Results 1 to 6 of 6
Thread: Fusible Link Diagram
  1. #1
    1978 280Z (stock) TomoHawk's Avatar
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default Fusible Link Diagram
    I will be re-labeling my fusible link covers soon, and I would like to pinpoint the purpose of the four fusible links on the right-hand shock tower.
    I saw an informative diagram somewhere, but I can't find it again. I also have the usual simple diagram from AltlanticZ techtips showing which color goes to which terminals, but I'd like more specific details.
    I know one fusible link is solely for the headlamps, but the other three are, for example, the ignition relay, the EFI interlock relays, and the alternator charging to electrical devices (accessories like the radio, gauges and inferior lamps.) One is what you would call the B+ to the ignition switch, for example, but I didn't note what the others go to.
    Can anyone help? Having specific information on the fusible links helps to diagnose any electrical problems.
    Drive Responsibly.
    enjoy classic Rock music.
  2. #2
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  3. #3
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    Thanks, I've seen that hundreds of time, Blue. It doesn't discuss the 1978 model, nor does it mention exactly where each fusible link goes.
    Drive Responsibly.
  4. #4
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Here is the 78 FSM electrical wiring diagram. Use it and a multimeter to trace. I had to do the same for my 77.
    Click image for larger version.
Name:	78schem fusible links.gif
  5. #5
    Member ID
    CZCC-2169
    Join Date
    May 2002
    Location
    NorthCoast, Ohio
    Age
    60
    Posts
    6,497
    Default
    This diagram gives a slightly better indication of each fusible link's purpose, but you cant tell where the information is from.
    Drive Responsibly.
  6. #6
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    That is similar to what is in the 78 wiring diagram.
    You can always disconnect 1 at a time to see what drops. It looks like the black FL feeds the fuel gauge and hazard light on the schematic. You can follow the wires from each fusible link then use the disconnect and multimeter testing to verify.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Fusible link
    By scotts pearl in forum Electrical (S30)
    Last Post: 04-24-2014, 03:52 AM
  2. Fusible Link Connectors
    By ZCurves in forum Electrical (S30)
    Last Post: 05-31-2012, 04:51 PM
  3. Fusible Link for a 240 Z
    By beandip in forum Help Me !!
    Last Post: 08-20-2009, 07:55 PM
  4. Fusible Link Upgrade
    By Alan Pugh in forum Electrical (S30)
    Last Post: 05-14-2005, 06:58 AM
  5. fusible link
    By malder in forum Electrical (S30)
    Last Post: 04-16-2003, 07:36 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
