Results 1 to 25 of 25
Thread: 280z Suspension Upgrade
  1. #1
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default 280z Suspension Upgrade
    been amassing parts for a suspension re-vamp and reading many posts (thanks for the tech tips Blue!) parts list is as follows:
    · Eibach progressive lowering springs
    · Staag struts
    · KYB boots
    · Ball/socket TC end upgrage
    · New rubber TC bushings
    · MSA performance swaybar kit
    · Speed-bleeders for the brakes (love these things!)
    got clearance to spend the weekend in z-land, and set to getting it done.
    Click image for larger version.
Name:	Ready to Start.jpg
    car up on stands, wheels off and I figured i’d try to avoid taking off the control arms. front was easy enough, with the sway bar out of the way it was just a matter of disconnecting the tie rod ends, unhooking the brake line clips and i was able to tilt the entire shock assemblies out through the wheel wells. this way i could undo the gland nut and top-of-shock assembly nut without a vice. the hardest part were the tie rod ends – stuck, stuck, stuck. bought a crowsfoot separator, and they popped off with a little help from a 5lb. hammer.
    rear was a little trickier, but it just amounted to unhooking the half shafts at the wheel, and one control arm pivot clamp (the rearmost) and loosening the other and the control arm hung down enough to swing the assembly out of the wheel well.
    the original struts were toast – no gas left, fluid leaking, useless.
Name:	Strut Comparison.jpg
    the rear boots were filled with crumbled purple stuff, i believe it was the disintegrated bump pads. the staag struts seem just fine – no, they are not adjustable, track-ready units, but they were shockingly affordable and fit perfectly. the kyb boots were pretty cheap - plastic vs. the oem rubber ones. i actually wound up cleaning and re-using the stock boots on the rear, mine were in great shape.
    the swaybars were simple and installed w/little drama – only tricky part was have compressing the pin bushing sandwich enough to get the nut on the end. wound up using a c-clamp to get it done. needed to split the exhaust at the center flange (between center resonator and rear pipe) to get clearance for the rear swaybar removal/install, but no biggie. nice quality kit, very happy with it.
Name:	Swaybar Front Comparison.jpg
ID:	71723 Click image for larger version.
Name:	Swaybar Parts Comparison.jpg
    had an “oh, sh*t” moment when i took the eibach springs out of the box – the rear springs are waaaay shorter than the stockers, so much so that they don't even touch the perches until the car is lowered down. i thought i had been sent the wrong kit, but a few looks online and apparently that’s the way they are.
Name:	Spring Comparison.jpg
    put her all together and was very disappointed to discover the rear was way lower than the front, and the handling was crappy – harsh, jumpy, not good.
    so i decided to go the old-school route and cut a couple of coils off the stock rear springs. 5 min. w/an angle grinder and all was good. took me longer to clean and paint them than to cut them.
Name:	Spring Cut Lines.jpg
ID:	71727 Click image for larger version.
    now she sits level and the feel is perfect for me. the swaybars really help – zero body roll and she just eats up corners now!
Name:	Just Right.jpg
    while i had the wheels off, i cleaned out my brakes and installed the speed-bleeders. they are bleeder fittings with an internal check-valve, so you can bleed the hydraulics without a helper - i have these on my motorcycles and they literally make bleeding/changing fluid a breeze.
Name:	Speed Bleeders.jpg
    now for the “embarrassing shade-tree mechanic’s story”:
    later, when i was fiddling w/trying to get the shock assemblies back in, i unwittingly squatted down onto the can of brake cleaner, depressing the rattle-can nozzle w/my posterior and sending a soaking charge of brake cleaning fluid into my crotch. let me tell you first-hand: brake cleaner to the satchel burns like hell!! i quickly dropped a serious “sag” and waddled into the house to clean off and change hooting like a scorched owl – thank god nobody was around! yikes...
    anyway, i'm extremely pleased with the results - the z handles sooooo much better and the ride is still DD comfortable.
    anybody looking for a pair of eibach rear springs???
    '78 280z - Daily driver/work in progress...
  2. #2
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    rofl good stuff!
    The suspension will settle after some driving.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  3. #3
    Registered User Sean240Z's Avatar
    Member ID
    CZCC-6478
    Join Date
    Apr 2004
    Location
    McLean, VA, USA
    Age
    48
    Posts
    232
    Default
    Lmao! Great detailed write up.
  4. #4
    Boat Anchor Repairman Captain Obvious's Avatar
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Quote Originally Posted by rossiz View Post
    Hahahaha!! I get it. "shockingly affordable" I bet you didn't even plan that!
    So you pulled inserts out? You were thinking that you might have the original factory strut guts, but apparently not. What brand did you pull out? I can't read it on the pic.
    After the work, it should feel just a little more solid than mine? I know it's hard to do the comparison without a side-by-side jump from one to the other, but what do you think? I'd love to have mine an inch lower at some point, but first I had to get a good baseline.
    Nice VOC in the crotch story! I'm not sure I would have admitted that one!
  5. #5
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Oh and your car is gorgeous by the way. I wouldn't want to have to clean those wheels, but it's beautiful!
  6. #6
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    the struts that were in the car had no branding on them - just black casings and a warning about pressurized gas (no longer applicable).
    the car feels really nice now: well planted and quite settled. the swaybars make all the difference in the world when cornering (thanks for the tip Blue!) and have all but eliminated body roll - a total transformation from before (felt like a minivan in comparison). the springs/struts seem to do a better job of keeping the car from getting wobbly over bumps... just seems more settled, balanced, with less translated to the steering wheel.
    in truth it's hard to say if it's more solid than yours Cap'n, without driving them together on similar roads. definitely less body roll though. if you're going to lower your car, i would definitely recommend cutting coils first, try that before spending the $$ on the spring kit. worked like a charm for me - dropped it down just enough and kept the civilized ride i so cherish on my commutes.
    on another note - i discovered that my rack bushings are almost non-existent! with the car up in the air, if i grab a wheel and turn it sideways the whole rack lifts up & down about 1/2" - yikes. the good news is the rack seems totally tight otherwise and the bushings are cheap (already ordered) so i'm looking forward to pulling that slop out of the steering.
  7. #7
    Rust Free'ish zKars's Avatar
    Member ID
    CZCC-12190
    Join Date
    Jul 2006
    Location
    Calgary, AB Canada
    Posts
    1,256
    Default
    I may have discovered your initial "Rear too low, front too high" problem after the initial Eibach install.
    The 6203-001 springs are the fronts, the -002's are the rear... The picture you show in post #1 where the 6303-001 part number is visible on the very very short spring next to the stock rears was the clue. Many many of us have been caught by that little detail in the past.
    You likely accomplished much the same spring rate by using a shortened rear spring anyway. Someday when you're bored you can switch the Eibachs around and see if you prefer the ride and likely somewhat lower ride height any better. It looks just fine the way it is.
    Jim
    73 240Z HLS30 149331
    69 510 PL510 77603
    www.zKars.com
    www.calgaryzclub.ca
    Reference materials
    www.xenonS30.com
  8. #8
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I find that eliminating the roll makes the car move like a shark finning on the surface. Glad it all worked out. Good luck with the rack bushings!
  9. #9
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    oh crap - you mean i now have the rear springs on my front end?!? does anyone know how different an eibach progressive rear spring is from a stock front spring?
    the surprising thing is that this ass-backwards setup dropped the ride hight about 1" and seems to be riding really well... but of course now i'm wondering if i should swap everything back out??
    what a pain in the butt...
  10. #10
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    "Pain in the butt" beats brake cleaner blast
    Here are some rates: http://atlanticz.ca/zclub/techtips/springs/index.html
    Most seem to have rears at ~ 13% stiffer than fronts.
    You are now at front: 212 lbs/inch and rear ~ 151 lb/inch (approximation with the 2 ring cut factored in).
    So you are skewed with rears ~ 30% weaker than the front.
    It would be good to correct as this may make the car twitchy.
  11. #11
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    yes, as annoying as it is to repeat the process, i suppose i would rather tear the suspension apart and re-do it than take another chemical solvent hit to the nards...
  12. #12
    Registered User LeonV's Avatar
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Quote Originally Posted by zKars View Post
    I was going to say the same. I'd switch them...
    2/74 260Z
  13. #13
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    so i only had a couple of hours tonite, but managed to swap the eibach fronts. now i have the correct eibachs in the front and the cut stockers in the rear. will swap out the rear springs later when i have time. the front is now a bit lower, looks quite nice actually, and a quick test drive shows even better front end tracking, sticks really well. the rear is a little higher than the front - not funnycar high, just about 1".
    interesting experiment though - kind of an iterative test of different setups.
    what i started off with was a really crappy baseline: blown struts, tired, saggy sway bars and too-high stock springs. the ride was really boat-like for a sports car, lots of body roll and not much damping to speak of.
    the next test was with all eibachs, but front/rear reversed - very low rear, too high front, and the ride sucked. the front pushed and washed out in corners and the back was harsh.
    the third test was with eibach rears in the front and cut-coil stocks in the rear - ride height was level, and it actually felt pretty good (better than the first two setups)
    now i've got the correct eibach fronts and cut-coil stocks in the rear - ride is lower in front, it tracks quite well, but i'm actually feeling the road surface more from the back it seems...
    i hope to finish the swap either tomorrow or thursday nite and i'll report back.
    the good news is i'm getting pretty good at pulling her apart and swapping suspension bits - it's actually kinda fun :}
  14. #14
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Nice to see your observations matching theory.
    You are now F183 to R151 so only 17% weaker in rear compared to 30% for the last setup so the gap is closing.
  15. #15
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default Matching Set Installed...
    got a bit of free time this afternoon to pull out the cut oem rear springs and install the eibachs.
    the nice things about having done this job 3 times now are:
    • i know exactly what tools to use
    • none of the fasteners are difficult
    • i can do it in an hour
    the not-so-nice part is that fact that i've done it 3 times now...
    anyway, i did learn a few tricks that might help others:
    1. remove spring clips at flexible brake line and disconnect e-brake, un-bolt half-shafts at wheel connection, disconnect sway bar
    2. a good floor jack is a huge help - use it to prop up the control arm when you remove the strut tower bolts and slowly lower the assembly until it can swing out.
    3. remove rear bracket (2 bolts) that holds up the rear control arm, loosen the 2 bolts for the front bracket (the one closest to the diff) - this lets the control arm lower/hang at an angle so the strut assembly can be swung out and you can fully service it w/out removing from the car. this way you don't need a vice to get the top shock nut or gland nut off.
    4. loosen the top shock nut before removing the 3 top strut tower bolts (easier, better leverage) and if you back it off until the strut shaft dips below the nylock ring, it reduces the amount of futzing around w/the spring compressors, then as soon as the spring pressure is released from the perch, you can spin the nut off w/your fingers.
    5. with the floor jack under the control arm, you can lift the finished assembly up into the strut tower (use your foot to work the handle) while guiding the bolts into the chassis holes - use a socket on the top shock nut to rotate the cap to line up the 3 bolts w/the holes.
    piece of cake.
    the results:
    here is a picture of the car w/the eibach fronts and the cut-coil oem's at the rear - back end is slightly high
Name:	Eibach Front - Cut OEM Rear.jpg
    the ride was pretty good, even w/the wonky, mismatched spring rates, but the rear felt a little bouncy.
    here is a picture of the car w/the eibachs both front and rear - interestingly, the rear is actually just a little higher than before. i've heard the springs need to "settle in" a bit, so i'll reserve judgement for a while - anyone know how long it should take for them to "settle"?
Name:	Eibach Front and Rear.jpg
    the ride is much better - feels more "matched" front/rear. before, when i hit a bump, the front and rear reacted differently, now they react similarly. overall, the springs feel much firmer, but not harsh. the car feels much more crisp over the road, vs. the vague, mushiness w/the oem's. the new springs behave a lot like the suspension on my bikes - tuned for more aggressive riding, they actually feel better the harder they are run. the eibach's feel a little "bumpier" pootling around below 20 mph, but the faster i go, the better the suspension seems to perform. whereas the oem's sort of got overwhelmed at higher speeds, this setup feels quite a bit more confident.
    to be clear - i am no racer, but i can definitely feel that the car is a whole lot more fun now!
    main takeaway:
    • the biggest bang for the buck in stability/handling was the sway bar upgrade - HUGE difference.
  16. #16
    Member ID
    CZCC-19146
    Join Date
    Apr 2009
    Location
    Bay Area, CA
    Posts
    1,961
    Default
    Did you make sure to torque any fasteners at pivot points with the car loaded and on the ground?
    2/74 260Z
  17. #17
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    I concur, the sway bar was #1 for me too for best bang for the buck for street driving. The t-c ball and sockets were next but you need to a/b without/with to see this. I think your full upgrade masked it.
    The weak link(pun) with sway bars are the end links. If they are not tight then some of the effectiveness of the bar is lost. Poly's work better as the insulator pucks in the links.
    Of course the mount points for sway bar to the frame is a common rust point on the Z. The sway bar mount often pulls free. Bad Dog parts make plates to reinforce this area.
  18. #18
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    the msa kit came with poly bushings and i torqued the links enough to compress them a little with no load on the suspension - about 1/8" proud of the nylock nut.
    i'm fortunate in that the bushing connection points are all solid - no rust at all and the fasteners weren't even stuck. lots of grease was applied all over the pivot and bushing points, so i'm feeling good about it.
  19. #19
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    For things like sway bars and T/C rods, it never matters. Tighten them hanging or on the ground. No difference.
    The only ones that matter are the rubber style control arm bushings. One each side in the front inner, and eight in the back (fore and aft, inner and outer, each side). So, since you loosened the rear control arms to lean the struts out, you should tighten the four big inner bolts (like 26mm or something like that?) while the suspension is loaded. And if you loosened the spindle pin nuts (outboard) you should tighten those under load as well.
    And in the front, I couldn't tell if you had to loosen the front lower control arm pivot bolt to get the strut beyond the fender, but if so, then that one needs to be tightened under load.
    You might consider just giving it a few days of driving and "settling" and then loosening all ten pivot points while under load, letting the bushings relax, and then retightening them while still under load? Then get an alignment.
    If some time in the future you switch to poly control arm bushings, it won't matter anymore. The poly bushings are designed to pivot the inner sleeve inside the bushing instead of torqueing the rubber as the original design bushings do. And because of that, you can tighten the poly stuff while hanging or loaded. No difference.
    That rotating sleeve pivoting action of the poly bushings are what causes them to squeak if not greased properly. It's the inner sleeve turning inside the bushing material.
  20. #20
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    i didn't mess with the spindle pins - just the clamps that hold the rear control arms to the chassis. there are two: one next to the diff and one towards the rear of the car, each has two bolts. i greased up the rubber bushings plenty before re-installing. not sure how that joint would make a difference loaded or un-loaded, but i'll see if i can shimmy underneath and loosen/re-tighten them. might need some ramps, now that it's a bit lower...
  21. #21
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Grease on the outside of those rear bushings isn't necessary, and might even be an issue. You see... There isn't supposed to be any movement of the outer rubber portion within those clamps. All the movement is supposed to be twisting the inner sleeve inside the outer rubber portion. You really don't want the rubber portion squirming around.
    Works like this... You clamp the rubber portion tightly in the strap clamps and do not allow it to move. Then you pinch down on the ends of the bushing with the big flat washer and bolt until you have compressed the rubber completely. You're not tight until you have actually tightened it so much that the inner sleeve (with the toothed serrations) is held tightly against the control arm. So tightly, in fact, that the inner toothed sleeve will always rotate with the arm as the arm moves up and down.
    There should be no movement of the inner sleeve with respect to the control arm. They should be locked together.
    There should be no movement of the outer rubber with respect to the undercarriage. They should be locked together.
    The bushing works by torqueing the rubber between the inner sleeve and the band clamps. And that's what sets the rubber bushings apart from the poly replacements. They operate differently.
    The right way to do it would be to clamp down hard with the strap clamps on the outside of the bushings, and then (with the suspension loaded) loosen and retighten the big (26mm?) bolts that go through the centers of the bushings. Problem is, if there's corrosion or anything on the inside of the bushings they still might not spin to their new "happy place".
    I'm not a suspension guy and I'm having troubles explaining this... Is any of this making any sense at all?
    Last edited by Captain Obvious; 06-01-2014 at 06:36 AM. Reason: My cat was helping me type and she can't spell good
  22. #22
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    There's also some discussion about how the rubber bushings work in this thread. It started about spindle pins and washers, but got to bushings in general at the end of the thread:
    http://www.classiczcars.com/forums/s...r-washers.html
  23. #23
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    ohhhhhh.... that makes perfect sense to me now. i did it all wrong, and am thinking that's probably one of the reasons the rear is still sitting a little high.
    i was actually surprised to see that when i lowered the car off the stands, the rear was WAY high (wheels cambered) and i figured the springs needed to settle in. duh...
    i will pull them apart, wipe off grease, re-do and report back.
  24. #24
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    If you're going to loosen the rear all back up again, I'd do this:
    Loosen (a couple turns) but don't remove the four big bolts that hold the inboard bushings to the control arms. Left side of this pic is a good view of the bolt I'm talking about. You can see it threaded a few turns into the control arm:
    Drop the hanger "U" clamps completely and let the inboard side of the control arm hang down a little.
    Grab the rubber portion of the bushing and make sure it isn't rusted tight to the control arm. It should spin about the cylinder that goes through the middle. If they're free, cool, if not, take the big bolts out completely, pull the bushings off the control arms and clean out the ID so they DO spin free.
    After you have verified that the bushings are free to rotate, position them so the rubber "wings" are horizontal and fitted into the non-round cavity formed by the "U" clamp and the undercarriage and once the "wings" are in the right position, reinstall the "u' clamps to hold the control arm back up against the underside. Not completely tight yet, but couple turns off fully bottomed out?
    Snug, but not completely tighten the four big bolts. This will make sure the bushings are properly located all the way home on the cylinder.
    Tighten the "U" band clamps locking the outside rubber to the undercarriage.
    Loosen the four big bolts a turn or so.
    Drop the car to load the suspension and while it's loaded, tighten those four big bolts till your eyeballs bug out.
    Since I don't have a pit or an alignment rack... When I lowered my car, I lowered it onto moving dollies with a couple pieces of wood stacked on top for some extra work height. The dollies allowed the suspension to squirm around to wherever it wanted to naturally go and didn't have to worry about friction of the tires stuck to the garage floor. The boards stacked on top gave me the extra inch or two I needed to reach under and tighten those bolts while the car was on the dollies.
    Don't drop the car on yourself or anyone else. I had my front end on jack stands at the time so the body was level. Rear on dollies, front on stands.
    In the end, the outer position of the bushings should have the wings locked into the corners where the clamps meet the underside, and the inner cylinder should have been able to find it's "natural happy spot" under load and then locked in place.
    Summarize the whole thing up like this... When the car is sitting neutral, you want the bushings to be neutral and not under any torque. Then when the suspensions moves up and down, you torque the bushings one direction or the other. But at rest, no torque.
  25. #25
    Member ID
    CZCC-24608
    Join Date
    Jul 2011
    Location
    Philadelphia, PA
    Posts
    1,845
    Default
    Sorry for the stream of consciousness, but I've been thinking about this a little... I think that since you lowered your car, you should "re-neutralize" all of your control arm bushings. Both front and rear. All ten of them.
    Reason being, if your bushings were neutral before you lowered it, it's guaranteed that they aren't neutral anymore.
    Fronts are easy. Spindle pins are easy unless the bushings are rusted to the pin. Only difficult ones are the rear inners that you're already working on.
    Hope you didn't think you were done!
Thread Information
Users Browsing this Thread
Similar Threads
  1. 280z Suspension Upgrade Parts
    By S30Driver in forum Suspension and Steering (S30)
    Last Post: 04-29-2010, 09:19 AM
  2. suspension upgrade
    By khughes in forum Wheels, Tires, Brakes (240K)
    Last Post: 04-26-2010, 08:17 PM
  3. Interpart Suspension Upgrade Kit Help Please
    By JohnnyO in forum Suspension and Steering (S30)
    Last Post: 03-08-2010, 12:55 AM
  4. Suspension and Steering upgrade
    By Ramses in forum Suspension and Steering (S30)
    Last Post: 04-19-2007, 09:11 AM
  5. suspension upgrade help please
    By gator in forum Suspension and Steering (S30)
    Last Post: 10-29-2006, 12:45 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
