I was having a bugger of a time figuring out why I had lean ping (sounds like shaking a spray paint can) under load until I found that my front crab's float level was way lower than the rear. All these years I've been adjusting my fuel mixture knobs the same amount, I forgot to check them individually for mixture. Try the tips on this page: Technical Information Page ..... Carburation
The technique recommended there for checking mixture by raising the lift pin in the underside of the dashpot mount is where it clicked for me. That's when I found that my front carb needed over 2 full turns out more than my rear carb needed.
I still have to do something about my float levels, but this helped so much its not even funny.
Bookmarks
