Results 1 to 4 of 4
Thread: 240 power antenna replacement
  1. #1
    Registered User Si|v3r72's Avatar
    Member ID
    CZCC-1788
    Join Date
    Mar 2002
    Location
    Dover, DE USA
    Posts
    185
    Default 240 power antenna replacement
    My stock antenna has finally died - thanks to a car wash attendant. I put my car through the wash and forgot to lower the antenna, went to pay and realized the antenna was still up, ran back to lower it before it went through, and to my horror found the attendant trying to lower it by hand. Needless to say, he killed it. He was gracious enough to offer to pay for replacement if he damaged it, so I'm in the market for a new one.
    So where's the best place to get a replacement? MSA? Which antenna works best in a 240?
  2. #2
    mmm Z cars.. ohhh bbabyy PrOxLaMuS©'s Avatar
    Member ID
    CZCC-4022
    Join Date
    Apr 2003
    Location
    Colorado
    Age
    34
    Posts
    1,071
    Default
    or a 280Z... i need one pretty bad
    1978 280Z Boring Mods :
    F54/P90a, Holset HY35W turbo, 3.75" downpipe, 3" exhuast, NPR intercooler, 440cc injectors, Innovate Wideband, Arizona Zcar springs, Tokico 5 ways, MSA sway bars
    www.putfile.com/proxlamus
    SEE my 280Z in ACTION! VIDEO!
  3. #3
    Registered User Victor Laury's Avatar
    Member ID
    CZCC-1303
    Join Date
    Oct 2001
    Location
    Los Angeles
    Age
    61
    Posts
    1,814
    Default
    I bought the "aftermarket", "modern" auto antenna from MSA. It was a clean installation. I ran an un-switched 12 volt wire and the antenna motor signal wire together along the path of the rear harness. Six months of good duty so far.
    DatsunVic CZC1303
    ダットサンビク
    72 HLS30 94071
    72 510
    70 SRL311 13136
    71 PL521
    Los Angeles
    Visit My Other Photo Site
  4. #4
    CentralValleyZ.org SoCalZ's Avatar
    Member ID
    CZCC-908
    Join Date
    Aug 2000
    Location
    Lemoore, Ca
    Posts
    50
    Thumbs up
    It is an easy job to replace just the mast, Just remove the nut on the top on the outside and have some one run the button while you pull the old one out and then run the button while you feed the new one in to the hole until it is retracted. then replace the nut and you are done. No need to remove all the interior panels and the whole unit.
    Chief Air Traffic Controller
    Naval Air Station Lemoore, Ca.
    IZCC 9484
Thread Information
Users Browsing this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
