-1819 Original F4
    DSC-1820 New F5 just in front of sway bar
    DSC-1821 New B2 on fire wall brake lines
    DSC-1822 Whats left of F4 and one of the F6.
    DSC-1823 is the best F5 from the originals.
    Ill try to get the new mould done this week and make some new F6's next week.
    Stay tuned.
    Chas
ID:	68959   Click image for larger version.
ID:	68960   Click image for larger version.
ID:	68965   Click image for larger version.
ID:	68961   Click image for larger version.
    Chas
  10. #10
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    Looking good so far. Now if you just had replacement lines......
  11. #11
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I spent the last two evenings under the car changing the rubbers insulators.
    They are all replaced except the curved one behind the engine for the two brake and cluth line. I tried to make the mold from the original, but it looked worse than the original so I need to made a dummy later this week.
    PITA to do now the suspension, diff and transmission are in the car. Dipping them in a contain of soapy water first made it a lot easy to position them.
    Here are some photo's of the last sets I fitted.
    Hope to have the set complete and able to reproduce next week for people interested.
    PS: Bob. I would love a new set of replacement lines. Just getting them fitted and still reasonably straight is what s holding me back. Its on the "to do list" or wish list might be a better name for it....
    Chas
ID:	69334   Click image for larger version.
ID:	69335   Click image for larger version.
ID:	69336   Click image for larger version.
    Chas
  12. #12
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    With the good weather we are having here, I have been side tracked a little trying to finish things in the back yard.
    Turning this
    Into this. Still not finished
    All the molds are done and I changed all the insulators (or what was left of the insulators after 37 years of aging) except the two small insulators on the clutch line under the brake booster. They are still in good condition.
    I had some trouble getting the F6 insulator to fit. In one bracket it was not very tight and the other it was too tight. The brackets are slightly different, but Nissan quotes the same insulator mmm. I ended up making a new mold and "adjusting" the metal bracket on the loose one to fit better. Its onlt 2mm smaller, but it makes a big difference. The insulator doesn't buldge out anymore.
    Ill take some photo's on the weekeind when I have more light.
    If anyone is interested in a set. Send me a pm.
    Chas
    Chas
  13. #13
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Spent the last week on the engine bay wiring harness. Cleaning all the terminals and replacing the rubber insulators on the connectors.
ID:	70007Click image for larger version.
    So far I have made the following for the front harness:
    5x Large round rubber (XB39) fits plugs for wiper motor, 2x Headlights, Voltage regulator and a spare connector near AFM.
    1x Small round with square hole (XB36) fits A/C vacuum solenoids
    3x Small oval shape (XB15) A/C Dryer, L+R front side indicators.
    3x Small round with triangle hole (XB2?) A/C Relay P/N:25230-N4205, Front turn signal indicators.
    One of my fusable link bases has suffered from overheating in the past and melted around the spade terminals. The other block is perfect which will make for a good master to copy. That will be my next challenge.
    Chas
    Chas
  14. #14
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Chas, Your insulators look great. My PO put new hardlines and insulators on my car so the rubber looks OK, but the hardline routing is a little screwy in spots. Not a big deal, but while I've got all the suspension torn off, it would be convenient to make changes now.
    Have you got a photo of the hardline routing back by the rear sway bar? I'm trying to figure out if those lines are supposed to go above or under the sway bar.
    Something just about a foot further forward than this one:
  15. #15
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    Hi Captain,
    I have some photo's of during the rear suspension rebuild. If its not clear, let me know and I will take some more photo's of the area.
    Chas
ID:	70139   Click image for larger version.
ID:	70138   Click image for larger version.
ID:	70137   Click image for larger version.
    Chas
  16. #16
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Chas,
    Those pictures are perfect. Again, answered my current question, and a few I hadn't asked yet.
    Thanks much for the help!
Thread Information
Users Browsing this Thread
Similar Threads
  1. fuel line and brake line insulator rubbers id help
    By nix240z in forum Wheels, Tires and Brakes (S30)
    Last Post: 02-10-2013, 02:27 PM
  2. Fuel and brake line rubber insulators
    By 240znz in forum Misc (S30)
    Last Post: 10-28-2008, 06:17 PM
  3. Brake line insulators
    By 2Forty in forum Help Me !!
    Last Post: 01-21-2007, 09:26 PM
  4. Hard line brackets and insulators help
    By hls30.com in forum Misc (S30)
    Last Post: 11-05-2006, 07:06 PM
  5. Brake line/Fuel line refinishing
    By kenz240z in forum Tech Pubs and HowTo
    Last Post: 12-11-2005, 09:55 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
