Anywhere from 10 to 30%. The numbers are not directly comparable. Some of the better chassis dynos are very repeatable but none approach the accuracy of an engine dyno that is certified to either the SAE, JIN, or DIN specs.
How many HP does a person loose from the crank to the wheels? All the Dyno results that I have seen recently are to the wheels..........
Life's a journey; enjoy the ride!
Mitchell
L28 - N42 Block w/Flat tops - N42 Rebello Head & Cam - Triple 40 PHH Mikuni's - Headers - Recaro Seats -
R180 3.9 Diff - Close Ratio 5 Speed - Toyota Vented Brake Upgrade w/ Porterfield High Performance Pads & Shoes
1972 Datsun 240z
HLS30-75040
John Coffey
http://www.bentonperformance.com
Every dyno result you see is likely from a chassis dyno (to the wheels), unless it was on an engine dyno (e.g. Rebello).
It's also completely useless to compare numbers from different dynos. Extrapolating "crank" numbers from chassis dynos is equally useless. I've seen as much as 50-60hp swings from the same car, with absolutely no changes made besides it being on a different dyno. A good example is an FC RX7 that came through our shop and pulled 125whp. At another dyno, it hit 175hp. That's a 40% difference!
2/74 260Z
Bookmarks
