Results 1 to 23 of 23
Thread: What kind of battery is in your Z?
  1. #1
    Registered User peng155's Avatar
    Member ID
    CZCC-7489
    Join Date
    Dec 2004
    Location
    Seattle, WA
    Age
    62
    Posts
    168
    Default What kind of battery is in your Z?
    Hey Folks,
    I was curious as to what type/make battery you had in your 'Z'
    Right now I have a regular lead acid battery in the 'Z'... after I drive the car and park back in the garage, I pull the battery, put it on the bench and hook up my smart charger to it to keep the battery charged... This get's to be a pain, BUT I'm worried about the acid boiling out, and getting all over the place in the engine bay if the charger goes wonky...
    I also have a Red Top Optima that I have another smart charger in the garage, but it doesn't fit the factory battery hold down frame... I would prefer to switch to the sealed Optima that way I think I'm safer from battery acid getting all over the engine bay when it's hook-up to the charger.
    I've never had a problem with a leaking battery... I'm I being paranoid??
    thanks....
    -Phil
    Phil
    71 Series-I
    HLS3010924 - Build 9/70
    ___________________________
  2. #2
    Fired Up! JLPurcell's Avatar
    Member ID
    CZCC-7454
    Join Date
    Dec 2004
    Location
    Richmond, Indiana
    Age
    67
    Posts
    1,098
    Default
    A dead one at the moment!
    Jerry Purcell
    1970 HLS30 00029 Owner since 1976 Now owned by Les Canaday (Classic Datsun Motorsports)
    1972 HLS30 93606 IZCC Registion #105 Original owner back home after full restoration by Classic Datsun Motorsports
  3. #3
    Registered User rcb280z's Avatar
    Member ID
    CZCC-21454
    Join Date
    Apr 2010
    Location
    Ventura Ca.
    Age
    58
    Posts
    873
    Default
    Autozone Duralast gold 700 CCA. Works well.
  4. #4
    Jim Arnett jfa.series1's Avatar
    Member ID
    CZCC-22303
    Join Date
    Aug 2010
    Location
    Richardson TX
    Posts
    764
    Default
    I have a conventional battery with reversed posts (positive near the engine) and keep a maintainer on it most of the time. I've never had a leakage problem in all the 43+ years I've owned the car but have always had a good tray and drain tube under the battery. If a car is going to be stored/unused for a long period, pull the battery.
    Jim Arnett
    HLS30-15320 12/1970, original owner
    L24-020208 (original)
    IZCC Original Owner Registry #53
  5. #5
    Member ID
    CZCC-7489
    Join Date
    Dec 2004
    Location
    Seattle, WA
    Age
    62
    Posts
    168
    Default
    Quote Originally Posted by JLPurcell View Post
    Hahaha...... Yeah been there, after I've forgotten (actually just lazy) to put the charger on the battery
    Phil
    71 Series-I
  6. #6
    Low Budget/High Value
    Member ID
    CZCC-20342
    Join Date
    Oct 2009
    Location
    Washington County, OR
    Posts
    3,629
    Default
    The charger shouldn't cause any more leakage than the alternator in the car. The alternator can put out 60 amps if it needs to. Subtract out electrical load and you're still probably around 45-50 amps at normal driving speed, but only if the battery is discharged. Most chargers are in the 4 - 5 amp range I think. The voltages are about the same also, maybe higher for some alternator systems.
    1976 280Z, with some minor modifications
  7. #7
    Registered User Oiluj's Avatar
    Member ID
    CZCC-15388
    Join Date
    Nov 2007
    Location
    SF Bay Area
    Age
    67
    Posts
    1,746
    Default
    Lead acid from Auto Zone for last 4 years with reversed terminals. Still working fine.
    Julio
    1972 240Z (in-progress, 95% complete)
    CZC# 15388
  8. #8
    Walmart greeter Mikes Z car's Avatar
    Member ID
    CZCC-18366
    Join Date
    Dec 2008
    Location
    Idaho
    Posts
    1,041
    Default
    What I discovered is that the charger I had wanted to overcharge causing acid to come out. I bought a battery tender and it doesn't overcharge the battery so it does not release acid. My thinking is that the battery tender has smarter voltage sensing so it does no harm.
  9. #9
    Registered User Pop's Z's Avatar
    Member ID
    CZCC-8342
    Join Date
    May 2005
    Location
    Fort Collins, Colorado
    Age
    75
    Posts
    430
    Default
    On the battery itself, I found out that Costco sells their own brand of battery, but it is made by the same company and to the same specs as the Interstate, but at 2/3 the price. Good deal? Yes, I got one for my Subaru daily driver and have been pleased with the result and the savings. Next time the Zed needs a battery that's where I'm going. Currently on my Zed I use a "Battery Tender" on a NAPA brand lead-acid battery and have had no leakage or problems and it sits idle most of the winter. I do start it occasionally and let it warm up before shutting down. Never a problem, always full power.
    Cheers, Mike
    '73 240Z, 80,000 original miles, F54, N42 massaged and shaved (10.5-1 comp.), stage 2 cam, ZX ignition, Header, 2 1/2" exhaust w/ magnaflow muffler, 5 spd (Maxima), 4:11 R180 (200SX), 15" Rota RBs 205-60/15 Bridgestone Grid 109s, KYB struts, stock springs, rubber bushings, MSA sway bars and strut bars, HotRod Air hvac system, '90 300ZX seats, upgraded sound system, BRE-type spook and spoiler
  10. #10
    Registered User psdenno's Avatar
    Member ID
    CZCC-14231
    Join Date
    Apr 2007
    Location
    SoCal Desert
    Age
    73
    Posts
    1,091
    Default
    Quote Originally Posted by Pop's Z View Post
    I needed a new battery for my '71 a couple weeks ago and went to Costco for that exact reason. I took my old battery in for a match and asked for a battery for a 1971 Datsun 240Z. First question was, "Who makes Datsun?". That was followed by, "Sorry, we don't carry or have a listing for that size battery, try the Interstate Battery store across the street.".
    Instead, I went to Sam's Club and bought one off the rack for a reasonable price with a good warranty.
    Dennis
    1971 240Z - Original Owner
    2010 Infiniti G37 Convertible
  11. #11
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Clearwater,Florida USA
    Age
    76
    Posts
    4,424
    Default
    Red Top in the White 72 - somewhere in this forum, I believe one person posted a diagram that shows how to build a custom top battery bracket for the Red Tops.
    Interstate - in the Blue 72
    Interstate Absorbed Glass Mat's {AGM} two of them in the BRE Z
    All kept on battery tenders..
    Important to note - that all of todays batteries have Posts that are no longer in the exact same position - as batteries from the 70's. The result is that the OEM Battery Hold Downs - now come very very closet to the terminals on the cables. I've had to wrap battery top hold down brackets with electrical tape - to assure that the positive terminals on the battery cables - don't come into contact with the bracket.
    I bought a Firestone "FOREVER" battery in 1976… Firestone has been replacing it free of charge since then. They were lasting 3 to 4 years, when not kept on modern battery tenders. The last one lasted 7 years when kept on a battery tender. It was replaced by Firestone with an Interstate, which is what they now carry.
    I say "battery tender" rather than "Battery Tender" because mine were made by Guest.. Battery Maintainer/Charger - charges at 3 amp if necessary. Otherwise it is a microprocessor controlled - Float Charger. It kicks on and charges when battery voltage drops to around 12.2 volts, kicks off when the charge is back up to 12.6. These Float Chargers keep your battery fully charged - and won't overcharge like the older Trickle Chargers could. There is no need to take the battery out of the car.
    FWIW,
    Carl B.
  12. #12
    Registered User S30Driver's Avatar
    Member ID
    CZCC-21075
    Join Date
    Mar 2010
    Location
    Seattle Washington
    Posts
    163
    Default
    Optima Red Top
    4 + years
    1977 280z 06/77
  13. #13
    Member ID
    CZCC-7489
    Join Date
    Dec 2004
    Location
    Seattle, WA
    Age
    62
    Posts
    168
    Default
    Hey S30Driver,
    How do you have your Red Top secured in the battery tray?
    Need to find some sort of diversion from the TV right now... Hawks are getting schooled by the Chargers But it only the 3rd quarter.... still hope
    Phil
    71 Series-I
  14. #14
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    76
    Posts
    4,424
  15. #15
    Member ID
    CZCC-7489
    Join Date
    Dec 2004
    Location
    Seattle, WA
    Age
    62
    Posts
    168
    Default
    thanks Carl
    Phil
    71 Series-I
  16. #16
    Registered User Mike W's Avatar
    Member ID
    CZCC-19584
    Join Date
    Jun 2009
    Location
    Austin, TX
    Posts
    243
    Default
    I also use an Optima Red Top with positive and negative terminals reversed from original configuration. Best battery I have ever used. Started with marine applications first and now use them in all of my cars.
    Instead of fabricating the bracket that Jeff G designed, I ended up going with a machined billet hold down plate that was specifically made for the Optimas. You can get these from numerous sources as well as eBay. I simply bolted the new Optima plate to the original battery plate that was welded into the Z. I had the back hold down bracket already installed, then slipped the battery in, then installed the front hold down bracket. It was a little tricky getting the bolts tightened and it was a relatively tight fit, but in the end it worked out great.
    Here's a few pictures.
    Mike.
    Click image for larger version.
ID:	74045 Click image for larger version.
ID:	74046 Click image for larger version.
ID:	74048 Click image for larger version.
  17. #17
    Member ID
    CZCC-7489
    Join Date
    Dec 2004
    Location
    Seattle, WA
    Age
    62
    Posts
    168
    Default
    Hey Mike,
    thanks for the suggestion.... I actually did order a billet hold down frame from Summit for the Optima, and was going to do exact the same as you, but the tray for the one I had ordered was physically to big to fit in the factory tray area... ended up sending it back.
    I know some metal work guys from work, with the plans that Carl linked to, I'll probably have a bracket made up for me...
    Thanks all for your input... it is apprceated
    Phil
    71 Series-I
  18. #18
    Registered User Jeff G 78's Avatar
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Northville, Michigan
    Age
    55
    Posts
    1,895
    Default
    Quote Originally Posted by Carl Beck View Post
    Thanks for linking my bracket drawing Carl. It was easy to make and only needed a few short welds which I had a friend do since I didn't have a welder at the time. I bought the steel at Home Depot.
    Last edited by Jeff G 78; 09-14-2014 at 07:32 PM. Reason: Posted before reading all replies
    Jeff
    IZCC #1285
    '78 280 10:1 CR, Arizona Z Car header, urethane bushings, Tokico springs, Illumina struts, Panasports w/Hankook R-S2 225/50R16 tires, Maxima 105 amp alternator
    http://www.classiczcars.com/photopos...00&ppuser=7975
    '74 260Z BRE look-alike crap can for Optima Batteries ChumpCar World Series Racing racing
    https://www.facebook.com/Jeff.Grauer
  19. #19
    Member ID
    CZCC-7489
    Join Date
    Dec 2004
    Location
    Seattle, WA
    Age
    62
    Posts
    168
    Default
    Quote Originally Posted by Jeff G 78 View Post
    Hey Jeff,
    Thanks for taking the time to come up with the CAD drawing for the bracket... it makes it real easy for me to just hand it to the metal guy's to fab up for me.
    Phil
    Phil
    71 Series-I
  20. #20
    Member ID
    CZCC-7975
    Join Date
    Mar 2005
    Location
    Age
    55
    Posts
    1,895
    Default
    No problem Phil. I took CATIA training at work just before I bought my Optima and it was a good way to practice what I learned. I haven't used it much since then and couldn't possibly make that CAD model now.
    Don't forget to have the fabricator swap the cantilevered hole for a piece of small tube. It works better than the simple hole like I put in the CAD model. Using heavy duty Velcro as a cushion has worked well and is still in good shape after many years of use.
    Jeff
    IZCC #1285
  21. #21
    Registered User
    Member ID
    CZCC-3609
    Join Date
    Feb 2003
    Location
    Age
    76
    Posts
    4,424
    Default
    Jeff - ZTek has a battery hold down for the OEM Battery. I sent him a copy of your drawing/model - and ask if he had anything like that for the Optima. Must say he makes some very nice pieces.. BLING!
    Polished Billet 240Z Logo Battery Hold Down 70 78 Datsun S30 | eBay
    Will let you know..
    I like Mike W's set up as well. Thanks for Posting that Mike.
    Carl B.
  22. #22
    Member ID
    CZCC-7489
    Join Date
    Dec 2004
    Location
    Seattle, WA
    Age
    62
    Posts
    168
    Default
    Hey Jeff,
    I did see that change in your original post... good idea... I'll make sure I mention that to the fabricator when I see him.
    Thanks again.
    Phil
    71 Series-I
  23. #23
    Z Club of San Diego Montezuma's Avatar
    Member ID
    CZCC-10665
    Join Date
    Feb 2006
    Location
    San Diego
    Age
    57
    Posts
    1,063
    Default
    An Interstate Battery from Costco.
Thread Information
Users Browsing this Thread
Similar Threads
  1. POP QUIZ: What kind of car is this?
    By Mike in forum Publications
    Last Post: 12-14-2012, 11:03 AM
  2. newbee kind of
    By kacrow76 in forum Open S30 Z Discussions
    Last Post: 10-07-2011, 03:52 PM
  3. what kind of console is this?
    By oskidunker1 in forum Open S30 Z Discussions
    Last Post: 04-11-2010, 02:59 PM
  4. battery bracket for Red Optima battery
    By Curtis240Z in forum Electrical (S30)
    Last Post: 03-21-2008, 08:22 AM
  5. What kind of hat do you like?
    By Mike in forum Front Page News
    Last Post: 09-21-2004, 06:29 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
