Results 1 to 13 of 13
Thread: Installed wrong muffler could damage my 240z?
  1. #1
    Registered User
    Member ID
    CZCC-29967
    Join Date
    Dec 2013
    Location
    Panama
    Age
    44
    Posts
    157
    Default Installed wrong muffler could damage my 240z?
    As per my previous post, last week i removed the following muffler which has 2" inlet and 2"outlet from my car due to its size and fitment besides the gas tank:Click image for larger version.
Name:	Muffler Datsun 240z.jpg
    Anyway, i swap this muffler for a smaller 14" long muffler with 1 3/4 inlet and outlet 1 3/4:
Name:	New installed Muffler.jpg
    When driving the car home i noticed the car had lost power and you could hear explosions under the car. I decided to park the car for a couple of days until i could take it to another shop where i found a Dynomax Super Turbo 2" inlet and 2" Outlet muffler. The car now gain strenght but according to my mechainic was running in 3 cylinders only with random explosion noise after shifting to 2nd gear.
    My question is Could driving the car in these conditions have damaged something in the engine, require new tuning of the carbs and new timing adjustment?
  2. #2
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    75
    Posts
    4,424
    Default
    1 3/4" inlet/outlet is pretty close to what the OEM muffler is - so unless there was something inside that second muffler that had collapsed.. or was shutting the exhaust flow off almost completely - - it is very doubtful anything would be harmed at the engine.
    FWIW,
    Carl B.
  3. #3
    Nova Scotia,Canada,Earth Blue's Avatar
    Member ID
    CZCC-7641
    Join Date
    Jan 2005
    Location
    NS
    Posts
    4,085
    Default
    Carbs may be out of balance
    What do each of the 6 plugs look like starting with #1 (near radiator) to #6 (near firewall)
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
    The person who buys on price alone is this man's lawful prey.
    John Ruskin (1819 - 1900)
    ZCars in Eastern Canada seaport ready for shipment to Europe
    http://ZSportCanada.com
  4. #4
    Registered User Hardway's Avatar
    Member ID
    CZCC-26208
    Join Date
    Jan 2012
    Location
    Austin TX
    Posts
    659
    Default
    I would like to know more about the "internal explosions" taking place in the engine that you are talking about. Our engines by their very nature have internal explosions to run a they are internal combustion engines. I agree with Carl that unless there was an issue with the muffler itself you should not have any issues. I wonder if you mean "pinging" is what you heard by the internal explosions. If so, this would happen at higher RPMs and could be due to many factors such as incorrect timing, lack of fuel, or using low octane gas to name a few. Just looking at the pictures above, the 90 degree elbow at the inlet of the muffler was definitely hurting flow and performance but should not make an engine run on only 3 cylinders.
    08/1970 240z Series-1 #8011 - Silver, black int., 2.4L I-6, 5spd, 90% restored.
    06/1973 VW Karmann Ghia - Black convertible, 4spd, 1600cc air-cooled engine.
    11/2013 Scion FR-S - Silver, 6spd, a car with the soul of a Z for the modern times.
    Restoration thread of my old '72 240z -> http://www.classiczcars.com/forums/o...1972-240z.html
  5. #5
    Registered User rossiz's Avatar
    Member ID
    CZCC-30163
    Join Date
    Feb 2014
    Location
    Seattle, WA
    Age
    54
    Posts
    323
    Default
    sounds to me like it was backfiring - restricted exhaust does richen up the mixture and if the offending muffler has significantly less flow, coupled with perhaps already poorly tuned carbs and suspect ignition timing, and you get fouled plugs, hence "running on 3"...
    following his threads i'm not sure the car is correctly tuned to start with.
    '78 280z - Daily driver/work in progress...
  6. #6
    Registered User
    Member ID
    CZCC-29967
    Join Date
    Dec 2013
    Location
    Panama
    Age
    44
    Posts
    157
    Default
    Quote Originally Posted by rossiz View Post
    This is the advice i was looking for!!!! The carburetors may have gotten out of tune. Can i do the ignition timing perfectly without the ignition timing tab installed:
    Datsun 240Z 280z Timing Indicator Tab | eBay
    Please confirm!
  7. #7
    Registered User
    Member ID
    CZCC-29967
    Join Date
    Dec 2013
    Location
    Panama
    Age
    44
    Posts
    157
    Default
    Ok. The car is already tuned up and three spark plugs have been replaced. The car lacks strenght anyhow. Will the Dynomax Super Turbo muffler work fine for this car? something in the exhaust may be causing the power restriction.
    Dynomax 17730 Dynomax Super Turbo Mufflers - Free Shipping on All Orders @ JEGS
  8. #8
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    Disconnect the muffler entirely and see what happens. It will be loud but you should be able to tell if it's down on power.
    1976 280Z, with some minor modifications
  9. #9
    Registered User Stanley's Avatar
    Member ID
    CZCC-24191
    Join Date
    Apr 2011
    Location
    Redondo beach
    Posts
    641
    Default
    Rather than relying on the manufacturer's claims, unless you have personal knowledge, I would rely on my local muffler shop to choose a muffler that won't restrict flow, and won't be too loud. They should have plenty of experience as to how a particular muffler will sound, perform and fit. Also, there are some good threads on this site about specific muffler and exhaust pipe combinations, but what someone else thinks is perfect might be too loud for you (and your local PD).
    I've heard to use 2 1/4' exhaust pipe for 240Z engine, 2 1/2" exhaust for 280Z. From your previous posts, you have a built engine with a cam that works better in a higher rpm range. That means if you're driving 30 mph in high gear, performance might not be great.
    If you choke it off with a muffler or exhaust pipe that's too small, performance will be even worst. Your experiment may have confirmed that.
  10. #10
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    I think that his muffler shop created the abomination in the first post. Some of his other posts imply that he doesn't have many good shops to go to. He's in a tough spot.
  11. #11
    Registered User
    Member ID
    CZCC-29967
    Join Date
    Dec 2013
    Location
    Panama
    Age
    44
    Posts
    157
    Default
    HAHAHA! The mechanic tuned the car carbs again and changed 3 of the spark plugs that got damaged due to backfiring. The car was tested and had lost power. Thinking that the loss of power could be due to the bad muffler installation, he chopped down the exhaust and discovered it was the electric fuel pump that was failing. What Brand and type of Electric fuel pump can i order for my 240z which has a Far 311 race cam and 5 speed transmission from a 280z? I need a reliable and powerfull one.
  12. #12
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Posts
    3,629
    Default
    Quote Originally Posted by jalexquijano View Post
    You just need reliable, not powerful. The cam and the transmission don't mean anything as far as the fuel pump goes. Get a stock pump, or try the Mazda pump (search around the internet for model).
    If your mechanic did all of that work just to find a weak fuel pump, you might still need a new mechanic. By now, using this forum and the internet, you should know more about your car than any of the mechanics you've used. And spark plugs don't get damaged from back-firing.
  13. #13
    Registered User
    Member ID
    CZCC-29967
    Join Date
    Dec 2013
    Location
    Panama
    Age
    44
    Posts
    157
    Default
    Well, Just to let all of you know that my car is finally is running smooth with no backfire. It has a Master branded electric fuel pump and a Dynomax Super Turbo 2 inlet and 2 outlet installed. Thanks for your great help!
Thread Information
Users Browsing this Thread
Similar Threads
  1. 71 240Z muffler question.
    By rubrbulits in forum Exhaust (S30)
    Last Post: 10-09-2012, 03:39 AM
  2. '72 240z Muffler recommendations?
    By dntpunchgrandpa in forum Exhaust (S30)
    Last Post: 01-27-2010, 05:26 PM
  3. Replies: 2
    Last Post: 10-07-2006, 08:06 PM
  4. installed moustache bar bushing wrong...
    By san_maru_zed in forum Suspension and Steering (S30)
    Last Post: 01-15-2005, 04:06 AM
  5. 240Z muffler
    By llylaclama@aol.com in forum Open S30 Z Discussions
    Last Post: 01-08-2001, 04:45 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
