Some suggested to me if the timing was off that could cause this problem. I say again. If the fuel pump never stops running how is anything going to stop fuel from entering the filter.
I have been trouble shooting my 78 280z for about 3 weeks now. I have replaced the fuel pump with a msd 2225, new air flow meter. new clear fram g3 fuel filter at the engine and the tank before the fuel pump. new thermostat. new temp sensor, cleaned the injectors and installed new o rings. new fuel pressure regulator new vacuum line to the regulator and distributor. new fuel line and clamps from the tank to the rail all new fuel line.I have done every last test on the ecu with my multimeter according to the fsm. I also have a fuel pressure gauge just after the filter at the engine. I can charge the fuel system by running the pump only. the filter at the engine fills up and the gauge reads a solid 40 psi when pumping. Start the car fuel pressure with the car running is 35-36 So Im good there. It will idle for quite a time like this or drive for about a mile. You can sit and watch the fuel slowly drain out of the filter at the engine. eventually draining almost completely out the pressure drops of course and the engine dies. If I disconnect the vacuum from the fpr the pressure surges right back to 36 and stays there. Fuel will come back into the filter, but after a few minutes it will just drain out again. although with the vacuum line disconnected from the fpr even though there is no fuel in the filter the pressure remains on the gauge. With the vacuum connected the fuel pressure drops with the loss of fuel from the filter. either way the car dies. As I said i have a clear filter at the fuel tank. There's not a spec of dust in the filter so it doesn't seem to be that anything is in the tank. I also have about 12 gallons of gas in the tank. When the pressure just starts to drop i can get under the car and hear the fuel pump running so i know its not shutting off. As a matter of fact when the engine sputters to a stop the pump runs a few seconds after the engine dies from no fuel. Please Help. I am at a complete loss. I have gone through all the trouble shooting and just can't figure it out. I am in the army up in Ft drum NY and i have called 10 different mechanics. No one will touch a car this old up here. I have read and read and read other peoples problems with fuel . Nothing matches this issue I can find. even if the ecu or fpr was malfunctioning. If the fuel pump is running. fuel should be in the filter should it not???
Unhook the fuel line from the top of an injector at the rail and put another short piece of hose on the rail, secure it in a jar or bottle or something. Crank it over and see what comes out. Sounds like a vent line or something is clogged up.
Oh yeah! Could a fuel filter arrow be pointing the wrong way? I've done that before.
1972 240Z #918 New Sight Orange
1977 280Z #305 Light Blue Metallic
1972 240Z #110 Persimmons Red
Yep ive done that and fuel comes out fine. the arrows are definately pointing the correct direction as it says flow with the arrow
Matt, what sort of filter are you using? The OEM design of filter is quite large, and I've not seen a clear one of that size. There are some clear, low-flow filters for carburetors. When running one of those on a carbureted 318, there were times the filter appeared to be empty, when in fact it just had an air pocket. It was still passing fuel just fine. That said, an OEM fuel filter is oriented in such a way that any air inside the filter should be purged. You would see nothing but fuel in the filter, if you could see through the metal can.
I'm guessing your issue is simply one of the fuel pump fading. As your pump is new, I'm guessing your electrical connections aren't in good shape. You should trace all your connectors from the fuel pump relay to the pump. Check that the connections are clean and solid (and haven't charred/arced). After cleaning, grease each connection with dielectric grease to preserve it.
First stop is the fuel pump relay connector, inside the big, black box on the passenger side of the engine compartment. The blue/green wire leads to the pump. Second stop is the big wiring tree connector (there are two of them) just inside the passenger firewall. This is where I had a melted, charred connector. I snipped out the blue/green wire and connected via a bullet connector. Last stop is the fuel pump.
Also check your ground, which runs from the pump, through a bushing in the floor, and to the interior of the cabin.
FAIW, 35-36 psi running pressure and 40 psi non-running pressure is a bit high. Non-running pressure (during cranking, or also with vacuum line disconnected) should be 36. Idling should be about 29 if your engine is running efficiently -- higher if it's not. The 4-5 psi differential you're getting between non-running and running should be more like 7 psi. This tells me your engine is either running rich or lean. If your fuel pressure gauge is accurate, your high pressure might have your engine running rich. That would indicate a fuel pressure regulator issue. It's more likely your gauge is off, though.
My last three sports cars while I still owned all three:
2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
1966 Ford Mustang Coupe (sold)
1978 Datsun 280Z (enjoying very much)
It may be that the things you listed are not all related.
Following FastWoman's logic, what happens if you just let the pump run alone for the same amount of time it would take the engine to die, but without the engine running. Is the behavior the same? That would separate any engine heat, injection issues from the general weirdness. Just let it run, it won't hurt it, that's what it does when you're driving.
And are you running a stock fuel rail and return line?
1976 280Z, with some minor modifications
Thank you very much for the suggestions FastWoman. I will check these things first thing monday morning as I left the car at a shop for the weekend trying to decide what to do with the car. The fuel filter is a fram g3 as I have read many z owners using on there cars so i figured it was ok. I just wanted something clear to see if there was something in the line that was obvious. I still have the original filter which is new from the previous owner who could not make the car stay running. Also I cleaned up the connectors at the pump. with electrical cleaner and a brass brush but I will follow the line up on Monday as you suggest. The interesting thing I thought to is when i take off the vacuum from the fpr the gauge reads a perfect 36 and does not waver even when hitting the throttle and as the filter empties of gas it continues to read 36psi. Now if as Im whatching the fuel drain from the filter I connect the fpr back up the pressure drops with the emptying of fuel. Regardless the fuel runs out and the engine dies. Again I say though when the engine quits the fuel pump can be heard running. So monday i will check connections and put the original filter back on for starters. Again thankyou so much I have no way of getting this thing done except my self and I feel like its getting beyond my skill level. At least my ability to figure it out. As I have checked and replaced or cleaned everything i can see to do. Its not that I can't work on or replace something its just I have run out of ideas of what to do.
I do run the pump after the engine dies to get the engine started again. The fuel pressure reads around 40 and the filter refills only about one quarter the way and won't get any fuller than that. but the pressure remains at 36 when i release the key. It is a stock rail and return and all my rubber fuel lines are new with new clamps
I think that Fast Woman may be right and you have weak pump volume. But I wonder if the volume is low because you're pulling air in to the pump. There's enough gasoline getting in to keep a seal in the pump mechanism and let the pump work but it's pushing mostly air instead of fuel. Or the fuel is sitting at the bottom of the system, back-flowing in to the pump to let it hold pressure. Maybe. Check your fittings in to the pump and the filter and its fittings.
Or a quick test would be to disconnect the inlet hose to the pump and run a hose without a filter to a gas can. Make sure the hoses seal tightly.
If I were you, I would rule out the pump as Zed suggests. You can "hot-wire" it by running a wire from the battery's (+) post to the (+) post of the fuel pump (blue/green wire). You don't have to disconnect the existing wiring.
Before you fire up the pump, connect a long piece of rubber tubing to the "return" line of your fuel rail (coming from the outlet of the fuel pump regulator and sweeping around the front of the engine -- the tube other than the one connected to the fuel filter.
Now fire up the pump. Your pressure should be 36 psi, and you should have a steady flow of fuel coming out the end of the hose. You can pour it into a fuel can, or if your hose is long enough, you can dump it right into the filler neck of your gas tank. Just watch it for a while to see what happens. If you've got the same fuel flow and pressure after 15 min or so, then your pump and filters are probably fine, and we search for other issues (like electrical).
Ok Im on it first thing monday. I going to get my fuel line today. and do both. Run the pump from a can and run it directly to the return line at the fuel rail coming off the fpr.
BTW, I note that JRSGTS (on this list) is a pro mechanic specializing in classic cars, located in Greenwich, NY, about 3 hr from you. I realize that's a bit of a hike, and I suspect you can tackle this issue on your own. However, he's there if you need him. He's not a Z specialist, but he's currently working on a customer's Z and is coming up to speed quickly -- apparently eager to learn.
There may be other mechanics closer to you who would be willing/able to work on your Z. In fact you might find some old-timer mechanics at your local Nissan dealer. The PO of my Z lived in a fairly remote part of Virginia, but he was able to find expertise at the local dealership. There was one mechanic there who cut his teeth long ago on the Z and did all his work. I've had a few nice conversations with him, both before and after the sale.
I vaguely remember being at another Nissan dealer's service department inquiring about a fuel pump check valve. One older mechanic shouted over to another and asked, "What's the part number on those old Bosch check valves?" The other mechanic rattled off the number from memory!
I mention all this not because I don't think you're up to solving this fuel delivery problem. I think you are. Rather, I saw JR's post on another thread and remembered you -- both of you from the nether-regions of New York.![]()
Ok cool thank you. I am ending up having to go to the field for the next couple of days so I wont be able to tackle anything until thursday. But I convinced my boss to let me take 2 leave days so i can take my car to the auto craft center on post here. Soooo Im going to have 3, 8 hour days to whip this cars butt lol..
I just want to say thank you again for the ideas and suggestions.. I can't wait till thursday when I have some solid 8 hour periods to tackle each trouble shooting idea.. I so want to drive this car!!!!
I did it I did it I did it!! Bang my head against the wall.. I drained the tank and the previous owner sure enough cleaned the gas tank out. However.. switched the outgoing line for the returning line.. AAAAARRRRRGGGGG lol.. Heat wasn't working connected up the disconnected vacuum lines... I have heat!! Replacing my suspension bushings tomarrow.. Bring it !! Thank you Thank you again Fast Woman and Zed Head. I wouldn't have started over if it wasn't for you too pushing me to start from the begging..I love this car so much. I know Im old too but when I was a kid my dads best friend had one of these and i love it to this day.. Selling my 97 suburban Monday. My z is my daily driver.. Time Now..
Ok now all of a sudden i have no spark at #2 and #3 cylinder.. any suggestions. Im about to go check my coil with a multimeter. Wires plugs cap rotor all new. took a plug from one of the cyliders that fires and put it in the one that didn't still no spark so i know the plug is good.
Check the inside of the dizzy cap boots & the spark plug boots to see if the connectors have pulled back. If this is a consistant no fire in two cyls. it is isolated to the wires, cap, rotor or plugs all of which are new. Swap #1 & #2 plug wires & see if the miss changes to #1. This problem is usually a poor elec. connection, especially when you have new components.
ok i had a crappy connection at my coil the wire just didn't fit snug.. Still though. I run the engine and its really rough. It'll rev fine but put it in drive and nada.. So back to the plugs. Still now when i take off 2 and 3 I hold them close to the plug and i can hear it tic tic tic.. but pull it off and no change in the way the engine runs.. I pull off 1 4 5 or 6 and the engine almost stalls out.. 2 and 3 come off nothing happens at all. I swapped 1 for 2 plug and 1 for 2 wire. still no change 1 stilll makes the engine stall and 2 disconnected does nothing.. I tested all the wires and coil wire for continuity. good to go. It doesnt matter where i adjust the timing. other than the engine running faster or slower. theres just no power when you put it in drive. Which stands to reason if 2 and 3 arent firing off its only running on 4 cylinders
going out to double check my air gap not sure if that could do anything but ill check.. it says 0.2 to 0.4 mm in the fsm. My timing is good a t 10 well my car likes about 12 13 btdc better but its within a few degress non the less
Sounds like the injectors aren't opening. Try swapping injector plugs from a cylinder that works to one that doesn't. It's batch fire so it doesn't matter which is where. Also, try the long screwdriver stethosocope trick to hear the difference between an injector that's opening and one that's not.
The tic tic sounds lindicate the plugs are firing. I'd pull #2 or 3 plug & ground it to actually see what, if anything, is going on. Compression? Recheck the valve adj. & compression to eliminate that possibility. That leaves FI. I'm an SU guy but basic injector function must be easy an easy test. I'd guess disconnecting the injectors one at a time.
ok rgr that. going out to check for injector tic . tried it earlier just to verify they all are clicking but i did notice a distinct difference in some. but I wasnt at the 2 and 3 problem yet so i need to recheck to see if its those to. also i cleaned the 2 and 3 spark plug back to new condition to see if theres any fuel on them or if there dry.
ok number 2 is definately not clicking.. 1 is loud and proud so unhook the plug put it on 2 and nothin back to 1 loud clicks.. back to 2 nothin.. 3 is clickin but not like 1 is. and again disconnect 1456. all want to stall the engine.. so its got to be the injectors? at least 2 for sure there just nothing at all
I've messed with a few old stuck injectors and found that a rap with a light weight wrench or a screwdriver blade will break them free sometimes. Nothing to lose. Try to hit the solid metal base if you make an attempt.
If you get to the point where you're considering replacing them, you might also jump the two pins at the injector with a full 12 volts. A quick jolt or two won't burn anything up but the higher current flow might create a stronger magnetic field to pop things free (although I'm not sure how much stronger). Don't short your wires, there's not much room in there. Connect the wires at the injector and make sure they're clear then tap the other end to the battery.
Edit - apparently the magnetic field strength is proportional to current so a 12.6 volt jolt might have an affect.
Edit 2 - just a note on why they might get stuck. It's a tight fit inside and the gasoline flows past the metal core of the solenoid plug and the pintle pin which seats in the pintle orifice. Dried or old fuel leaves gooey varnish behind, gluing things together. If you get it free, let it run for while and rev it up to get clean gas through to clean things up.
Thanks guys no ****.. 2 and 3 not spec of fuel coming out when pulsed by hand with carb cleaner.. tapped them cleaned again and again.. cars running great!! Hell yea time for a shower and a cruise..
Congrats! Sorry I wasn't here for you yesterday, but it looks like everyone else got you running! I hope you had a great victory cruise. Whenever conquering a problem, don't forget to do the ritual snoopy dance around your car!![]()
Well crap.. running like garbage again.. number 2 injector is clogged again. So i just ordered a new injector. number 3 is still doing great when you put the screwdriver to the 2 injector you can hardly hear in clicking as apposed to the others are distinct click click click. did I mention the idiot who cleaned the tank used airhose coming frim the tank to the pump. Some peoples children uhhg.
Bookmarks
