Results 1 to 6 of 6
Thread: Wierd whining sound coming from the engine compartment...
  1. #1
    The Lone Potter v12horse's Avatar
    Member ID
    CZCC-3738
    Join Date
    Mar 2003
    Location
    Fremont, Ca
    Age
    38
    Posts
    1,130
    Question Wierd whining sound coming from the engine compartment...
    There is this wierd sound that is coming from the engine compartment. It seems to be there when I start it, but when it starts moving it is still there but not as much. It sounds like an aweful whine. The car just started making the sound today. The only thing that I did different was not warm it up because I was in a rush, but I don't think that would be it. I thought it was coming from the fan or the fan shroud, but I am not certain. It is an early 260z. If any one can help or give ideas that would be great. Thanks.
    -Ben
    "A real sports car chooses its owner because it has a soul. If you're chosen, you'll love it, and the more it requires care and maintenance the more you love it." -Mr. Morita (Z432 owner)
    RLS30-034436
    305 GP Light Blue
  2. #2
    Registered User Bruce Woolmore's Avatar
    Member ID
    CZCC-3699
    Join Date
    Mar 2003
    Location
    Auckland New Zealand
    Posts
    68
    Wink whining sound
    have you seen the cat lately??
  3. #3
    HLS30165540
    Member ID
    CZCC-1052
    Join Date
    Jan 2001
    Location
    Houma, Louisiana
    Age
    55
    Posts
    2,297
    Default
    It would really help us if you could pin point where the sound is coming from. It might be a bearing but unless you can pin point it who knows which one. Take a long screw driver phillips or flat tip it doesn't matter the longer the better.
    Place the tip of the screw driver against a stable piece of metal close to a bearing while the engine is running (watch out for that fan!) put it as close to the bearing as you can.
    Check the alternator, water pump, air pump & A/C.
    Next put your ear against the handle of the screw driver and listen. Move the screw driver around to different parts and listen. Basically you are using the screw driver like a stethascope.
    Eventually you will find where the whine is coming from.
    The 1973 240Z 165540 Slightly modified. L28, 5sp, cam, headers, MSD 6AL, power windows, power door locks, leather seats, custom this and custom that.
  4. #4
    Member ID
    CZCC-3738
    Join Date
    Mar 2003
    Location
    Fremont, Ca
    Age
    38
    Posts
    1,130
    Default Thanks...
    I will definately do that stethescope procedure today and post what I hear.
    -Ben
    RLS30-034436
    305 GP Light Blue
  5. #5
    CentralValleyZ.org SoCalZ's Avatar
    Member ID
    CZCC-908
    Join Date
    Aug 2000
    Location
    Lemoore, Ca
    Posts
    50
    Lightbulb
    Might be your fan clutch. Had it happen but it would whine only at a certain RPM and when it was warmed up. Might be worth looking into. As Bruce suggested, I would also be looking for that cat!!
    Chief Air Traffic Controller
    Naval Air Station Lemoore, Ca.
    IZCC 9484
  6. #6
    Member ID
    CZCC-3738
    Join Date
    Mar 2003
    Location
    Fremont, Ca
    Age
    38
    Posts
    1,130
    Question what sound????
    I have not heard that sound anymore since I wanted to go in there and check what it was. Figures.. I am going to be driving it from the Bay Area to Orange county next week for the Motorsport Z nationals so that will be the test of what that sound was. I want to find that kitty. Darn. Thanks a lot.
    -Ben
    RLS30-034436
    305 GP Light Blue
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
