Results 1 to 27 of 27
Thread: Engine Bay black or body color?
  1. #1
    Registered User
    Member ID
    CZCC-30308
    Join Date
    Mar 2014
    Location
    Hagerstown, MD
    Posts
    10
    Default Engine Bay black or body color?
    Hello,
    I just picked up a 71 240Z series I with all matching numbers. The only thing not matching is the color. I have not decided what color I am going with because the red that was sprayed in the engine compartment area is still pretty good. I'm planning on using OR-15 to coat the bottom of the chassis and interior floors. Probably going to do the engine bay as well. Believe it or not, there's absolutely no rust holes or spots in the engine compartment but coating it prevents future rots if any develops. So my question is this......from a collectors point of view, is it better to match the body color or should I black it out with the rust preventive coating that dries gloss black?
  2. #2
    Registered User olzed's Avatar
    Member ID
    CZCC-20649
    Join Date
    Dec 2009
    Location
    Auckland. New Zealand.
    Age
    77
    Posts
    1,069
    Default
    Definately go with body colour for the engine bay.
  3. #3
    Registered User grannyknot's Avatar
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Black paint in the engine bay always looks like you are trying to hide something to my eye. Besides, if you are are considering it from a collectors pov then the whole car (engine bay included) should be painted whatever colour it was when it rolled off the assembly line. If you what to paint the car a different colour then just make sure you get the best job done that you can afford.
    Oh, and welcome to forum! You won't find a better place for Z info.
    Chris
    1970 240Z HLS30 01955 March/70
  4. #4
    Fumblin'Bumblin Z car fan
    Member ID
    CZCC-2858
    Join Date
    Sep 2002
    Location
    Atlanta
    Age
    51
    Posts
    111
    Default
    I was planning on white for my engine bay. Helps show leaks faster, and helps with heat, I think. There has to be a reason the NASCAR boys all have white engine bays.
  5. #5
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    Here's the original color codes, 70-78 Datsun Z Paint Code Gallery
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  6. #6
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    I would go with body color FWIW. Mine is black because of the PO. Was looking at what it would take to put it back to original and it would cost way too much.
  7. #7
    Registered User EuroDat's Avatar
    Member ID
    CZCC-26512
    Join Date
    Feb 2012
    Location
    The Netherlands
    Posts
    1,420
    Default
    I would go with the body colour. Thats the way it came from the factory and the way everyone expects it to be.
    I have the same problem as rcb280Z. My engine bay is 305 light metallic blue and the rest is some kind of red the PO painted. It a hassle to do the engine bay, but eventually I do it and the body the same colour.
    Welcome to the club.
    Chas
    Chas
    5/77 280Z HLS30 403100 with some modifications
    Original colour: 305 Light Blue. The PO changed it to Red
  8. #8
    Her Majesty the 26th 26th-Z's Avatar
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Default
    From a collector's point of view, don't use "OR-15".
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    http://home.earthlink.net/~cwenzel/index.html
    Go Gators
    Go Butler Bulldogs
  9. #9
    Registered User
    Member ID
    CZCC-30308
    Join Date
    Mar 2014
    Location
    Hagerstown, MD
    Posts
    10
    Default
    Thank you all for the welcome and suggestions. It sound's like I'll just be keeping the red paint. I have yet to check to see if it's actually Datsun paint code used by the PO so when I get new skin I'll have to somehow match it if it's not.
    26th-Z, why will OR-15 be bad? Do you recommend something else in lieu of it? I know I want to seal the undercarriage and interior panels for sure just to prevent future rusts.
  10. #10
    Member ID
    CZCC-4148
    Join Date
    May 2003
    Location
    Sarasota, Florida
    Age
    67
    Posts
    3,854
    Default
    Tardis, I'm assuming you are talking about POR-15. My comment comes from a "collector's point of view". I doubt any "collector" is going to purchase a car covered up in POR-15; I wouldn't. POR-15 does not stop the rusting process. It is an encapsulator, meaning that rust may continue, unnoticed, beneath a material that is near impossible to remove. I suggest that you clean out the body seams, reseal them and paint the surface - just as it was done at the factory 40 years ago.
    Enjoy the Ride
    HLS30-00026
    HLS30-00027
    Go Gators
    Go Butler Bulldogs
  11. #11
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    If POR15 is not applied exactly the way they recommend, then, yes I agree, it can hide rusting metal.
    But if you follow the directions with no short cuts, well I haven't found a better coating.
    As with all coatings, prep is everything.
  12. #12
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    In my area, all engine bays are blacked-out, because they're all vintage muscle cars.
    I like it black, because it hides some dirt, the black wire bundles are less visible, and if I need to touch up the paint, I have a few spare cans.
    I think it highlights the blue engine block with all the cast and polished aluminum parts.
    Drive Responsibly.
    enjoy classic Rock music.
  13. #13
    Registered User
    Member ID
    CZCC-10869
    Join Date
    Feb 2006
    Location
    Irvine, California
    Age
    50
    Posts
    755
    Default
    Quote Originally Posted by TomoHawk View Post
    This. If you have a stock car an engine bay painted the stock color is fantastic. However, once you start modifying anything in the engine bay having a black engine bay that you can repaint yourself is invaluable.
    -Bo
    1972 240z - Not original and still not done.
    "Something wicked this way comes...."
  14. #14
    AZ Z Fan duffman's Avatar
    Member ID
    CZCC-9965
    Join Date
    Nov 2005
    Location
    Scottsdale, AZ
    Age
    65
    Posts
    580
    Default
    Black works for me.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    January 1970 240Z
    HLS3001399
  15. #15
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    ^ That works for me too, beautiful.
  16. #16
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    tastefully dunn, duffman.
    Drive Responsibly.
  17. #17
    Member ID
    CZCC-9965
    Join Date
    Nov 2005
    Location
    Scottsdale, AZ
    Age
    65
    Posts
    580
    Default
    Thanks, like to accentuate the bling with the black background!!
    January 1970 240Z
    HLS3001399
  18. #18
    Registered User
    Member ID
    CZCC-30308
    Join Date
    Mar 2014
    Location
    Hagerstown, MD
    Posts
    10
    Default
    Quote Originally Posted by duffman View Post
    Black works for me.
    Did you use engine paint or body paint?
  19. #19
    Member ID
    CZCC-9965
    Join Date
    Nov 2005
    Location
    Scottsdale, AZ
    Age
    65
    Posts
    580
    Default
    Body paint, painted by professional (Sakura Garage in Tempe, AZ). Has been very durable and minor spills easy to wipe up. Removed engine and drivetrain last year, had it done then.
    January 1970 240Z
    HLS3001399
  20. #20
    Member ID
    CZCC-26437
    Join Date
    Feb 2012
    Location
    Toronto
    Posts
    698
    Default
    Yeah, that really shows. My comment in post#3 is mostly how I feel about rattle can paint jobs. I see so many of them at car shows, just makes me shake my head.
  21. #21
    Registered User Travel'n Man's Avatar
    Member ID
    CZCC-14147
    Join Date
    Mar 2007
    Location
    Western North Carolina
    Age
    60
    Posts
    1,486
    Default
    I second the black engine bay - if it is done correctly - but it is totally owner preference
ID:	70609Click image for larger version.
    Life's a journey; enjoy the ride!
    Mitchell
    L28 - N42 Block w/Flat tops - N42 Rebello Head & Cam - Triple 40 PHH Mikuni's - Headers - Recaro Seats -
    R180 3.9 Diff - Close Ratio 5 Speed - Toyota Vented Brake Upgrade w/ Porterfield High Performance Pads & Shoes
    1972 Datsun 240z
    HLS30-75040
  22. #22
    Administrator bpilati's Avatar
    Member ID
    CZCC-844
    Join Date
    May 2000
    Location
    VA
    Age
    61
    Posts
    1,483
    Default
    Body color, in my opinion.
    Bryan Pilati
    1971 Datsun 240Z (8/71; 920 paint)
    IZCC #583; TZCC #16; CZC #110
    I'm never serious unless I should be.
  23. #23
    Jim Arnett jfa.series1's Avatar
    Member ID
    CZCC-22303
    Join Date
    Aug 2010
    Location
    Richardson TX
    Posts
    764
    Default
    The previous posts with a black engine bay are really well done. Here's another vote for sticking with the factory approach.
Name:	18. Painting Complete.jpg
    Jim Arnett
    HLS30-15320 12/1970, original owner
    L24-020208 (original)
    IZCC Original Owner Registry #53
  24. #24
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    55
    Posts
    1,895
    Default
    Body color for sure. Black can look good, but it is usually hiding something, so when Z experts see the black engine bay, that's what they immediately think.
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  25. #25
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    What would it be hiding?
    Drive Responsibly.
  26. #26
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    67
    Posts
    1,746
    Default
    Engine bays are often painted black to hide a color change or stained / faded body color paint.
    Is it a crime? No, and it can look very nice. Will it potentially hurt the resale value of the car? Probably.
    My vote falls in the body color camp.
    However, if I were refreshing a car to be my daily driver, I would using black paint in the engine bay. It's easy to apply so that it looks good and is a way to save money by doing it yourself. I would not POR-15 it though for reasons stated above. I feel the same about undercoat. Mine came to me undercoated, (from the dealer according to the paperwork), but I wish it wasn't.
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  27. #27
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    To know if a black engine bay is covering up something, you'd have to look closely at the rest of the vehicle.
    For a DD, undercoating would be great. But for a sporty car driven occasionally or for show, undercoating works against you.
    Drive Responsibly.
Thread Information
Users Browsing this Thread
Similar Threads
  1. any color other than black?
    By logan1 in forum Body and Paint (S30)
    Last Post: 01-13-2011, 08:14 PM
  2. Found the body color tonight
    By carguyinok in forum Body and Paint (S30)
    Last Post: 03-21-2009, 01:34 AM
  3. Body Panels - MSA vs Black Dragon?
    By ConchZ in forum Body and Paint (S30)
    Last Post: 12-15-2008, 01:29 PM
  4. engine color
    By NY " Z " in forum Body and Paint (S30)
    Last Post: 07-06-2006, 06:58 PM
  5. Starting body work soon, looking to do black trim....
    By sonofzzzap in forum Body and Paint (S30)
    Last Post: 03-01-2005, 05:17 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
