Results 1 to 11 of 11
Thread: Another problem :(
  1. #1
    Registered User kjphilippona's Avatar
    Member ID
    CZCC-20308
    Join Date
    Oct 2009
    Location
    Dothan, Alabama USA
    Age
    61
    Posts
    297
    Default Another problem :(
    Got my battery changed out so that I could track down my wiper, blower motor and radio gremlin when I noticed over half of my injector blocks were cracked. I have a new set on order but wanted to know if it was safe to drive the car until the new set comes in.Click image for larger version.
    4/77 280Z
    HLS30-387956
    KJP
  2. #2
    Registered User
    Member ID
    CZCC-4044
    Join Date
    Apr 2003
    Location
    Denver
    Posts
    1,008
    Default
    my '82 turbo blocks would leak when cracked. Not sure if it's a problem with non turbo. Make sure you don't over tighten the new ones when you replace them.
    things will only bother you if you let them.
    82 280zxt 4 spd auto
    73 240z--lsd, cv axles
    short throw info
  3. #3
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    It shouldn't be a problem. The screw holes are still intact and will hold the pieces in place. Like Darrel said, they don't need to be very tight. Once the screws have pressed the injector seal down in to the hole, and squeezed the insulator and metal top piece together and down to the manifold (no gaps), there's little benefit to being tighter.
    1976 280Z, with some minor modifications
  4. #4
    Z geek at large FastWoman's Avatar
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    I think my blocks were cracked when I replaced them, and they didn't leak. There's an O-ring that seals the tip of the injector in the manifold's hole. Assuming you're not running a turbo or supercharger, there will always be a vacuum inside the manifold, so IF there is any leakage of any sort, it will be from the outside to the inside. Thus any stray fuel would be kept inside the intake manifold. So in my non-expert estimation, there is nothing unsafe about your cracked insulators.
    My last three sports cars while I still owned all three:
    2001 BMW Z3 Roadster 3.0i soft/hard top (sold)
    1966 Ford Mustang Coupe (sold)
    1978 Datsun 280Z (enjoying very much )
  5. #5
    Member ID
    CZCC-20308
    Join Date
    Oct 2009
    Location
    Dothan, Alabama USA
    Age
    61
    Posts
    297
    Default
    When I change the blocks, will I have to replace the injector o rings ?
    4/77 280Z
    HLS30-387956
    KJP
  6. #6
    Member ID
    CZCC-19635
    Join Date
    Jul 2009
    Location
    Hampton Roads, VA
    Posts
    2,787
    Default
    I don't know that you'll HAVE TO change them. I think mine came off intact and could, in theory, be re-used. However, I think it would probably be a good idea. I found a complete O-ring kit on ebay for maybe $9 at the time.
  7. #7
    Member ID
    CZCC-20308
    Join Date
    Oct 2009
    Location
    Dothan, Alabama USA
    Age
    61
    Posts
    297
    Default
    Thanks
    4/77 280Z
    HLS30-387956
    KJP
  8. #8
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    I've just spent the last couple of weeks looking at injectors and seals and mounts. I've re-used all of the seals before, both the small ones and the big ones, but wold probably not re-use the bottom ones again if I ever have a choice in the future. The mounting system is designed to compress the bottom seal in to the manifold to a specific distance. Then it sits there getting baked over time and tends to lose its elasticity and take a set. So it won't have the same squishiness if re-used, and might not seal completely. If they still seem rubbery and elastic, they'll probably be okay. Looking at your picture, I would guess that they'll be rock hard.
    The big top rubber ring though, is just a vibration insulator and locator. I would reuse that one unless it was rock hard. they're a pain to get on and off.
    When you pull the injectors make sure the seal doesn't stay in the manifold. You might think you lost one but it will still be stuck in the hole.
    And when you're removing the fuel rail don't forget about the mounting bracket to the intake manifold bolt. It's hard to see when standing at the fender, it's under the rail, and many rails have been bent by people pulling before taking that last bolt out.
  9. #9
    Member ID
    CZCC-20308
    Join Date
    Oct 2009
    Location
    Dothan, Alabama USA
    Age
    61
    Posts
    297
    Default
    The injectors, blocks and o-rings are only a couple years old. I only hope I can leave the injectors connected to the fuel rail, I will get a set of o-ring on the way also
    4/77 280Z
    HLS30-387956
    KJP
  10. #10
    Registered User siteunseen's Avatar
    Member ID
    CZCC-24724
    Join Date
    Jul 2011
    Location
    Alabama
    Posts
    1,967
    Default
    I noticed the newer hex head screws. That may be how the holders got cracked, too much righty tighty.
    1972 240Z #918 New Sight Orange
    1977 280Z #305 Light Blue Metallic
    1972 240Z #110 Persimmons Red
  11. #11
    Registered User ZCurves's Avatar
    Member ID
    CZCC-7312
    Join Date
    Nov 2004
    Location
    Spring, Texas USA
    Age
    56
    Posts
    1,052
    Default
    Just replaced mine, see post with part numbers below:
    http://www.classiczcars.com/forums/f...tml#post454170
    Andrew (ZCurves)
    1978 Coupe - HLS30-440105
    Spring, Texas USA
    pro deo et patria
    My Albumz
Thread Information
Users Browsing this Thread
Similar Threads
  1. Front solution and problem; rear problem
    By Richard McDonel in forum Suspension and Steering (S30)
    Last Post: 03-02-2013, 05:22 PM
  2. Replies: 1
    Last Post: 11-04-2012, 05:34 AM
  3. Starting problem and possible carbon buildup problem
    By Project_Black in forum Help Me !!
    Last Post: 04-27-2011, 06:37 PM
  4. Window roller guide problem and headlight problem
    By Richard Oben in forum Help Me !!
    Last Post: 01-12-2011, 11:26 PM
  5. Vapor lock problem solved... Next problem
    By nuteman in forum Help Me !!
    Last Post: 08-23-2004, 05:35 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
